Tiger pulls to the right    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Tiger pulls to the right
Page: [1]
Login
Tiger pulls to the right - 9/9/2012 11:44 PM
kev308
Score: 100
Last Login: 5/19/2013
Status: online
Hi All, What would cause my Tiger to suddenly start pulling to the right? I just finished painting (my first attempt at painting and decals) Got it all back together and it pulls to the right while moving. I have it trimmed properly as far as I can tell, I counted the treads and both sides has the same amount. Any ideas?
Thanks, Kevin
Hide Signatures
       Post #: 1
RE: Tiger pulls to the right - 9/10/2012 12:10 AM
bowlman
Score: 104
Last Login: 5/20/2013
Status: offline
If this is a Tamiya Tiger put it on a block of wood that will raise the tracks off the ground then start it and see if one track moves faster then the other if so you will need to adjust the rud screw on DMD .
Jimmy
Hide Signatures
(in reply to kev308)
       Post #: 2
RE: Tiger pulls to the right - 9/10/2012 12:59 AM
kev308
Score: 100
Status: online
I should clarify, this is a Heng Long Tiger
I put it up on a block and ran it. It looks like if I try to run the motor slow the left tread runs faster. At mid speed they both seem to be running together. I played with the trim on the transmitter, I have that set where I think it's optimum.
< Message edited by kev308 -- 9/10/2012 3:37 AM >
Hide Signatures
       Post #: 3
RE: Tiger pulls to the right - 9/10/2012 2:04 PM
mustclime
Score: 106
Status: offline
Try the trim tabs next to the toggles on your hand set....move the one under the drive toggle to the left, see how that works.
_____________________________
That which does not destroy me just makes me more irritable
Hide Signatures
       Post #: 4
RE: Tiger pulls to the right - 9/10/2012 2:10 PM
mustclime
Score: 106
Status: offline
Btw, NEAD is having a battle this weekend in northern NJ a little more than a hour from you, you should show up.
scott
Hide Signatures
       Post #: 5
RE: Tiger pulls to the right - 9/10/2012 8:49 PM
kev308
Score: 100
Status: online
Scott, I fully intend to be there Sunday. Can't wait.      I set the trim under the toggle, it still seems to pull to the right, I'm constantly correctly to the left.
Looking forward to meeting you all Sunday, has the location been determined yet?
This is my first attempt at painting and all, I haven't touched a model in over 40 years.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to mustclime)
       Post #: 6
RE: Tiger pulls to the right - 9/10/2012 9:11 PM
mustclime
Score: 106
Status: offline
Looks great...another option is you have more links in the tracks on one side than the other...I would pull the tracks and count them, then roll all the wheels and see if any are binding....
I think we are doing it at the crusing rc location, I am waiting for thecommander to finalize the location....if it cruzing, iwill be out there with the mower to close cut the grass....
I might bring the E100 that I started this weekend just for laughs....the thing is huge...
Hide Signatures
       Post #: 7
RE: Tiger pulls to the right - 9/10/2012 9:16 PM
tisaksen
Score: 100
Last Login: 2/25/2013
Status: offline
I have the same issue on my jagdpanther, one motor  seems to be moving a lot faster than the other
Hide Signatures
       Post #: 8
RE: Tiger pulls to the right - 9/10/2012 9:51 PM
B.A.D.A.S.S.Force
Score: 103
Status: offline
mustclime, he did mention that he counted the links already & they were even on both sides, though checking for any binding wheels should still be done.
quote:
ORIGINAL: tisaksen
I can see that happening, & if it's too severe a difference which the trim can't compensate for the drifting, then what did you do, get new motors?
kev308, does it drift at all speeds, or only when full speed? Just grasping here, but could it also be that the controller is allowing less voltage out on just one side?
Also, one other thing maybe worth a mention, that I believe could cause this effect, is if there are any worn gears on a gearbox that don't catch fully at all times. If that is the case, it would be getting pushed in that direction by the gearbox with all good gears. So check all the gears on the side the tank is drifting towards, for any worn gear teeth too.
~ Craig ~
(¯`·._.·´¯`·._ ★ B.A.D.A.S.S. F⊙rce Club F☮under ★ _.·´¯`·._.·´¯)
Hide Signatures
(in reply to tisaksen)
       Post #: 9
RE: Tiger pulls to the right - 9/10/2012 9:58 PM
kev308
Score: 100
Status: online
I counted the links, but will do so again, to make sure they are correct. I will also give it a longer run thru when I get the chance, hopefully tomorrow after work. I noticed that while painting I rotated the drive wheels and it felt like the right wheel would stick every now and then it was more difficult to turn than the other side.
Thanks, Kevin
Hide Signatures
(in reply to B.A.D.A.S.S.Force)
       Post #: 10
RE: Tiger pulls to the right - 9/10/2012 10:01 PM
George Jure
Score: 100
Status: offline
Hello
Sounds like paint has gotton into places where it does not belong. Might have to check and clean the wheel shafts of paint and relub.
George
Hide Signatures
       Post #: 11
RE: Tiger pulls to the right - 9/10/2012 10:19 PM
DirtyBird69
Score: 123
Last Login: 5/17/2013
Status: offline
Have you tried "stretching" the tracks a bit?.....You could have some links binding(I always seem to find some)...While your at it also check all the links to see if all the sprocket holes are clear of any excess casting....
Hide Signatures
(in reply to George Jure)
       Post #: 12
RE: Tiger pulls to the right - 9/11/2012 9:16 AM
tisaksen
Score: 100
Status: offline
First I changes the gears because the plastic ones were broken. I have 3:1 brass gears which I hate because they are too soft. I'm thinking maybe this is the issue that one or more of the gears are bent but I haven't been able to figure out which one(s), if any, yet.
I also have new motors so I guess that might have something to do with it too. .I'll have to meassure the voltage to make sure the soldering doesn't suck
Hide Signatures
       Post #: 13
RE: Tiger pulls to the right - 9/12/2012 4:12 AM
kev308
Score: 100
Status: online
Ok so I counted the treads (3x just to be sure ) And  I don't see any binding. However when I put the tank on a block, it looks like the right track hangs lower than the left. As far as I know there's no way to adjust that on an HL tank?
Thanks, Kevin
Hide Signatures
       Post #: 14
RE: Tiger pulls to the right - 9/12/2012 1:59 PM
mustclime
Score: 106
Status: offline
This is a stock hl tiger with new gear boxes and no tensioners? If that is correct , check the gear box alinment, if on track is hanging lower than another and the links are the same on both sides, you might have a gear box angled forward or back and this could be causing the bunding or ristance. you should be able to lay a strait edge across the gear boxes and have both axils line up.......just a guess without seeing the tank...
Hide Signatures
       Post #: 15
RE: Tiger pulls to the right - 9/13/2012 8:44 PM
kev308
Score: 100
Status: online
Ok so last nite, I put her up on a block and ran the motor and fiddled with both trim toggles. Very interesting! But after a few minutes of this and that I think I got it squared away. A quick road test today after work and she seems to be running true.
Looking at it on the block, and the right track hangs lower than the left one. I guess the motors musr be out of alignment?  After Sunday I'm going to pull it apart again (that in itself is a pain)
and I'll see what's what.
Kevin
Hide Signatures
       Post #: 16
RE: Tiger pulls to the right - 9/13/2012 11:40 PM
DirtyBird69
Score: 123
Status: offline
You should really invest the $50 in a tensioner...they're worth every cent!
http://rctankwars.com/products.asp
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
