OS10 FP    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> OS10 FP Page: [1]
Login
OS10 FP - 9/13/2012 7:11 PM
AMB
Score: 110
Last Login: 6/19/2013
Status: offline
Ok group i picked up a NIB OS 10 FP- ISSUE I cannot get out the phillips head head screws used WD 40 heated to no avail, do not want to take the chance of
of bugging the screw heads or really up the creek do have the Davis head and the socket head screws to get rid of the phillips ones
Ideas welcome martin
Hide Signatures
       Post #: 1
RE: OS10 FP - 9/13/2012 7:21 PM
Mr Cox
Score: 102
Last Login: 6/18/2013
Status: offline
You'll need a correct screw driver. It is not a regular philips one, but a japanese philips. That and some heat should do the trick.
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: OS10 FP - 9/13/2012 9:55 PM
fiery
Score: 100
Status: offline
Posi-Drive screwdriver of the correct size and a small propane torch to get some local heat on the head screws.
I borrow the small torch my lady has that she uses to caramelise the topping on dessert puddiings. When she is not looking
Hide Signatures
(in reply to Mr Cox)
       Post #: 3
RE: OS10 FP - 9/13/2012 10:11 PM
earlwb
Score: 599
Status: online
I would look for a set of Japanese JIS standard screwdrivers. OS uses the JIS standard and regular screw drivers won't fit the Philips head screws properly.  Now if the screws have buggered up heads or something, then what I do is place the engine in my milling machine with a cutting tool to fit in the hole and mill the heads off the offending screws. Then when I remove the head I can unscrew the remaining screw sticking out slightly above the crankcase top.  I have done that several times already to various engines.  A drill bit may work Ok too, I just didn't like the slight tapered bit of a hole leftover after the head is drilled off.
The two types of scvrew heads that one can encounter: You can see how a regular screwdriver won't fit in the cross slot on the JIS screw head.
JIS screw head
Regular Philips screw head
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to fiery)
       Post #: 4
RE: OS10 FP - 9/14/2012 1:09 AM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: earlwb
I have drilled out rusted head screws with a slightly under sized drill bit and find that the last wafer thin vestige tends to twist off just before head contact.
And its rare to find that the shaft of the screw bound into the case so just use some mulit grips to grip, twist and extract or dremel a slot across the shaft and screw out with a flat bladed driver normally.
Cheers.
Hide Signatures
(in reply to earlwb)
       Post #: 5
RE: OS10 FP - 9/14/2012 8:46 PM
AMB
Score: 110
Status: offline
We got it a # 0 phillips driver filed for a perfect fit, there was one buggered screw, after taking out 3, head was loose and got out the chewed up one no sweat
the Davis Diesel head is now on secured by 3.5mm hex head socket screws
I did heat cycle in the oven twice last night and lots of WWD40 and let it set till today sure that helped too martin
correction screws are 2.5mm
< Message edited by AMB -- 9/17/2012 10:40 PM >
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 6
RE: OS10 FP - 9/14/2012 10:26 PM
AMB
Score: 110
Status: offline
OK Group Its up and running the minnie telemaster is the bench just remounted engine and tied down the plane. a few spins with the starter off it went on prime and stopped, kept opening needle till stayed running took 4 1/2 turns open, davis head compression 3/4 turn off bottom after starting opened an other turn for rich run stopped let it cool for a bit, when we first started WOT 8400 the 8500 now 9000 only about 10 minutes so far prop 9 x 4 wood zinger it was NIB never saw glow fuel we have an other one from Dennis a few hours on it great shape will mount the Davis head as soon as I pick up from 3.5mm hex head screws so we now have 2 OS10 FP max to join the OS LA 10 Davis head.an other tank or two and will be able to lean and increase compression martin
fuel was Davis 1/2A
Hide Signatures
(in reply to AMB)
       Post #: 7
RE: OS10 FP - 9/27/2012 11:29 PM
AMB
Score: 110
Status: offline
OK ALL.. trying get the 3rd one up and running have a new p/l looking around to see if I can find a "junker" all I need are the teflon discs that plug into the end of the wrist pin case, shaft, carb muffler all good have a new gasket set and screws , do have the Davis head martin
Hide Signatures
(in reply to AMB)
       Post #: 8
RE: OS10 FP - 9/28/2012 12:32 AM
AMB
Score: 110
Status: offline
if all else fails will see if i can get some 1/4 inch teflon rod if it exists put a piece in my drill press and work with some jewelers files , worth a try
Hide Signatures
(in reply to AMB)
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> OS10 FP
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.267RCU1
