RE: Sheber Pitts S1S build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Sheber Pitts S1S build
Page: <<   < prev  1 [2]
Login
RE: Sheber Pitts S1S build - 10/15/2012 3:40 PM
SplinteredProp
Score: 100
Last Login: 6/12/2013
Status: offline
The rest of the time was spend cutting the ribs from 1/8" balsa, and starting dry-fitting.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SplinteredProp)
       Post #: 26
RE: Sheber Pitts S1S build - 10/15/2012 4:33 PM
acerc
Score: 221
Last Login: 6/18/2013
Status: online
That sure does remind me of why I like magnet's. No glue needed untill all part's have been fitted.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 27
RE: Sheber Pitts S1S build - 10/15/2012 6:05 PM
SplinteredProp
Score: 100
Status: offline
quote:
ORIGINAL: acerc
To each their own.
Hide Signatures
(in reply to acerc)
       Post #: 28
RE: Sheber Pitts S1S build - 10/15/2012 8:42 PM
acerc
Score: 221
Status: online
Was just an observation of difference in technique, sorry. Will not make any other such comment's again. Fine workmanship going on here and I'm taking note's. On my collection toward's the pitt's I have added the reciever, batteries, power switch, servo's and a really sweet tailwheel.
Robert
Hide Signatures
       Post #: 29
RE: Sheber Pitts S1S build - 10/15/2012 10:50 PM
SplinteredProp
Score: 100
Status: offline
quote:
ORIGINAL: acerc
You can make any comments you would like - I certainly didn't mean anything by mine.  I just prefer using pins.
Thank you for the workmanship comment - I try to make everything as accurate & neat as possible, usually at the expense of time.  I'm predicting that this one will take me close to a year to complete.
Hide Signatures
(in reply to acerc)
       Post #: 30
RE: Sheber Pitts S1S build - 10/15/2012 11:22 PM
acerc
Score: 221
Status: online
Great then were all good. I thought I may have offendedyou. I try to build the same way. The only time restraint I have is, uh hmm, the end before I'm done. One year to build a masterpiece is doing quite well.
Are you doing all the bell's and whistles?
Robert
Hide Signatures
       Post #: 31
RE: Sheber Pitts S1S build - 11/2/2012 12:19 AM
acerc
Score: 221
Status: online
Getting closer. Placed an order with BUSA today for all the wood and then some. Can't ever have too much. Now to decide what color scheme. Hopefully I'll decide before I'm ready to order paint.
I think I have narrowed it down to the following three. Really leaning toward's the Marlboro one just to be a bit provocative.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by acerc -- 11/2/2012 7:23 PM >
Robert
Hide Signatures
(in reply to acerc)
       Post #: 32
RE: Sheber Pitts S1S build - 11/2/2012 4:21 PM
SplinteredProp
Score: 100
Status: offline
quote:
ORIGINAL: acerc
I think I have narrowed it down to the following three. Really leaning toward's the Marlboro one just to be a bit provakitive.
I really like the black...I was going to go with the traditional red/white scheme, but after seeing the black....hmmm....
Good call on BUSA.  I ordered my wood from Lone Star, and I couldn't have been more disappointed.
Hide Signatures
(in reply to acerc)
       Post #: 33
RE: Sheber Pitts S1S build - 11/2/2012 4:31 PM
SplinteredProp
Score: 100
Status: offline
Well, I haven't posted in a while, but I have managed to get some things done.
The top wing is getting close, but the plans really made me scratch my head a few times.  There is, in my opinion, not enough "meat" shown in the center section of the wing, so I made a piece of 1/8" plywood to span 4 ribs rather than just spanning 2 as shown on the plans (pic 2).
There are also plywood braces epoxied to the main spars on the side of the wing not shown.
The trailing edge, as shown on the plans, is a solid piece of balsa with dadoes cut in to accept the ends of the ribs (pic 3).  This method was a real pain, considereing I had to rough cut each side of the TE to get the approximate shape, then sand sand sand until the final shape was achieved.  For the bottom wing, I may consider extending the TE of the ribs and eliminate the solid piece.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 34
RE: Sheber Pitts S1S build - 11/2/2012 4:33 PM
SplinteredProp
Score: 100
Status: offline
These pics show the aileron bay and wing tip.   No real challenges with either of these.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 35
RE: Sheber Pitts S1S build - 11/2/2012 4:38 PM
SplinteredProp
Score: 100
Status: offline
I've never done any metal working before, but this Pitts is going to force me to learn.  \
Pic 1 shows the top wing brackets - the were made from aluminum channel, which was easy to rough cut on the band saw and fine tune on the disc sander.
Pic 2 shows a top wing aileron control horn which was cut from .064 aluminum.  I sandwiched the aluminum between 2 pieces of 1/8" plywood, glued together with 3M 77 adhesive, and cut with a jeweler's blade on the scroll saw.  Again I fine tuned it in the disc sander.  A short soak in a bit of acetone released the plywood from the aluminum.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: Sheber Pitts S1S build - 11/2/2012 7:21 PM
acerc
Score: 221
Status: online
Very nice work. I have heard those type of complaint's about LS. I have used BUSA for years with no reason to switch. Really looking forward to my build. I'm considering taking a shortcut on the metal work and have it laser cut.
Robert
Hide Signatures
       Post #: 37
RE: Sheber Pitts S1S build - 11/24/2012 3:32 AM
acerc
Score: 221
Status: online
SP, where you been. Doing any building?  I don't know what you got in mind for flying wire's. Found this guy who will make them to scale and length.  http://www.bruntons.co.uk/
And here's one for some nice build pics.  http://www.steenaero.com/PittsS1/construction_gallery_index.cfm
Also, I will be going to the factory the first of Dec, need any particular pics?
