Sheber Pitts S1S build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Sheber Pitts S1S build
Page: [1] 2   next >   >>
Login
Sheber Pitts S1S build - 9/6/2012 9:30 PM
SplinteredProp
Score: 100
Last Login: 5/21/2013
Status: offline
 Greetings,
New to the board, and would like to document this build here.  If anyone is interested, they are welcome to follow along.
I just got my hands on a set of Andy Sheber 1/3 Pitts S1S plans, so the build is in it's infancy.
So far, I've only made a copy of the plans, cut up the copy to useable sizes, and have made a material list.
This will not be a fast build, since weekends are the only time I can dedicate to building.
Since it is my intention to post a pic with every post (except if answering a question), I will start off with a pic of the plans.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Sheber Pitts S1S build - 9/6/2012 9:50 PM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
Hi There,
I built a 1/3 s1s from the toni clark kit a couple of years ago so i'm definatly interested in your build !
                   cheers
                          john
Hide Signatures
(in reply to SplinteredProp)
       Post #: 2
RE: Sheber Pitts S1S build - 9/7/2012 3:40 AM
smithcreek
Score: 159
Last Login: 5/23/2013
Status: offline
Looking forward to this.
_____________________________
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to john josey)
       Post #: 3
RE: Sheber Pitts S1S build - 9/9/2012 3:19 PM
SplinteredProp
Score: 100
Status: offline
This plan requires various elements to be laminated to curved shapes, the most complex being the horiz stab/elevator (hs/e).
Since I've never attempted this method of construction before, this seemed like the logical place to start.
Pic 1: The plan.
Pic 2:  I traced  the inside line of the perimeter of the hs/e, cut out the pattern, and glued it to doubled up pieces of MDF, which   I screwed together.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to smithcreek)
       Post #: 4
RE: Sheber Pitts S1S build - 9/9/2012 3:21 PM
SplinteredProp
Score: 100
Status: offline
Pic 1: The pattern/template after being cut with a band saw and final shaped with a bench belt/disc sander.
Pic 2: I drilled 1" dia holes through the template while they were still screwed together - these will provide places for clamping. I then seperated the 2 template halves, placed packaging tape around the perimeter and screwed then to my workbench.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Sheber Pitts S1S build - 9/9/2012 3:28 PM
SplinteredProp
Score: 100
Status: offline
I needed a few balsa strips, so I fashioned a bench mounted balsa stripper.
The plan calls for a final thickness of 5/16, but I cut these to 7/16 to allow me to sand out imperfections and uneven strips.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6
RE: Sheber Pitts S1S build - 9/9/2012 3:38 PM
SplinteredProp
Score: 100
Status: offline
I soaked the balsa strips for about an hour, then placed them, without glue, around the template.  I wanted to pre-shape the laminate strips before gluing.  I thought this would make the gluing process easier.  That also explains the lack of wax paper under the template in the first pic.
After the laminate pieces dried, I removed them from the template, placed wax paper under the template, and began gluing the layers together.
I glued a single layer at a time, allowing approx 30 minutes between layers, for a total of 6 layers, and let dry overnight.
The finished piece ended up being between 13/32 and 7/16 thick, allowing me enough material to sand to a finished 3/8 width.
Overall, I'm pleased with the finished result, considering I have never attempted this construction method before.
That's it for this weekend - Today is going to be spent watching football.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Sheber Pitts S1S build - 9/16/2012 12:50 AM
SplinteredProp
Score: 100
Status: offline
OK, back to the shop...
The first thing I did was to cut the HStab TE & Elev LE to the correct size, mark the hinge locations, add 5/16x3/8 backing to the hinge locations, drill them both at the same time on the drill press.  I then inserted dowels in 4 of the 8 hinge holes to keep everything aligned. (Pic 1)
My shop helper (Pic 2)
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Sheber Pitts S1S build - 9/16/2012 3:34 AM
acerc
Score: 221
Status: offline
I have the plans, cowl, pants, and canopy. Plan to start after the first of the year. So I am subscribed and learnin.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 9
RE: Sheber Pitts S1S build - 9/16/2012 2:08 PM
SplinteredProp
Score: 100
Status: offline
I didn't like how little material there was for the hinges to grab onto in the elevator, so I added more balsa. (Pic 1)
The almost finished stab/elev (pic 2)
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 10
RE: Sheber Pitts S1S build - 9/16/2012 2:10 PM
SplinteredProp
Score: 100
Status: offline
Rather than use block balsa in areas that require addidtional strength, I made 3-ply balsa pywood...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: Sheber Pitts S1S build - 9/23/2012 3:12 PM
SplinteredProp
Score: 100
Status: offline
I cut the H stab/elev gussets out of 1/8" plywood on the scroll saw & sanded to fit (pic 1)
The finished H stab/elev (pic 2)
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Sheber Pitts S1S build - 9/23/2012 3:22 PM
SplinteredProp
Score: 100
Status: offline
I dislike sanding the edges of control surfaces since I feel as though I have little control - especially on this H stab/elev with everything being curved.
