Rat Fink II Razor    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Rat Fink II Razor
Page: [1]
Login
Rat Fink II Razor - 9/9/2012 5:28 AM
mistycreekboats
Score: 105
Last Login: 5/25/2013
Status: offline
Here is my version of my Rat Fink ......... part II
J&G
MHZ gear box
CC 1" Pipe
Twin HOR drives with SS prop shafts
will post as I finish - just need last pieces (Cables from Thomas) to finish
many little things I'll show in a while
designed to spin smaller props
anyway u get the idea
Randy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Randy Danchuk
Misty Creek Boats Canada
Hide Signatures
       Post #: 1
RE: Rat Fink II Razor - 9/9/2012 7:46 AM
jvdd
Score: 100
Last Login: 5/24/2013
Status: online
look very nice
can't wait for the vid.
jim
Hide Signatures
(in reply to mistycreekboats)
       Post #: 2
RE: Rat Fink II Razor - 9/9/2012 8:07 AM
Justaddwata
Score: 217
Status: offline
someones been doing a whole lot of thinking and working!! Looking good Randy - be looking forward to updates on this one!
One of the better gas boat picture sites - http://imageevent.com/justaddwata
Hide Signatures
(in reply to jvdd)
       Post #: 3
RE: Rat Fink II Razor - 9/9/2012 3:12 PM
lipdaddy
Score: 100
Last Login: 5/22/2013
Status: offline
This is without a doubt one of my favorite boats! Great job.
Ryan
http://lipgensfabrication.com
Hide Signatures
(in reply to Justaddwata)
       Post #: 4
RE: Rat Fink II Razor - 9/10/2012 3:39 AM
danielplace
Score: 120
Status: offline
Gotta install a 57cc twin in front of the gear box and you'll be flying.
Really cool Randy. I love it.
Hide Signatures
(in reply to lipdaddy)
       Post #: 5
RE: Rat Fink II Razor - 9/11/2012 3:17 AM
mistycreekboats
Score: 105
Status: offline
Thanks for the compliments + Yes Daniel but the recoil would be under deck ........ maybe for part III
The Razor
  • (Rat Fink) is serial number 6
  • it is 3 colors of green on hull
    • Candy Apple Green over white base for bottom
    • Candy Apple Green over metallic for Deck
    • Key Lime Green stripe and 3M Carbon Fiber stipe
    • Cleared 2 x and RF decal added
  • Hatch is made from 1/8" Baltic Birch and is Key Lime Green and 3M CF - the alum vents on rear open and weight very little
Drives come from HOR and stainless propshafts with square inputs come from PMB in UK
Props shown are 2 from MHZ and are 'starters' Billet Alum
Wing is made from sheet CF (The real stuff) with hand made alum brackets
The struts are 4/40 threaded rod with 4/40 ball joint ends and carbon fiber rod with shrink sleeve ends over the rod .  4/40 stainless bolts
The strut is adjustable to various angles
The Rudder is a 6" Speemaster with a custom made 'control arm block' - so I can have arms both sides
No water pu on rudder comes from hull
CF Rod supports the 4/40 rods to the rudder
The inside stuff tubes are 11/32 and are epoxied and glassed in the ends are cut to clamp the 5/16
The clamps are made from McMaster Carr clamps - resized to 11/32
The gearbox is a MH$ 1572
Width: 112mm (4,4")
Height: 48mm (1,9")
Weight: 19,33 oz (548 g)
Diamter inlet shaft to motor: 7mm
Gear up: 18,5%
I added 'fill level' hose (just mocked up for now) but added vent to top
I will look at box over winter as I think its kind of heavy
I used the MHZ box because the width of the 2 out put shafts lines up with rear spacing for drives and I don't have length to play with bending tubes .  This way makes the tubes almost straight to drives
Anyways thats todays
Cheers
Randy
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Danchuk
Hide Signatures
(in reply to danielplace)
       Post #: 6
RE: Rat Fink II Razor - 9/12/2012 5:29 AM
mistycreekboats
Score: 105
Status: offline
Had some nice cable (very well done - thanks Matho) come in today so did a little more
made some 't-bars' to go with clamps for front and made clamps for rear - should work
looks kinda like this
shows somewhat why I picked the MH$ box as keeps stuff tubes pretty straight ........ works for me on short boat
