I noticed a year ago that the RC IR battlers were wondering what to do if someone came out with a E-100 or Maus. The things had 6-8 inch front armor, 5-6 inch side armor.....How any Hits to kill somethng like that? Well the release of the E-100 and Maus never happened....So I decided to look into putting one of them togather just for the heck of it.....and along came Ludwig.... http://www.ludwigs-hobby-seite.de/flohmarkt.html And that made me start to look into it more, then he had this thread.... http://www.rctankwarfare.co.uk/forums/viewtopic.php?f=23&t=9390 And he was posting pics of scale thinkness armor! I sugested he look into making one that used Heng Long suspension to make the build easier....he said OK and I said sold.....this will be HACKS atempt at building an E-100..... First issue in any tank build is tracks, wheels and suspension. You figure out these and the rest is easy. Since the E-100 is using a king tiger for a base, how are they different in size in these items? Item....................king tiger..................E100 tracks..................800mm.....................1000mm road wheels............800mm.....................900mmthis was the Adler built prototype, not the Krupp drawings number of road wheels..18........................16 ### Hack tip.....use mm to convert to scale.....just take the item you want to convert and devide by 16.....1000mm track = 62.5mm in scale, 800mm track = 50mm in scale.......I used to do this in inches....like I said, I am a hack. First Issue, the tracks...the hl king tiger has 50mm wide tracks, the E-100 should have 62.5mm tracks.....I understand that some compeny is comming out with some 1/16 scale e-100 tracks but the cost is going to be around 1200 euros, I spend that much on a set of tracks, I need a part time job to cover the cost...so lets see If I can make some..... here is a pic of the tracks Here are the track on the tank in the UK for testing.... Here is a pic of some 1:35 scale track made for the E-100 IMO, the E100 tracks look like king tiger tracks that have been centered and has duck bills added....here are some matero and heng long tracks, note that they are open pin also note the hl tracks on the bottom have the teeth holes a little closer togather and the non holed links have more closed sections than the matero's... Now to make them wider....cut them at the outer teeth holes and add the extra peaces for width and you get 60mm wide tracks and glue with some PVC solvent/glue and cut off some teeth from the other track peaces and you have 63mm wide tracks now to see If I can find 6 sets of hl king tiger tracks....
< Message edited by mustclime -- 9/11/2012 3:53 PM >
_____________________________
That which does not destroy me just makes me more irritable
Hide Signatures