So I figured a shaping tool of some kind was needed and made on out of a piece of 1/2" PVC & some self-adhesive sandpaper.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Sheber Pitts S1S build - 9/23/2012 3:23 PM
SplinteredProp
Score: 100
Status: offline
The finished result after using the PVC sander & finishing with some 220 grit.
Click for fullsize
Hide Signatures
       Post #: 14
RE: Sheber Pitts S1S build - 9/23/2012 3:26 PM
SplinteredProp
Score: 100
Status: offline
I then cut the elevator away from the H stab, and rounded the elev LE the same way I did the other edges.
I want to minimize the gap between the elevator & H stab, so in order to do that, I needed to make the TE of the H stab concave.
Another tool was needed, and this time a pencil & piece of sticky sandpaper was used.
Click for fullsize
Hide Signatures
       Post #: 15
RE: Sheber Pitts S1S build - 9/23/2012 3:27 PM
SplinteredProp
Score: 100
Status: offline
The finished result.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: Sheber Pitts S1S build - 9/23/2012 3:33 PM
SplinteredProp
Score: 100
Status: offline
I would love to hinge this thing before covering, but I am unsure how I would do that....any tips would be greatly appreciated...
Hide Signatures
       Post #: 17
RE: Sheber Pitts S1S build - 10/9/2012 7:51 PM
acerc
Score: 221
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXES25&P=7   Might be helpfull
Robert
Hide Signatures
       Post #: 18
RE: Sheber Pitts S1S build - 10/11/2012 3:49 PM
SplinteredProp
Score: 100
Status: offline
Well, after a shop disaster which resulted in the destruction of the stab & elevator, I had to start from scratch & rebuild.
I took this opportunity to make some changes to the stab/elev.  In my opinion they are improvements - things that I thought of after building the first stab/elev.
Pic 1 shows the new stab/elev.
Pic 2 shows 1/16" plywood inlays at the points where the flying wires will be attached.  These should make a more stable area of attachement.
Pic 3 shows how I reinforced the leading edge of the stab with plywood gussets.  I figured this couldn't hurt since this is one of the areas where the airplane is held during engine run-ups.
I also doubled up the balsa on the trailing edge of the stab & leading edge of the elevators to provide strength & a better gluing rea for the hinges.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 19
RE: Sheber Pitts S1S build - 10/14/2012 3:28 AM
R/C Art
Score: 100
Status: offline
quote:
ORIGINAL: acerc
I also have the same items but don't know when I will ever get to the actual build. I am subscribed, too.
Hide Signatures
(in reply to acerc)
       Post #: 20
RE: Sheber Pitts S1S build - 10/14/2012 2:21 PM
acerc
Score: 221
Status: offline
SP did you give the above link a look in regard's to the hinging?
Robert
Hide Signatures
(in reply to R/C Art)
       Post #: 21
RE: Sheber Pitts S1S build - 10/14/2012 2:50 PM
R/C Art
Score: 100
Status: offline
quote:
ORIGINAL: SplinteredProp
Pic 2: I drilled 1'' dia holes through the template while they were still screwed together - these will provide places for clamping. I then seperated the 2 template halves, placed packaging tape around the perimeter and screwed then to my workbench.
I have laminated outlines on several projects over the years but never thought about drilling holes around the perimeter and using clamps. Sheer GENIUS! I will use this technique in the future for sure. (I have sent you a PM)
Hide Signatures
       Post #: 22
RE: Sheber Pitts S1S build - 10/15/2012 11:12 AM
SplinteredProp
Score: 100
Status: offline
quote:
ORIGINAL: acerc
Yes I did, thanks for the link.   The hinge pockets are worth considering, but I'm not sure I'm going to go that route.
Hide Signatures
(in reply to acerc)
       Post #: 23
RE: Sheber Pitts S1S build - 10/15/2012 11:14 AM
SplinteredProp
Score: 100
Status: offline
quote:
ORIGINAL: R/C Art
I can't take credit for being a genius.  I've seen that method on this site and copied it.  But it is a forehead-slapping type of an idea...
Hide Signatures
       Post #: 24
RE: Sheber Pitts S1S build - 10/15/2012 3:38 PM
SplinteredProp
Score: 100
Status: offline
Well, didn't get too much done this weekend, as I chose to spend a lot of time flying instead
I did work on the upper wing ribs, and in studying the plans, I really didn't like the spar arrangement as shown.  In Pic 1, you can see where the main spars (1) are shown as 1/4" x 1/4" balsa, and not located at the thickest part of the rib.
I chose to add  3/8" x 1/4" basswood main spars as shown on my rib template in Pic 2 (1).  A also decided to use 2 1/4" x 1/4" TE spars in lieu of the 1/4" x 1/2" spar drawn on the detail (2).  I wasn't confident that I could cut accurate rectangular holes in the ribs.
I spray-glued the modified detail onto 1/8" plywood, and cut on the bandsaw.  I then glued sandpaper onto the backside of the template to prevent it from moving while cutting the ribs.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
