MVVS F2C Diesel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> MVVS F2C Diesel
Page: [1]
Login
MVVS F2C Diesel - 9/13/2012 7:49 AM
qazimoto
Score: 100
Last Login: 5/21/2013
Status: offline
Here's a 1974 era MVVS 2.5cc F2C motor for sale on ebay.
http://www.ebay.co.uk/itm/Vintage-Diesel-Model-Engine-MVVS-2-5-DR-A-TR-/110950921975?pt=UK_ToysGames_RadioControlled_JN&hash=item19d530b6f7
Looks very nice but nothing like any MVVS production engine I've ever seen. Drum valve as well.
Ray
Click to see fullsize image.
Click for fullsize
< Message edited by qazimoto -- 9/13/2012 11:29 AM >
Hide Signatures
       Post #: 1
RE: MVVS F2C Diesel - 9/13/2012 10:27 AM
tiffitech
Score: 110
Last Login: 5/20/2013
Status: offline
There are some parts that for sure aren't original. At first the Needle Valve, that one on the picture is coming from an old russian Glow Engine "Polet" 5,6ccm.
Never ever has MVVS made an head where the mounting holes are destroyed while machining down the diameter of the head on the lathe :-)
Rear drum induction is possible, MVVS experimented with that in the past. I do have a 2.5ccm Glow with rear induction, but no drum as far as I remember..
Regards,
Holm
< Message edited by tiffitech -- 9/13/2012 1:48 PM >
Hide Signatures
(in reply to qazimoto)
       Post #: 2
RE: MVVS F2C Diesel - 9/13/2012 10:31 AM
greggles47
Score: 100
Status: offline
Wow! that's a great looking motor!
Rear induction doesn't look standard. I'd like to hear the story about that.
G
Hide Signatures
       Post #: 3
RE: MVVS F2C Diesel - 9/13/2012 11:09 AM
qazimoto
Score: 100
Status: offline
I'd guess that it has a two part push/pull head similar to what was later done with Taipan Goldhead glows which had a similar crankcase construction.
The seller comes from Poland and has been putting up a lot of very interesting motors lately.
Ray
Hide Signatures
(in reply to greggles47)
       Post #: 4
RE: MVVS F2C Diesel - 9/13/2012 1:50 PM
tiffitech
Score: 110
Status: offline
..where on the picture you can see something that can do a "pull" on the head?
This thing is looking like a simple self made head with more cooling fins than the original Diesel Head from MVVS had.
The seller wrote something that the "Motor is tuned" in the item description.
Regards,
Holm
Hide Signatures
       Post #: 5
RE: MVVS F2C Diesel - 9/13/2012 10:07 PM
earlwb
Score: 584
Status: offline
Well, it would not surprise me to see a different needle valve on a engine. Usually one airplane crash breaks off the needle, so I can see someone replacing it. Now as to the head, yeah it does look like a custom made head. But I would suspect they turned it's diameter down more to fit a racing plane of some sort. Some of those planes have a narrow cowl with a tight fit around the engine's head.
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to tiffitech)
       Post #: 6
RE: MVVS F2C Diesel - 9/13/2012 11:46 PM
DerFly
Score: 100
Status: offline
Hi All,
Drum intake parts look to be from a Rhythm 2.5D. The needle valve also for that matter.
I wonder how it runs.
DerFly
Hide Signatures
       Post #: 7
RE: MVVS F2C Diesel - 9/14/2012 1:16 AM
qazimoto
Score: 100
Status: offline
quote:
ORIGINAL: DerFly
Hi All,
DerFly
The head is probably a home made copy of a Nelson head (six bolts rather than the four shown) from the late 1980's to 1990's. It's rather tall and is definitely two piece.
I have a Nelson diesel with that type of comp screw. I'd assumed that it's push/pull. I'll check later today and report back.
Ray
Hide Signatures
(in reply to DerFly)
       Post #: 8
RE: MVVS F2C Diesel - 9/14/2012 1:51 AM
Recycled Flyer
Score: 101
Status: offline
Are my eyes deceiving me Ray is it that backplate not screwed home for some reason?
I am sure that I can see the retaining bolts shaft between the rear cover and the crank case. Sign of a really poor fit and mix and match components?
Hide Signatures
       Post #: 9
RE: MVVS F2C Diesel - 9/14/2012 2:09 AM
qazimoto
Score: 100
Status: offline
quote:
ORIGINAL: Recycled Flyer
Yes I thought that as well.
I wonder if it has a gasket broken that side.
These unanswered questions are what make ebay auctions exciting for me.
For example these little things might be easily fixed yet put other buyers off allowing you to get a bargain.
On the otherhand if you ask he might answer online and everyone gets the information.
I'm not bidding, "I have enough engines"
Ray
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 10
RE: MVVS F2C Diesel - 9/14/2012 4:02 AM
Recycled Flyer
Score: 101
Status: offline
I note well that the ad states nowhere is this a running workable engine though as the obvious description of -
"Rear exhaust , Drum valve Nelson type head Looks as new-very clean. Strong compression New Rossi Team Racing propeller as a bonus Sell as is "
tells me little that I don't already know.
Along with Derfly I smell a rat with that different backplate.
Hide Signatures
       Post #: 11
RE: MVVS F2C Diesel - 9/14/2012 4:18 AM
qazimoto
Score: 100
Status: offline
quote:
ORIGINAL: DerFly
Hi All,
[image][/image]
DerFly
mmm, very likely!
That's not necessarily a bad thing.
Ray
Click for fullsize
Hide Signatures
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> MVVS F2C Diesel
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