Robert
Hide Signatures
(in reply to acerc)
       Post #: 38
RE: Sheber Pitts S1S build - 11/24/2012 11:53 PM
gordon_mcln
Score: 100
Status: offline
ACERC.
How would you go about having the metal pieces laser cut? I have a number of projects and need to figure out a way. Would you send copies of parts to a laser shop?
Let me know when you have a moment.
Gordon
Fleet Brotherhood #18
Hide Signatures
(in reply to acerc)
       Post #: 39
RE: Sheber Pitts S1S build - 11/25/2012 12:06 AM
acerc
Score: 221
Status: online
I contacted a lazer cutting shop local to me. They said it would be no problem. Just have to give them a copy off of the plans of what is to be cut. After speaking with them on cost I may not do it. They have a rather heafty set-up fee. Total for me here would be somewhere around $350-400.  Needless to say I have not made up my mind yet. I probably will go the following link route  http://www.proctor-enterprises.com/products/hardware/strut_fittings/strut_fittings1.htm. Seem's they have pretty much everything needed. But more than likely I will make all of them myself same as SP.
Robert
Hide Signatures
(in reply to gordon_mcln)
       Post #: 40
RE: Sheber Pitts S1S build - 11/26/2012 8:16 PM
john josey
Score: 110
Last Login: 6/17/2013
Status: offline
Far from telling you guys how to build, but i thought it may be worth mentioning the way i built the wings on my own pitts. I used panel pins to 'pin' the spars to the board then cut them flush with the spar using sidecutters that way you can do the spar webbing, the sheeting, cap strips, the lot, while the wing is still pinned to the board, once you have completed the wing, you simply prize the whole thing off the board. When the wing is removed it is very very stiff with very little chance of a warp at this stage.
Exellent workmanship though, truly top drawer !
Hide Signatures
(in reply to acerc)
       Post #: 41
RE: Sheber Pitts S1S build - 11/27/2012 12:25 AM
acerc
Score: 221
Status: online
Nice Pitts JJ. Is it the s1c?
Robert
Hide Signatures
(in reply to john josey)
       Post #: 42
RE: Sheber Pitts S1S build - 11/27/2012 2:52 PM
SplinteredProp
Score: 100
Status: offline
ACE - still here. just haven't been doing any building lately - been flying instead since the weather here has finally turned decent.
JJ - beautiful airplane, specs?
Hide Signatures
(in reply to acerc)
       Post #: 43
RE: Sheber Pitts S1S build - 11/27/2012 7:32 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: SplinteredProp
Thanks guys,
My own pitts is built from the Toni Clark kit and is an S1S at 1/3 scale (68") it is covered using profilm, also known as oracover including the coloured trim. It's powered by an zenoah G62 with stainless exhaust and weighs 19.5lb's including the smoke system.
I'll post a link for the Toni Clark kits as the metal brackets you guys are making are 'spookely' like the parts that came in my kit.
http://www.toni-clark.com/index_en.htm
Cheers, john
Hide Signatures
       Post #: 44
RE: Sheber Pitts S1S build - 11/27/2012 8:15 PM
acerc
Score: 221
Status: online
JJ, I just e-mailed him. Curious what a kit would cost shipped here. Depending on price might buy one for future use. Thank's for that link!
Robert
Hide Signatures
       Post #: 45
RE: Sheber Pitts S1S build - 11/27/2012 9:12 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
My pleasure.
I would think it would be quite 'pricey' to ship to the states. I'd be curious to find out how much of the hardware from the TC kit is useable for the plan build you guys are doing.
What are the main diffrences from the standard S1S to the sheber S1S ?
Hide Signatures
(in reply to acerc)
       Post #: 46
RE: Sheber Pitts S1S build - 11/27/2012 10:04 PM
acerc
Score: 221
Status: online
It is my understanding that the only difference's of the (s1s) is whom ever drew the plan's. I do know Andy Sheber's is pretty much exact to the original.  I know that because I have a set of factory plan's for the full scale. The reason I asked which version your's is, is because it does not appear to have ailerons on the top wing. The Aileron's, according to the factory, are the biggest difference between models-A,C,D,E..etc. As well as airfoil.
I got an e-mail back from Toni. The kit is $812 and shipping of $96 for a total of $908. For what is in the kit that's not bad. They are out of stock and will e-mail me when more comes in.
< Message edited by acerc -- 11/27/2012 11:56 PM >
Robert
Hide Signatures
       Post #: 47
RE: Sheber Pitts S1S build - 11/27/2012 10:34 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Ah, ok. yeah mine does have ailerons on the top wing, you can just see the horn on the right wing just behind the front cabane strut. The kit supplies the parts and materiels for the scale pushrods between the top and bottom wings, but i had just had enough by then and decided to miss them out.
It's not as expencive as i thought it would be. The only thing i can say is, if i had total loss of the aeroplane in a crash i would have another one in a heartbeat ! it flies so well, even near the stall, it just gives a gentle waggle of the wings to let you know.
Hide Signatures
(in reply to acerc)
       Post #: 48
RE: Sheber Pitts S1S build - 11/28/2012 12:12 AM
acerc
Score: 221
Status: online
Here is a link to the factories history page of the pitts. In some ways one could actually build several versions into one airframe. All  the variations of the wings are availabe for the ,original, Pitts s1 fuse.
Good reading!
http://www.steenaero.com/PittsS1/history.cfm
Robert
Hide Signatures
       Post #: 49
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
