RE: 150% enlarged WingontheWeb HO-229    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: 150% enlarged WingontheWeb HO-229
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: 150% enlarged WingontheWeb HO-229 - 12/14/2012 11:26 PM
kwblake
Score: 110
Last Login: 5/24/2013
Status: offline
Wow.  Can you spell focused???
Sure hope I got the spelling right.
_____________________________
Kevin
Hide Signatures
(in reply to invertmast)
       Post #: 201
RE: 150% enlarged WingontheWeb HO-229 - 12/14/2012 11:29 PM
invertmast
Score: 193
Last Login: 5/25/2013
Status: offline
Lol, ehh thats a piece of cake after doing the molds for the F14! The F14 fuselage mold has over 125 hours of labor in just the layups! Each of the six segments took on average of 21hours of non-stop work!
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to kwblake)
       Post #: 202
RE: 150% enlarged WingontheWeb HO-229 - 12/14/2012 11:36 PM
kwblake
Score: 110
Status: offline
Not much I can say to that.  I USED to think that I worked hard.
Kevin
Hide Signatures
       Post #: 203
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 1:50 AM
invertmast
Score: 193
Status: offline
So what happens on a saturday evening. Infusion happens!
How is that for a teaser. Lol
Thomas W.
Hide Signatures
       Post #: 204
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 4:01 AM
invertmast
Score: 193
Status: offline
Ohh.. where to start...
First up was finishing the layup schedule on the bottom fuse mold. You can see there is a good bit of carbon fiber around the nose gear and main gear mounting locations:
Then the peel ply, resin feed lines, and flow mesh was put in place:
The the vacuum bag was put in place, the resin feed line "T" fittings popped through the bag and sealed along with the feed tubes installed and clamped off. The vacuum line "T" fitting was popped through the bag, sealed and hooked up to the resin trap as well. Then the entire thing was sucked down to 25" hg.
This was left under vacuum for about 2 hours while we ate some dinner and did the majority of the remainder of the layup schedule on the top mold half:
Then we infused the bottom mold half. I've got a video saving right now and will post the you tube video link when I get it posted..
Thomas W.
Hide Signatures
       Post #: 205
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 4:24 AM
invertmast
Score: 193
Status: offline
Here's a few pictures of the infused lower half:
Thomas W.
Hide Signatures
       Post #: 206
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 4:48 AM
invertmast
Score: 193
Status: offline
VIDEO LINK:
http://www.youtube.com/watch?v=yW0AltnUOr4&feature=youtube_gdata
Thomas W.
Hide Signatures
       Post #: 207
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 1:01 PM
Check6
Score: 105
Status: offline
Don't know what happened but I lost the audio after a min. Maybe it's my computer. Anyway awesome build and craftsmanship.
Fred
Hide Signatures
       Post #: 208
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 1:16 PM
Dago Red
Score: 100
Status: offline
time was sped up after about a minute, but returns later when time returns to normal.
Hide Signatures
(in reply to Check6)
       Post #: 209
RE: 150% enlarged WingontheWeb HO-229 - 12/16/2012 9:20 PM
wphilb
Score: 105
Status: offline
Impressive....
Questions: the spiral wrap is what we use to bind cables together? Here it holds feed lines inside and prevents crushing or it IS the feed lines? Flow medium?? Where is the peel ply in this and why is it used? What is the materials cost per fuse half and what of that is reusable? Like is the bag material reusable? How do you clean out the resin trap?
Answer only what you want to, I'm far from being able to do this, no hard feelings as your obviously busy.
I'm fascinated by this, it really looks professional.
Whit
Hide Signatures
(in reply to Dago Red)
       Post #: 210
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 3:44 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: wphilb
Impressive....
Whit
1. Yup same kind of spiral wrap used to hold electrical wires together.
2. The Spiral wrap Is the feed line
3. Flow medium (it helps the resin flow through the entire layup to wet it all out).. the soric (hexagon looking stuff) is a flow media and sandwich material as well. We then used a specialty expanded plastic mesh that also hows the resin flow quicker.
4. Peel ply is used between the layup and the resin feed lines. It makes the surface ready for any secondary bonding once it is pulled away.
