Hitec optima 6 NOT binding!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Hitec optima 6 NOT binding!
Page: [1]
Login
Hitec optima 6 NOT binding! - 9/15/2012 5:48 AM
nlxon
Score: 100
Last Login: 9/16/2012
Status: offline
Just upgraded my Eclipse7 with a 2.4GHz module and Optima 6 receiver; I've followed the linking steps (tx is in PPM mode), however when I release the RX button to complete the link the blue light doesn't come on, but the TX module red light is solid and blue light is flashing, which means its linking? What’s going on?
< Message edited by nlxon -- 9/15/2012 8:54 AM >
Hide Signatures
       Post #: 1
RE: Hitec optima 6 NOT binding! - 9/15/2012 10:40 AM
A.T.
Score: 181
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: nlxon    Just upgraded my Eclipse7 with a 2.4GHz module and Optima 6 receiver;
If you have bought a new Spectra Module and Optima Transceiver in the one pack, they should have been already set up.
Anyhow, given that you have the latest firmware in both units, the printed instructions will be out of date, the blue light now
flashes so quickly on the transceiver, that it may often not be seen, refer:
. AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure for
........Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver.
extract " 07 Oct 2011 Update:
Blue LED on Optima V2.02 may not hold steady after ID setup, just a very brief flash.
Red LED then holds steady.
Cycle power both TX & Optima to complete and then range test as usual."
The following may also assist:
. Hitec Eclipse 7 & Eclipse 7 Pro - All Manuals, Addenda, Quick Setup, CCPM and Additional Programming FAQ
ex Hitec USA Support Forum Sticky:
AFHSS Modules, Optima, Minima & Telemetry
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
_____________________________
R/C hobby consultant for various companies
Hide Signatures
(in reply to nlxon)
       Post #: 2
RE: Hitec optima 6 NOT binding! - 9/15/2012 11:18 AM
nlxon
Score: 100
Status: offline
Thanks A.T.,
That may explane why the servos have been operational and range check worked.
Would you happen to know of any issues around not having the RX wire in a vert. postion, but rather a horz. position; I plan to use this set up for a Jazz60 wing.
Thanks  ,
Hide Signatures
(in reply to A.T.)
       Post #: 3
RE: Hitec optima 6 NOT binding! - 9/15/2012 11:47 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: nlxon   Thanks A.T.,
but rather a horz. position; I plan to use this set up for a Jazz60 wing. Thanks  ,
No problem depending upon construction material, please refer:
. Optima Transceiver & Minima Receiver - Installation RX & BODA Antenna FAQ,
Volts & Range Test Results. {Regularily Updated with Q&A}
Suggest you familiarise yourself with the headers on the FAQ page, quoted Post #2,
content of which is updated daily.
Alan T.
Hide Signatures
(in reply to nlxon)
       Post #: 4
RE: Hitec optima 6 NOT binding! - 9/21/2012 4:38 AM
jrlingrel
Score: 100
Last Login: 5/20/2013
Status: offline
I upgraded my Eclipse 7 to 2,4 and am able to bind to the Optima 6 receivers, but I have 2 Minima 6 receivers that both fail to bind, any ideas
John
Take offs are optional, landings are mandatory.
Hide Signatures
(in reply to nlxon)
       Post #: 5
RE: Hitec optima 6 NOT binding! - 9/21/2012 5:28 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: jrlingrel   I upgraded my Eclipse 7 to 2,4 and am able to bind to the Optima 6 receivers, but I have 2 Minima 6 receivers that both fail to bind, any ideas            John
As in post #4, suggest you familiarise yourself with the headers on the FAQ page,
and as quoted Post #2 :
There are two separate methods of ID_Setup (for the Transceivers (Optima) and Receivers (Minima)
as disclosed within the last two pictures.
Note especially the separate LED operation on the module and how to change from one to the other,
(A flashing RED LED for Transceiver setup and a Flashing BLUE LED for Receiver setup).
Alan T.
Hide Signatures
(in reply to jrlingrel)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
