Valve overlap on 4 strokes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Valve overlap on 4 strokes
Page: [1] 2   next >   >>
Login
Valve overlap on 4 strokes - 9/13/2012 6:32 PM
SJN
Score: 105
Last Login: 5/21/2013
Status: offline
Hi
When exactly should the valve overlap happen in 4 stroke model engines ?
I bought a few used engines, and have a few new ones too.
I ofcourse inspect the used engines before using them, and and I was checking the timing marks and noticed different valve overlaps at TDC
When my ASP 120FS is at TDC, both valves are equaly open at TDC. Very easy too see, as the exhaust and intake rocker arms are both at the same angle.
Timing mark is exactly in line with the lifters.
My OS 120FS II P which looks almost identicaly to the ASP copy both valves are equaly open a few degrees before TDC.
Again, the timing mark is exactly in line with the lifters.
My YS-120 Has both valves equaly open exactly at TDC like the ASP engine
Timing mark is directly up/down at TDC, as the manual states......which is actualy also in line with the lfters as they are 90 degrees to the crank.
My little ASP .30 like the OS 120 has the valves equaly open a few degrees before TDC, and is also times inline with the lifters.
Whats up with this?
Is there no general rule for valve overlap ?
Click to see fullsize image.
Click for fullsize
_____________________________
Sonnich Johannesen
Hide Signatures
       Post #: 1
RE: Valve overlap on 4 strokes - 9/13/2012 7:12 PM
airraptor
Score: 130
Status: offline
Valve lash to tight maybe. you can change the lash to slightly adjust when the lifter is starting to get on the "ramp" of the cam. i wouldnt worry about it as far as i know no one makes aftermarket cams. The OS 30 FS is the only engine that had two different cam profiles made for the engine.
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to SJN)
       Post #: 2
RE: Valve overlap on 4 strokes - 9/13/2012 7:25 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: SJN
Hi
Whats up with this?
Generally speaking, a shift in valve timing will also shift the RPM where peak torque is produced in the "power curve" even though the cam profile, duration & ICL (intake center line) remain the same. Advancing the cam timing will tend to fatten the TQ curve @ lower RPM, retarding the timing will shift the TQ curve towards the higher end of the RPM range.
After-market timing sets for high performance automotive applications have 3 keyways in the engine sprocket spaced around the ID. They are usually sspaced for 4* advanced timing, "straight up" (valve overlap equal @ TDC) or 4* reatarded.
Chrysler's VCT (Variable Cam Timing) utilized on '09 up 5.7 Gen III Hemis shifts the advance value of the cam shaft to take advantage of the best of both worlds. At low RPM the cam timing is advanced to give the best TQ for acceleration from idle speed. As oil pressure increases fro increased RPM, the cam timing is retarded to make more power in the higher revs.
This is a simplistic version of VVT (Variable Valve Timing)
Evidently the engines that show a bit of advance in the overlap have the cam profiles ground for some cam timing advance @ TDC to enhance TQ @ the lower RPM ranges. To be honest, that seems a bit odd in an aircraft application.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to SJN)
       Post #: 3
RE: Valve overlap on 4 strokes - 9/13/2012 7:37 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: airraptor
Valve lash to tight maybe. you can change the lash to slightly adjust when the lifter is starting to get on the ''ramp'' of the cam. i wouldnt worry about it as far as i know no one makes aftermarket cams. The OS 30 FS is the only engine that had two different cam profiles made for the engine.
While minimal valve lash would advance the opening of the valve, it also retards the closing so while it would have an affect on duration, it has no affect on overlap or ICL.
Miniamal valve lash is a good thing as long as the valves are allowed to close completely. Generally speaking, minimal valve lash not only produces more power, it reduces cam & lifter wear.
Hide Signatures
(in reply to airraptor)
       Post #: 4
RE: Valve overlap on 4 strokes - 9/13/2012 7:38 PM
w8ye
Score: 318
Status: offline
I always set mine so the center of the overlap interval center line is about 5 degrees before top dead center. This varies slightly on the different models.
The important thing is that the last part of the overlap does go through TDC.
A Magnum with the timing mark straight up and down at top dead center will complete the valve overlap sequence just before TDC. It will start and idle great but will be sick at high rpm compared with a OS or Magnum with the overlap centerline just slightly before top dead center.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 5
RE: Valve overlap on 4 strokes - 9/13/2012 7:59 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: w8ye
Problem is, W/our gear drive valve train, a shift of 1 tooth shifts cam timing 15* on a Saito. W/a 48 tooth can drive gear. I would imagine the Magnum & OS valve drive would also result in excess shifts in valve timing W/a 1 tooth change.