5. Materials cost... there's around $150 worth of one time use consumables per mold half
6. Nothing gets reused once it part is infused...
7. No cleaning of the PVC resin trap.. its $8 in parts for one and can be used till its full, then it gets trashed and a new one made up. If i wanted to spend $300+ on a commercial unit, I could clean it out then.
Thomas W.
Hide Signatures
(in reply to wphilb)
       Post #: 211
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 3:49 AM
invertmast
Score: 193
Status: offline
Top half is done:
First up was getting the layup all done, peel ply in place, resin feed and vacuum lines in all place..
Then the vac. bag was put in place, fought with for an hour or so finding and fixing leak(s) (mostly just one stubborn one).. then it was infused. This one turned out Great as well!
Then sometime between all that, we torn all the trash off the bottom section and got it ready for internals and joining. We still have a good bit of work to do on the internal structure and determining fan unit mounts, battery tray's, nose gear stuff, etc.. but its mostly figured out. So here's a few shots of the bottom mold half and some views of the internal structure that is still far from done.
And a video of the infusing of the top half:
http://www.youtube.com/watch?v=ljldNC123bM&feature=youtube_gdata
Thomas W.
Hide Signatures
       Post #: 212
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 3:57 AM
wphilb
Score: 105
Status: offline
Thanks for all the answers!
Does that $150 include the resin and cloth that will be a part of the final part? What do you think you might be selling these for? I'm not a prospective buyer, just curious about the economics, when it makes sense to go this route vs just building the wooden plug but glassing and using it, from an economics POV vice any structural/performance/flying/maintence aspects.
Really enjoying this thread.
Whit
Hide Signatures
       Post #: 213
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 4:08 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: wphilb
Whit
Nope, that $150 is just in peel ply, bag film, bag tape, spiral wrap, nylon fittings and feed/vacuum tubes. There is around $1000 worth of materials in each complete part. Projected price was hopefully going to be around $900-1000, but its going to have to go up.. Once we get the 2nd and 3rd center section done, we will have a better idea of the costs associated and a selling cost.
To put it into perspective, there is about $200 in plywood in one center section. $180 worth of balsa, $30 in epoxy, $40-50 in fiberglass in just the plug. Not to mention about 2 weeks worth of work to cut out all the interlocking 'notch's in all the parts, And we didn't even put in all the lightning holes, or all the structure needed for man unit mounts, landing gear mounts, etc etc etc! It weights about 20 pounds to!
While our center sections will be expensive (compared to wood), it'll save allot of time, it will be significantly lighter AND stronger, and will be ready for paint, hatch mounting, equipment install and door hinging. Essentially if you work at a moderate pace, you could have the center section completely done and waiting on the outer wing panels in a week.
Thomas W.
Hide Signatures
       Post #: 214
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 4:13 AM
wphilb
Score: 105
Status: offline
Thanks again! Very educational.
How many do you plan on making? Slightly different question, how many could you get from your mold before you would have to make another one from that plug?
And those are the last questions!
For today at any rate LOL
Whit
Hide Signatures
       Post #: 215
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 4:17 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: wphilb
Whit
Uhm... good question on how many do we plan to make... Atleast two! lol really it just depends. We've had some realizations that we can't sell ourselves short on profit, we have to much invested in these things to just give them away. That said, we would like to see more people flying these things as they are awesome looking..
The mold should be good for 50-100+ parts. I ensure my molds are all very thick so they stay stable and last. The only thing that really wear's on the mold, is light details (panel lines in this case) so while these details may get less prominent over time, they will still be there.. But it takes ALLOT of parts for that to happen.
Thomas W.
Hide Signatures
       Post #: 216
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 4:24 AM
wphilb
Score: 105
Status: offline
OK,  I would love one but sounds like a $3K plane "on the hoof?" (Whoops, another question). Plus I'm not familiar enough with high wattage electrics to make a go at this project.
But I will happily fly one in my head drifting off to sleep tonight.
Please keep up the thread and the videos, especially the maiden flight.
Whit
Hide Signatures
       Post #: 217
RE: 150% enlarged WingontheWeb HO-229 - 12/17/2012 4:30 AM
invertmast
Score: 193
Status: offline
Whit,
Nah, you could have it done for around $2k.. This is my first High-powered EDF model, so there's lot of firsts for all of us..
