William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
David: My experience with muffler gaskets on these engines is consistent failure. With heat and vibration the gasket is compressed, that loosens the mounting and the muffler hammers the gasket making everything even looser, then the gasket fails and the muffler screws are so loose the muffler falls off. Don't use the gasket. The "High Temp" RTV you referenced will work, but I've never had any problem with ordinary "Blue Glue" on a two-stroke engine.They don't get that hot. LocTite is up to you, but the operating temperature is high enough to soften it so I don't bother. Smooth mating faces. a thin smear of RTV, snug the screws. No more problem. And yes, I seal the seam in the body too. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