We are pretty much stuck W/OEM valve timing.
Hide Signatures
(in reply to w8ye)
       Post #: 6
RE: Valve overlap on 4 strokes - 9/13/2012 8:03 PM
earlwb
Score: 584
Status: online
There is something of a whole lot of art and science involved with valve overlaps and how much is enough.
Generally you adjust the overlap timing to coincide with the exhaust system and its scavenging effect at a specific RPM range, which can be quite narrow in some cases. To take full advantage of it, one needs to have a exhaust system designed for it.  But normally as the overlap increases the power developed moves higher up the RPM band. But with a small 4 stroke engine that is revving over 10,000 RPMs already, the valve overlap can be quite extreme anyway.
Now with model engine the timings or degrees of overlap can vary from larger engines as there is a scale effect that occurs as the engine gets smaller and smaller. The air and fuel don't change size as the engine gets smaller, so that remains constant.
There are some valve overlap calculators for determining the camshaft to use or to make.
http://www.wallaceracing.com/camcalc.php
http://www.rbracing-rsr.com/camshaft.html
These valve overlap numbers can give you an idea as to hot an engine is setup too.
ref http://speedtalk.com/forum/viewtopic.php?f=1&t=23156
APPROXIMATE adv overlap "operational" reference chart:
10* - 40*….towing
30* - 60*….ordinary street
50* - 75*….street performance
70* - 90*….street/strip
85* - 100*...race
95* - 115*...Pro race
The thing is, his operational reference chart right above, only seems to fit Big Blocks properly. If you take percentages and scale things down for small blocks, it ends up looking like this:
9* - 35*….towing
26* - 53*….ordinary street
44* - 66*….street performance
61* - 79*….street/strip
74* - 87*….race
83* - 100*...Pro race
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to w8ye)
       Post #: 7
RE: Valve overlap on 4 strokes - 9/13/2012 9:58 PM
earlwb
Score: 584
Status: online
Clarence Lee did a couple of reviews of the Enya R1.20 engine which is one of my favorites.   ref http://www.rcmplans.com/issues/requested/content/reviews/pdf/r-rv-enya120-011988-1-1.pdf
He details his valve timing measurements which shows how Enya got the engine to rev up high like it does.
AMA # 928076
Hide Signatures
       Post #: 8
RE: Valve overlap on 4 strokes - 9/14/2012 2:00 AM
airraptor
Score: 130
Status: offline
those LSA's applie to NA engines. add a form of mechanical super charging and you want very little overlap.
You can build a "tuned" exhaust for the engines also. a mega phone style with a 7 degree taper a good starting point. thing is they are very very loud.
AMA # 186123
Hide Signatures
(in reply to earlwb)
       Post #: 9
RE: Valve overlap on 4 strokes - 9/14/2012 2:29 AM  1 votes
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: w8ye
One tooth off makes a considerable difference on the OS, Magnum, & Y-S engines.
Original AMA #31261
Hide Signatures
       Post #: 10
RE: Valve overlap on 4 strokes - 9/14/2012 2:35 AM
earlwb
Score: 584
Status: online
Yeah a Supercharger, that is the way to go.
Roots supercharger on a Saito engine, NOTE, they have a tuned exhaust too.
This cute supercharged Saito 82 dragster rail is really neat too.
It sounds more like a two stroke when it is wound up.
http://www.youtube.com/watch?v=eeyp5P-TmDE
Click for fullsize
Click for fullsize
< Message edited by Hobbsy -- 9/14/2012 1:11 PM >
AMA # 928076
Hide Signatures
       Post #: 11
RE: Valve overlap on 4 strokes - 9/14/2012 1:09 PM
Old Fart
Score: 158
Status: offline
Hey earl that looks interesting and do you fly it??? i'm over bent eights and horsepower tricky things to do with that,does the engine sound different and how does it throttle up?would like to hear it if you post a vid somewhere for us.
Watch out for the ground eh?
Hide Signatures
       Post #: 12
RE: Valve overlap on 4 strokes - 9/14/2012 1:15 PM
Hobbsy
Score: 650
Status: offline
The Topic here is model airplane engines, please.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to w8ye)
       Post #: 13
RE: Valve overlap on 4 strokes - 9/14/2012 1:25 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: earlwb
Where can I get one of those?
Hide Signatures
       Post #: 14
RE: Valve overlap on 4 strokes - 9/14/2012 1:39 PM
Hobbsy
Score: 650
Status: offline
Dan, that thing has been shown around for a good 10 years, I don't think it caught on. There was some Turbo talk also but that fidn't fly because of the oil in the fuel no letting the turbine rev high enough.
