Do you need throttle trim ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> Do you need throttle trim ?
Page: [1]
Login
Do you need throttle trim ? - 9/15/2012 10:08 PM
dkm
Score: 100
Last Login: 5/21/2013
Status: offline
Do you need throttle trim on your transmitter or does it just complicate the setup ?
After watching a flyer screw up a setup with a heli, I started to wonder if it is easier to
inhibit the throttle trim.
The throws are set using the servo travel for full throttle range.
Mechanically set for mid throttle - mid stick. The throttle curve can be displaced for
adjusting idle speed.
Hold speed is set on throttle hold and cut is also radio set.
Do I need throttle trim ? Don't use it when I fly !
Hide Signatures
       Post #: 1
RE: Do you need throttle trim ? - 9/16/2012 1:13 PM
BarracudaHockey
Score: 280
Last Login: 5/22/2013
Status: offline
Some folks use it to adjust the idle, and it only effects the lower portion of throttle range, it doesn't effect centering.
Also, in normal mode I usuall crank in a bit of throttle trim for a higher idle to keep the engine from going all the way back to idle during descents
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to dkm)
       Post #: 2
RE: Do you need throttle trim ? - 9/16/2012 5:38 PM
AKPhill
Score: 100
Last Login: 4/29/2013
Status: offline
Some use throttle trim as an engine shut off
and if your flying electric not needed at all
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
