Blur engine madness    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Blur engine madness
Page: [1]
Login
Blur engine madness - 9/13/2012 11:29 PM
davidgp
Score: 100
Last Login: 2/13/2013
Status: offline
The only way I can keep the enigne running is to set the high speed needle WAY rich, like 6 turns out. I can't find a low speed needle. It will run ok until the engine heats up, then it dies. I'm sure someone can tell me where the low speed needle is, and how to keep the engine running.
Hide Signatures
       Post #: 1
RE: Blur engine madness - 9/14/2012 8:28 AM
Foxy
Score: 2012
Last Login: 5/26/2013
Status: offline
Hi, moved your thread from the Exceed forum to Engines forum, I think you'll get better help faster in here.
_____________________________
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to davidgp)
       Post #: 2
RE: Blur engine madness - 9/14/2012 4:22 PM
purenitro33
Score: 115
Last Login: 3/30/2013
Status: offline
Not sure what style of carb you have but the one below is how most slide carbs are set up.
Hide Signatures
(in reply to Foxy)
       Post #: 3
RE: Blur engine madness - 9/14/2012 6:30 PM
nitroexpress
Score: 150
Last Login: 5/25/2013
Status: offline
Rotary carb, not slide type.
I would guess the LSN is on the linkage side.  The slotted screw in the middle.
http://www.shengines.com/spare%20parts/tech%20data/PT0701A.pdf
Hide Signatures
       Post #: 4
RE: Blur engine madness - 9/18/2012 10:05 PM
davidgp
Score: 100
Status: offline
Thanks guys, I found the low speed needle right where it should have been. It was so tight I thought it was only used th ehold on the throttle bracket. After setting it two turns out the motor ran a lot better, and after some tweaking to eliminate a little stall on tip in ran very well, right up to the point the pull start broke.
Hide Signatures
(in reply to nitroexpress)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