Cheers
Randy
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Danchuk
Hide Signatures
       Post #: 7
RE: Rat Fink II Razor - 10/15/2012 7:28 AM
mistycreekboats
Score: 105
Status: offline
Well few pics of some work
- I'm basically cheap so make my own stuff -
the servo box is from Tom at Expresscraft (HOR) - I changed to bolts thru bottom and MHZ 4mm Blue Knurled Nuts
- Battery is seperate as tubes take up bottom
- battery box seal is hi temp silicone - used to mount gear box too
- I ran gearbox for while but still not impressed - will need to look at over winter
- I made servo plate - mini t bars and battery box
- CC 1" pipe (I rewelded  changed angle) on TIG
- Walbro 1048 - Ron Buck ss shaft and GZ cover
more to come cheers
hope to start on next weekend
Randy
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Danchuk
Hide Signatures
       Post #: 8
RE: Rat Fink II Razor - 10/15/2012 7:36 AM
mistycreekboats
Score: 105
Status: offline
couple more pictures
ps
Daniel I need me one of them Daniel Place "Killer SX Motors"
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Danchuk
Hide Signatures
       Post #: 9
RE: Rat Fink II Razor - 10/24/2012 2:56 AM
mistycreekboats
Score: 105
Status: offline
couple pictures and Yep it run's
http://youtu.be/mok6Qtgl9Gw
TY
Stock Zen for now - running out of time before ''hard water ''
RD
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Danchuk
Hide Signatures
       Post #: 10
RE: Rat Fink II Razor - 10/25/2012 6:20 AM
mistycreekboats
Score: 105
Status: offline
Well it floats - was very late and dark already. Split fuel line so ended after one trial run
It's a start anyways
D-m dog wouldn't stop barking sorry for sound
http://youtu.be/Wv2ygCGRB8Q
Randy Danchuk
Hide Signatures
       Post #: 11
RE: Rat Fink II Razor - 10/26/2012 6:42 PM
crrcboatz
Score: 100
Last Login: 2/27/2013
Status: offline
Was that full throttle?
"For those who have fought for it, life has a flavor the protected will never know" Vietnam, 1st Infantry Division 1969
Hide Signatures
       Post #: 12
RE: Rat Fink II Razor - 10/26/2012 6:54 PM
mistycreekboats
Score: 105
Status: offline
No
Just  under 13000 rpm (SenDec tach)  and small 62 mm 2 blades and stock from the box Zen 26
 I discovered a split in fuel line after filled it two times  - boat was full of alot of gas (I have a cold and couldn't smell all the gas leaking seen puddle inside and wondered where water came from .. it was gas)  ....  explains why it wouldn't rev up
I ported a V2 J&G last couple night so I will try Saturday (already freezing and snow here so will be last time I'm sure)
Will try to pound it a little if I get to run .......... Might need snow shoes ........... LOl
Later Curt
Randy
Randy Danchuk
Hide Signatures
(in reply to crrcboatz)
       Post #: 13
RE: Rat Fink II Razor - 10/26/2012 7:00 PM
crrcboatz
Score: 100
Status: offline
Hey good Randy. That thing is one of my favorite builds EVER to keep up on. U have done a super jog as always. A JG should get it done with 2 props. Is the dual drive a gear up unit? By that I mean say a ratio of 1/1.25 or is it 1/1? Where did u find the drive unit? Like to try that myself on a larger boat.
Hide Signatures
       Post #: 14
RE: Rat Fink II Razor - 10/26/2012 7:32 PM
mistycreekboats
Score: 105
Status: offline
Curt
 18% overdriven - running through set 62 mm ..... I have 3 sets of small 2 blades and two sets of small 3 blades to try - idea is to try to spin two smaller props at higher rpm
 so if I can get say 18 or 17, 500 from engine  then I get around 21, 000 at props ....... Well see how she goes I need to play with gear box and change to some ceramic sealed bearings (to cut leaks out) and need to machine some excess weight out of the box.
Later Bud
Randy
the gearbox
http://shop.mhz-powerboats.com/IC-Engines/Gear-Box/Gear-Box-with-Square-Shaft.html
Randy Danchuk
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
