Moki blend: what is yours?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Moki blend: what is yours?
Page: [1]
Login
Moki blend: what is yours? - 9/9/2003 5:58:52 AM
rctimm99
Status: offline
I am looking for a Moki blend. I am new to this engine and not sure what ratios they like. Any tips this home mix?
Thanks!!!
Tim
< Message edited by rctimm99 -- 9/9/2003 5:59:36 AM >
       Post #: 1
RE: Moki blend: what is yours? - 9/9/2003 6:44:29 AM
Shortman
Status: offline
I use a homebrew such as your wanting and it works great.
Its pure Methanol which I pick up at the local Go-Kart shop for $3.95 a gallon. I then buy a few quarts of Blenzol Green 50/50 Synthetic Castor blend.
I use an 18% oil blend into 1 gallon of fuel.
There are 144 ounces of fuel if I am not mistaken. If you do the math I BELIEVE it comes out to 23 ounces of oil per gallon. I shake it up really hard and stir too to make sure that its mixed well. I store it in my garage and try to keep it out of the sun just because.
I will find the sheet I made and post tommorow when I have some time, Steven.
_____________________________
Steven Carroll
AMA# 738035
(in reply to rctimm99)
       Post #: 2
RE: Moki blend: what is yours? - 9/13/2003 4:44:56 PM
CurtD
Status: offline
128 oz. per gal but the 23 oz of oil is correct for 18%. I'm running Omega 5% with 3 oz. per gallon castor added. My Moki 2.10 loves it. After I use up the six gallons I have, I'll probably be going to home brew too, although I can get Omega FAI fuel for not all that much more than what it'll cost me to mix it myself.
(in reply to Shortman)
       Post #: 3
RE: Moki blend: what is yours? - 9/13/2003 8:32:36 PM
rctimm99
Status: offline
what I have been reading says these engines love 20% castor and 80% Methanol...
I have to wonder if:
1. adding acetone would help idle
2. a squirt of amorall for goog luck would give good luck (not sure why folks do this one ;-)
so is it castor or a castor /syn blend? How about any acetone? I KNOW there are brewmasters out there who have some opionons ... pls do share. The Moki is really impressing me :-)
what do you guys think?
(in reply to CurtD)
       Post #: 4
RE: Moki blend: what is yours? - 9/13/2003 10:09:20 PM
Hobbsy
Status: offline
I have always run my Moki .61 LS on Fox 5% with 20% 50/50 lube and it thrives on it.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 5
RE: Moki blend: what is yours? - 9/13/2003 11:44:26 PM
rctimm99
Status: offline
sweet engine.... I had this one and the 51 (or 56???) .... very nice motors way ahead of their time...
(in reply to Hobbsy)
       Post #: 6
RE: Moki blend: what is yours? - 9/21/2003 2:36:25 PM
mutare23
Status: offline
I have a Moki 1.80 that I have flogged the guts out of for 8 years running with 20% Coolpower and 10% nitro.
I know others will say that you dont need the nitro and could even be detrimental to the engines life span.
The engine is a power house and has never missed a beat turning a Bolly 18x10 with the Bolly EQ 3000 pipe.
Cheers
Phil
       Post #: 7
RE: Moki blend: what is yours? - 9/22/2003 6:04:42 AM
Warren
Status: offline
The old squirt of Armor All trick is to keep the fuel from foaming; works wonders.
Moki's also run great on 12% oil contrary to popular belief; and you'll get another 300 or so RPM.
I know at least 3 people that run 0% nitro and 10% full synthetic oil on the 2.10 and they have 100's flights on them with no problems.
Being that the big Supertigre and OS motors advertise low oil contents; I am not sure why the Moki needs anywhere near 20% oil.
Warren
       Post #: 8
RE: Moki blend: what is yours? - 9/22/2003 7:25:52 AM
mutare23
Status: offline
Warren
I've heard many stories about lower oil contents and no doubt it works for some. However, I have also seen fried engines where people have tried to use low oil contents and I really wonder why. Is there flying going to notice the small percentage gain in performance?
I know their hip pocket will notice if they fry the engine.
I dont claim that my idea is the best, but I know the engine is still going like a train after many long hours of work.
Cheers
Phil
       Post #: 9
RE: Moki blend: what is yours? - 9/23/2003 5:29:12 AM
Warren
Status: offline
Hey Phil,
I think they gravitate toward a less mess and lower cost per gallon: these a 3-4 gallon per weekend IMAC guys.
Warren
(in reply to mutare23)
       Post #: 10
RE: Moki blend: what is yours? - 9/23/2003 9:12:12 AM
mutare23
Status: offline
G'day Warren
Understand your point and certainly know the cost of fuel is a consideration, but I would rather be flying than replacing engines and the little extra fuel cost could be viewed as something like an insurance policy.
Cheers
Phil
       Post #: 11
RE: Moki blend: what is yours? - 10/2/2003 7:18:40 PM
michpittsman
Status: offline
When in doubt, follow the recommendations of the mfg/distributor! Gerard (the Moki importer) calls for SOME castor oil and very little nitro. I have used Mach7, 5% nitro with half-and-half castor/synthetic with great results. You can also get this with all castor or 25% castor direct from Morgan Fuels. Buying three cases at a time, I pay $11.00 per gallon, including UPS AND hazmat. To me, it"s not worth the time and trouble to buy everything separately and mix my own. I also run my 2.10 through 3/32 fuel line while some other fuels require 1/8 line. This tells me I am getting better fuel economy than they are. Also note that when you buy nitro, by law it cannot be 100% pure for safety reasons. An old boat racer buddy used to buy a barrel(!) of 50% nitro/50%alcohol and add castor oil to make 35% racing fuel. It worked fine.
< Message edited by michpittsman -- 10/2/2003 7:34:45 PM >
       Post #: 12
RE: Moki blend: what is yours? - 7/8/2004 9:46:35 AM
Vortec
Status: offline
Hi guys,
I've just bought my first Moki( )1.80,and would like to know if 5%castor and 15%syn with 5%nitro will hurt this? As this is all i buy for all my smaller planes but i might have to resort to making my own fuel if they suck as much fuel as ppl say.
I've been told that i can order the same fuel in at 10/10 mix with no nitro if i want.Id like to have some syn oil for the clean burning it has,I've run a 46 with just castor and it is a pain getting the sludge off at the end of the day.
(in reply to michpittsman)
       Post #: 13
RE: Moki blend: what is yours? - 7/12/2004 2:12:49 AM
mutare23
Status: offline
Vortec
Apologies for the late reply, but I have been away for a ocuple of weeks.
The fuel you want to use will keep your Moki more than happy.
Cheers
Phil
(in reply to Vortec)
       Post #: 14
RE: Moki blend: what is yours? - 7/12/2004 7:40:33 AM
Vortec
Status: offline
Thanks Phil..
I'll be running it on 10/10 mix i think.I dont realy see the need for nitro in this motor, as a fellow flyer(also Phil)has a 1.8 in a high wing glider tug and it has oodles of power and a very low idle,he even has trouble stoping it.
I cant wait to fit it in its plane and try it out.
       Post #: 15
RE: Moki blend: what is yours? - 7/12/2004 7:45:32 AM
mutare23
Status: offline
Vortec.
Half half is fine.
I always use a little nitro just to help with idle etc, but I'm in Canberra so elevation is 688 meters.
I know you will enjoy the Moki. I now have 4 and each one strong yet docile handling
Cheers
Phil
       Post #: 16
RE: Moki blend: what is yours? - 7/4/2005 11:19:51 PM
