Violent dive on rudder right - Fly Baby    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> Violent dive on rudder right - Fly Baby
Page: [1]
Login
Violent dive on rudder right - Fly Baby - 9/12/2012 6:10 PM
Winrich
Score: 100
Last Login: 1/6/2013
Status: offline
Hi guys,
We are running out of ideas how to correct some very strange behavior of a 1.20 size Fly Baby ARF. When applying right rudder (without any aileron input), the plane has not the slightest tendency to turn right but immediatiatly goes into a dive. The more rudder the more violent the dive. The response to rudder left is reasonably well although the plane needs some more than typical elevator to compensate for a notworthy dive tendency. This behavior is more or less the same at any throttle position. The CG is according to plan. We checked that there is no mixer active. There is no unreasonable slop in the rudder train and a powerful rudder servo is installed.
Any suggestions what's wrong?
Thank you and best regards
Winrich
Hide Signatures
       Post #: 1
RE: Violent dive on rudder right - Fly Baby - 9/12/2012 8:12 PM
opjose
Score: 280
Last Login: 5/24/2013
Status: offline
This sounds like torque induced gyroscopic precession to me.
Try flying the plane up to full throttle and as it is flying level throttle it back to idle then see how it responds to rudder inputs with the engine at idle.
_____________________________
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to Winrich)
       Post #: 2
RE: Violent dive on rudder right - Fly Baby - 9/12/2012 8:51 PM
rmh
Score: 252
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: Winrich
Hi guys,
Winrich
Sounds like basic trim is not correct - for example left trim is countering aileron setup
which produces aright turn
and /or it is quite nose heavy.
Libby is still watching you
Hide Signatures
       Post #: 3
RE: Violent dive on rudder right - Fly Baby - 9/22/2012 1:37 AM
mithrandir
Score: 110
Last Login: 5/10/2013
Status: offline
Right rudder causes a dive??
Is the elevator control horn on the left side? check the stiffness of the elevators... is the right one floppy?
LOOKING FOR ENGINEERING WORK ON UAV''S?
http://search9.smartsearchonline.com/asi/jobs/adhocjobsearch.asp
Hide Signatures
(in reply to rmh)
       Post #: 4
RE: Violent dive on rudder right - Fly Baby - 9/22/2012 2:00 PM
RCPAUL
Score: 122
Status: offline
HOW MUCH DIHEDRAL?
Gosh, model airplanes are not a matter of life and death - they''''''''re more important than that!
Hide Signatures
(in reply to mithrandir)
       Post #: 5
RE: Violent dive on rudder right - Fly Baby - 9/24/2012 9:07 PM
BMatthews
Score: 247
Last Login: 5/23/2013
Status: offline
As you're seeing there is simply no aerodynamics reason for this to occur. It's far more likely that you've got some sort of bad wing warp or the wing on one side is shaped differently from the other or there is some other side to side nonsymetry issue at work. So the first step would be to measure out all the wing to fuselage alignment factors. Then check for warps and at the same time ensure that the wing is shaped and balanced symetrically from side to side.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to RCPAUL)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
