YSDZ 160 cam bearing removal from crankcase    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YSDZ 160 cam bearing removal from crankcase
Page: [1]
Login
YSDZ 160 cam bearing removal from crankcase - 9/8/2012 2:12 AM
PeterP
Last Login: 5/17/2013
Status: offline
 I am in the middle of trying to remove a cam bearing from a DZ 160 Crankcase. Anyone got any suggestions how too! -
Hide Signatures
       Post #: 1
RE: YSDZ 160 cam bearing removal from crankcase - 9/8/2012 1:37 PM
petec
Status: offline
I would heat the case up in an oven and holding the case with a welding glove, tap it on the side on a piece of wood to get it out. I know some guys use a torch to heat the crankcase but that would be personal preference.
_____________________________
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
(in reply to PeterP)
       Post #: 2
RE: YSDZ 160 cam bearing removal from crankcase - 9/9/2012 11:16 AM
XMANS
Last Login: 5/18/2013
Status: offline
As Petec says, heating up the case normally works but sometimes it won't budge, I made up a special tool that goes into the bearing hole and I expand the end
to grip the bearing then I can pull it out of the hot crankcase.
YS Service Down Under
Hide Signatures
(in reply to petec)
       Post #: 3
RE: YSDZ 160 cam bearing removal from crankcase - 11/18/2012 9:39 AM
TVLmole
Last Login: 5/12/2013
Status: offline
Easiest way is to shave some candle wax into the bearing inner hole and tamp it in with the smooth end of a drill the same diameter as the shaft end. Keep adding wax untill full and tamp a bit harder, the bearing will be pushed out. Takes about one minute to accomplish with no mechanical damage.
Hide Signatures
(in reply to XMANS)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YSDZ 160 cam bearing removal from crankcase
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