Hide Signatures
       Post #: 15
RE: Valve overlap on 4 strokes - 9/14/2012 1:47 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Hobbsy
The fact that it "didn't catch on" doesn't bother me @ all. Scarcity only adds to the cool factor.
I was out of the hobby for 14 yars so that explains why I never saw it.
Turbocharging doesn't do it for me, but a roots style blower? That's gnarly!
I would mount the engine horizontally W/the blower sticking out the top of the cowl. Make an old school scoop for the carby.
Put a 180 pot on a 150 crank in a 150 case for 1.71 cu in @ 7.8:1 CR & throw the boost to it!
< Message edited by SrTelemaster150 -- 9/14/2012 4:08 PM >
Hide Signatures
(in reply to Hobbsy)
       Post #: 16
RE: Valve overlap on 4 strokes - 9/14/2012 2:26 PM
Old Fart
Score: 158
Status: offline
Yup! and then put the engine in an os46 sized scanner,it's exactly what they deserve
Hide Signatures
       Post #: 17
RE: Valve overlap on 4 strokes - 9/14/2012 3:05 PM
controlliner
Score: 100
Status: offline
A tuned pipe will not work on a four cycle engine as it would on a two stroke. You would have to alter the exhaust valve timing.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to Old Fart)
       Post #: 18
RE: Valve overlap on 4 strokes - 9/14/2012 3:51 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: controlliner
The newer more current 4 stroke glow engines have the valve timing already for supporting a tuned pipe pretty well. They have a lot of valve overlap and higher lift cams.The engines over timed improved and power increased. The 4 stroke engines used commonly for pattern or aerobatics are setup to use a tuined pipe even more. The early 4 stroke engines were quite mildly tuned in comparison to the newer ones. So those engines don't do well with tuned pipes.
AMA # 928076
Hide Signatures
(in reply to controlliner)
       Post #: 19
RE: Valve overlap on 4 strokes - 9/14/2012 3:55 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: Old Fart
I wish. The miniature roots blower was made by a machining firm in California (if I remember right), to promote their business. They didn't make any more, other than a few for their own purposes. No one outside of OS with their 1.20 supercharged roots blower pattern engine has made any that I know of. I think there were some videos made, I will post them if I find them.
There is a small company that makes superchargers for RC cars, but I honestly don't know how well they work. I have thought about getting one to see how it performs, but I haven't yet. That same business also offers various nitrous oxide injection systems for RC cars too. http://www.rbinnovations.com/default.asp
Here is the original thread about it here : http://www.rcuniverse.com/forum/m_1580599/anchors_1580599/mpage_1/key_/anchor/tm.htm
Their problem is that the 4 stroke engine needs to be modified for the supercharger, plus the supercharger has to be made for a specific engine displacement too. Glow engines tend to be more finicky in this way. So they never went into production with it.
AMA # 928076
Hide Signatures
       Post #: 20
RE: Valve overlap on 4 strokes - 9/14/2012 4:08 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: earlwb
Hey Earl, a low compression FA171 like I metioned above would work & I don't run glow ignition anyway if i can help it.
Also, as long as the design displacement is close, couldn't the drive pulleys can be altered for a little more volume?
Hide Signatures
       Post #: 21
RE: Valve overlap on 4 strokes - 9/14/2012 4:57 PM
earlwb
Score: 584
Status: online
Yes that would work.  I don't think they thought about it at the time.
AMA # 928076
Hide Signatures
       Post #: 22
RE: Valve overlap on 4 strokes - 9/14/2012 9:53 PM
Kmot
Score: 168
Status: offline
Looking at that old thread, led to his current Facebook page:
http://www.facebook.com/media/set/?set=a.3390357156578.2135176.1199086457&type=1
On it he says all the photos of his engine were lost in a hard drive crash. The photos that are up now were taken recently, and he is still flying this airplane!
~Tom~
Hide Signatures
       Post #: 23
RE: Valve overlap on 4 strokes - 9/15/2012 11:11 AM
Nitrovein
Score: 100
Status: offline
Easy explanation of cam LSA: http://www.compcams.com/Pages/413/cam-timing-lobe-separation-angle.aspx
Hide Signatures
(in reply to Kmot)
       Post #: 24
RE: Valve overlap on 4 strokes - 9/15/2012 3:11 PM
blw
Score: 655
Status: offline
I think the original project engine was a Saito 72.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to Nitrovein)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Valve overlap on 4 strokes
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