Thomas W.
Hide Signatures
       Post #: 218
RE: 150% enlarged WingontheWeb HO-229 - 12/18/2012 3:19 AM
invertmast
Score: 193
Status: offline
Pulled all the bagging, feed lines, etc off of the molded top part. Again it turned out pretty good... I'm begging to think the CF has a defect in it as there is another spot that appears to not have fully wet out either... but it is very stiff. It may just be some sort of contaminant on the surface of the CF... either way, off we go!
Then we tested the fit of the structure to the top half. We need to do a little bit of adjustments, but they fit pretty good. We also closed the mold halves together and they fit reallly good. The aft half didn't close completely, but that's due to the structure needing a bit of trimming. Wed. we are planning to get the structure layout and lightning holes finalized and then start installing all that stuff this weekend:
Thomas W.
Hide Signatures
       Post #: 219
RE: 150% enlarged WingontheWeb HO-229 - 12/20/2012 3:02 AM
invertmast
Score: 193
Status: offline
My budd and I essentially got all the templates done, and the majority of the interior structure for the first model done. All that is left, is the nose gear mount parts and fan unit mounts. We left ourselves two options for mounting batteries which we will show later on. Interior structure comes in at around 1 pound and is all aircaft ply. I plan to take some time tomorrow or friday and get the wing tube so kets epoxied and glassed to there spars, the nose gear mounts cut and readied and the main landing gear doublers glued into place.
For those wondering, the holes in the bulkheads should support a 110-120mm edf unit. There is also plenty of room for future fuel tanks for turbines.
Thomas W.
Hide Signatures
       Post #: 220
RE: 150% enlarged WingontheWeb HO-229 - 12/20/2012 5:15 PM
tardster
Score: 100
Status: offline
Invert, dude I have to say I'm so jealous of your skills. I wish I could come 1/10th the builder you are, keep up the amazing work man...
Lower, Lower, Ah Damnit
Ed P-40 Brotherhood # 61
Hide Signatures
       Post #: 221
RE: 150% enlarged WingontheWeb HO-229 - 12/21/2012 5:13 AM
invertmast
Score: 193
Status: offline
The first Horten is getting closer to being born!
Tonight I got the wing tube sockets epoxied and glassed to their carry-through spars/bulkheads. I also epoxied the main gear mount doublers in place. And I got started on designing the nose gear structure parts. I've got to wait for the nose gear to show up to verify they are long enough, but I'm pretty sure they are. They are also oddly shaped so you can get to the fan mount parts.. This big ole' center section is getting crammed pretty quickly with its guts..
Thomas W.
Hide Signatures
(in reply to tardster)
       Post #: 222
RE: 150% enlarged WingontheWeb HO-229 - 12/21/2012 5:30 AM
glazier808
Score: 291
Status: online
Lookn good Thomas
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 223
RE: 150% enlarged WingontheWeb HO-229 - 12/21/2012 5:31 AM
invertmast
Score: 193
Status: offline
Thanks Casey.. We are determined to have a Horten for Christmas! And if it all go's well, We will have a PAINTED horten for christmas... now If i could just get some snow to get a good snow camo inspiration. lol
Thomas W.
Hide Signatures
(in reply to glazier808)
       Post #: 224
RE: 150% enlarged WingontheWeb HO-229 - 12/21/2012 6:52 PM
invertmast
Score: 193
Status: offline
While I wait for the firewood delivery, I went out in the shop and got some stuff done..
First up was cutting and epoxying all of the outer wing panel attachment bolt blocks into place on the carry through bulkheads. I'll drill and tap these blocks for a 4-40 bolt to hold the wings on after the halves are joined.
I then got the main landing gear plates aligned and epoxied that entire assembly of plates and ribs together. 1/2" tri-stock was placed in the corners for added strength:
And my buddy Tom brought over the Robart nose gear retract. So with the retract here and some slight modifications to the nose gear structure, It is ready for install. We have decided to wait to install this till after we join the halves due to it possibly interfering with the canopy frame openings, which may require it to modified again..
So, now that everything is essentially complete, tomorrow we close the mold halves!
Thomas W.
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
