RE: Question for the Experts...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: Question for the Experts...
Page: <<   < prev  1 [2]
Login
RE: Question for the Experts... - 9/20/2012 7:45 PM
1QwkSport2.5r
Score: 155
Last Login: 6/20/2013
Status: offline
quote:
ORIGINAL: Nitrovein
quote:
ORIGINAL: supertib
On some engines the timing change is very small, not much more then shaving the chrome layer out of the port.... which can be extremely difficult to do...it is very easy to make a large change in timing, but extremely difficult to make a small change to a individual port
+1
Just cleaning up the ports can change the timing to where the sleeve needs to be brought down again.
Diamond needle files is all that I use In the ports as you control every stroke and have better control over the work that way. It´s always easier to remove material, than it is to put it back...
Dremel is for the crude work.
Understood, and agreed. When it comes to our small engines, a little bit goes a LONG way.
Be it known, I dont have much intention of modifying the engine physically, but moreso determine what pipe will work best with the timing the engine has from the factory. A carb and pipe swap can have more impact than adjusting the actual timing of the ports unless the timing is so low that it needs more to operate better. I wanted to know what the ideal timing is for a car engine for comparison purposes only.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Nitrovein)
       Post #: 26
RE: Question for the Experts... - 9/20/2012 10:13 PM
supertib
Score: 302
Last Login: 6/19/2013
Status: offline
I use several small hand pieces as well as a lathe and a mill
I use this hand piece to cut ports, then I finish with a fine diamond file...this tool cuts very clean and can take very shallow cuts much straighter then can be done with most tools...100 000 RPM means very clean cuts, but must be extremely careful, this tool can chew thru a sleeve like nothing.....
I use this lathe to cut buttons,pistons and sleeves
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 27
RE: Question for the Experts... - 9/20/2012 10:39 PM
Nitrovein
Score: 100
Status: offline
Now that´s a long way from a Dremel! Very, very cool!
Hide Signatures
(in reply to supertib)
       Post #: 28
RE: Question for the Experts... - 9/20/2012 11:03 PM
supertib
Score: 302
Status: offline
I also one of these
http://www.foredom.net/k1050-2.aspx
and one of these
http://www.foredom.net/msrbsct.aspx
Hide Signatures
       Post #: 29
RE: Question for the Experts... - 9/20/2012 11:21 PM
1QwkSport2.5r
Score: 155
Status: offline
Enough of the tooling braggery. Let stick to the topic please.
What is your all-time favorite pipe for a high timed 3-port 3cc smallblock, Neal?
Hide Signatures
       Post #: 30
RE: Question for the Experts... - 9/20/2012 11:30 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
I really don't run smallblocks........I use a JP5 on my CRT .5 but that is about the extent of it for me... I pretty much strictly run .21 or larger,,, tho I am doing a few 18TZ for 1/8 Buggy racing on smaller tracks..........Believe it or not, but on the 18TZ in a TK3 buggy the Werks 2058 works very well...
Hide Signatures
       Post #: 31
RE: Question for the Experts... - 9/21/2012 6:46 PM
Anthoop
Score: 121
Status: offline
I thought the topic was something else then? Remind me what you are asking?
Maybe better to ask if anyone has an opinion on how your specific engine will run best for your intention...what engine is it?
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
       Post #: 32
RE: Question for the Experts... - 9/21/2012 7:57 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Anthoop
Ultimately, the idea is being to better match a pipe to an engine based on the exhaust timing. Through the process, other thoughts and questions arose. I won't specify the engine or the model it's in because I'm not going to be crucified for my choices. There are too many fanboys here that are dead set on this engine or this pipe and anything else is garbage. Seen it happen too many times.
I know what engines are good and I know several that aren't so good. I'm not well schooled on pipes because it seems there are more pipe options than engine options. Ultimately, I want a pipe with enough adjustability to be used on more than one engine. No two engines are timed the same and as such have different pipe requirements. I don't believe there is any one pipe that is perfectly matched to any two different engines.
Hide Signatures
(in reply to Anthoop)
       Post #: 33
RE: Question for the Experts... - 9/21/2012 10:00 PM
Nitrovein
Score: 100
Status: offline
If you want an "easy to use tool", this might help you on the way: http://mh-aerotools.de/airfoils/javapipe_de.htm
But you still need to find a pipe, if you can´t make your own.
My best recommendation is to read Gordon Jennings book, that will give you a good starting point.
Hide Signatures
       Post #: 34
RE: Question for the Experts... - 9/22/2012 2:21 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Nitrovein
If you want an ''easy to use tool'', this might help you on the way: http://mh-aerotools.de/airfoils/javapipe_de.htm
I will locate a copy, and read it. Thanks.
edit: Found a copy online here: http://www.datafan.com/Horsepower_Blog/gordon-jennings-two-stroke-tuners-handbook/
Hide Signatures
       Post #: 35
RE: Question for the Experts... - 9/22/2012 2:26 PM
Nitrovein
Score: 100
Status: offline
quote:
ORIGINAL: Nitrovein
Here you go: http://edj.net/2stroke/jennings/
But as I said, it´s a starting point.
Hide Signatures
       Post #: 36
RE: Question for the Experts... - 9/22/2012 7:53 PM
Anthoop
Score: 121
Status: offline
The most frustrating thing is that even if you work out what pipe you actually need, finding pipe dimensions online is like finding a needle in a haystack.
Who cares what people think of the engines you use/enjoy?
Nice bit of light reading in those links for you...have fun.
Hide Signatures
       Post #: 37
RE: Question for the Experts... - 9/22/2012 8:02 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Anthoop
The fanboys lurk everywhere. The car/truck forums has some of the most judgmental users of this forum, bar-none. The course of the thread went better than I expected though.
I have the information I needed/wanted, so now its time to do some homework.
Thanks guys.
Hide Signatures
       Post #: 38
RE: Question for the Experts... - 11/18/2012 12:37 AM
Dodge1997
Score: 100
Last Login: 11/18/2012
Status: offline
Hello, I have a revo 3.3 with a picco .26 max mototr in it. I was driving it just fine yesterday, went to start it today, and the motor will not turn over.... And I have no clue what to do. It has the roto start on it and it broke the wand.. Can anyone tell me what is wrong??? Thank you!!!
Hide Signatures
       Post #: 39
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
