Jetcat P90-RXi    Gallery
Logged in as Guest
Users viewing this topic: jetpassion
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Jetcat P90-RXi
Page: [1] 2   next >   >>
Login
Jetcat P90-RXi - 9/16/2012 4:58 AM
Guillermo Ibanez
Score: 100
Last Login: 5/22/2013
Status: offline
Hi: when is scheduled to be released the Jetcat P90-RXi?
Any idea of the price?
_____________________________
Guillermo Ibanez
Hide Signatures
       Post #: 1
RE: Jetcat P90-RXi - 9/17/2012 10:07 AM
Dave Wilshere
Score: 108
Status: online
Around 6 weeks I was told. Did not ask a price!
Dw
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Dave Wilshere -- 9/17/2012 3:41 PM >
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to Guillermo Ibanez)
       Post #: 2
RE: Jetcat P90-RXi - 9/17/2012 3:34 PM
drdoom
Score: 130
Status: offline
90 RXI
Click for fullsize
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 3
RE: Jetcat P90-RXi - 9/17/2012 3:42 PM
CDB-RAE
Score: 100
Last Login: 5/21/2013
Status: online
hello
some one get the engine weight looks really big compared to the P-100rx ??
yes i know the pump is in the engine.
Hide Signatures
(in reply to drdoom)
       Post #: 4
RE: Jetcat P90-RXi - 9/17/2012 3:47 PM
drdoom
Score: 130
Status: offline
I have an P-100 rx it looks to be the same case.
Hide Signatures
(in reply to CDB-RAE)
       Post #: 5
erbroens
Score: 105
Status: offline
Interne kraftstoffpumpe? interesting and very cool... the installation should be super simple and clean.
Hide Signatures
       Post #: 6
RE: Jetcat P90-RXi - 9/17/2012 3:51 PM
Carsten Groen
Score: 100
Status: offline
quote:
ORIGINAL: drdoom
The P90RXi is the same case as P80/P120/P140/P180 etc (ie larger than P100RX)
Carsten Groen
Hide Signatures
       Post #: 7
RE: Jetcat P90-RXi - 9/17/2012 4:02 PM
FalconWings
Score: 121
Status: offline
Not a big fan of that many internal components.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to Carsten Groen)
       Post #: 8
RE: Jetcat P90-RXi - 9/17/2012 4:30 PM
drdoom
Score: 130
Status: offline
So it is the same as the p-140 RX? which is much bigger than the P100-RX.
Hide Signatures
(in reply to FalconWings)
       Post #: 9
RE: Jetcat P90-RXi - 9/17/2012 4:36 PM
erbroens
Score: 105
Status: offline
quote:
ORIGINAL: FalconWings
Supposing it is out of warranty, nothing that a screwdriver and a hammer can´t open and fix..
Hide Signatures
       Post #: 10
RE: Jetcat P90-RXi - 9/17/2012 4:38 PM
Vincent
Score: 105
Status: online
quote:
ORIGINAL: drdoom
It is a re-worked P-80se
Vin...
Hide Signatures
       Post #: 11
RE: Jetcat P90-RXi - 9/18/2012 5:53 AM
Airforce7
Score: 100
Status: offline
Looks like it uses the old style compressor wheel?
Hide Signatures
(in reply to Vincent)
       Post #: 12
RE: Jetcat P90-RXi - 9/18/2012 6:48 AM
chrigui
Score: 100
Last Login: 5/8/2013
Status: offline
seems KKK2038 from kj66 and another similar engine...
www.jetflydemoteam.com
Hide Signatures
(in reply to Airforce7)
       Post #: 13
RE: Jetcat P90-RXi - 10/10/2012 2:53 PM
Cliffhanger
Score: 105
Last Login: 5/17/2013
Status: offline
That is why people tend to call that brand CopyCat
Best regards,
Hide Signatures
(in reply to chrigui)
       Post #: 14
RE: Jetcat P90-RXi - 10/10/2012 3:39 PM
Dave Wilshere
Score: 108
Status: online
Mmm like so many who have the identical starter motor pod to JetCat
Cars with engines inside...and four wheels and Hoovers that suck up cr*p ?
Dw
Hide Signatures
(in reply to Cliffhanger)
       Post #: 15
RE: Jetcat P90-RXi - 10/10/2012 8:11 PM
chrigui
Score: 100
Status: offline
in my opinion good engine
Hide Signatures
       Post #: 16
RE: Jetcat P90-RXi - 10/10/2012 9:34 PM
bluescoobydoo
Score: 105
Status: offline
it will be great untill you get a problem with it then you are at the mercy of the black hole that is the jet cat repair service
I just ran out of talent !!!!!!!!
Hide Signatures
       Post #: 17
RE: Jetcat P90-RXi - 10/11/2012 12:48 AM
jetnuno
Score: 105
Status: offline
Hi
We have been watching in the last few years, from many manufacturers and JC in particular, to the following features:
1-Internal kerostart
2-Internal solenoid valves
3-Internal ECU (not in JC)
4-Internal pump
What will be next internal? will they make a turbine with internal landing gear and airplane???
Also another comun feature is the machined compressor.
Of course it is great to make an easy install, but in the end if you have an internal kero plug damaged or a damaged valve, the turbine will have to be shipped for the manufaturer to solve a simple problem. Is this a good thing? I don't believe so....
Service is a profit center and manufacturers think they will protect theirselves with these features.
The same for machined compressors-you will never be able to buy a compressor if it is damaged. Burn plug? Sticky valve? Frozen pump? Return it for service...wait and pay big bucks.
All in all, I feel that I want to stick with old fashion. Am I alone with these thoughts?
Regards
Nuno
Hide Signatures
(in reply to bluescoobydoo)
       Post #: 18
RE: Jetcat P90-RXi - 10/11/2012 1:01 AM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: jetnuno
Hi
4-Internal pump
Regards
Nuno
Not at all. I want serviceable items to remain external. Don't mind internal solenoid though, as long as I can bypass them if necessary.
What's next? I'd like to see a power inverter that provides power to the model, so that batteries would only be needed as backup and for start up.
David
Hide Signatures
(in reply to jetnuno)
       Post #: 19
RE: Jetcat P90-RXi - 10/11/2012 1:06 AM
Nhalyn
Score: 115
Status: offline
To respond this, I would like to see and photo of the 90 RXi without the front cover.
I'm pretty certain that there is still the well known valves and other stuff, but well packaged inside the cover with minimum and rigid tube, with minimum cables.
That's a step beyond in a simple idiot proof installation, with only few feets of single tube between hopper tank and turbine, and only two cables to receiver + power. I've asked myself so much question when receiving my JC P160SX ! There is too much cables and festo links in my plane !
"You''''ve never been lost until you''''ve been lost at mach 3 !" (a test pilot of the SR-71)
Hide Signatures
       Post #: 20
RE: Jetcat P90-RXi - 10/11/2012 1:12 AM
Nhalyn
Score: 115
Status: offline
quote:
]What's next? I'd like to see a power inverter that provides power to the model, so that batteries would only be needed as backup and for start up.
David
Well, that's done with the JC P300 and P400 with the generator option...
Next step will be integrated ECU... That's the last external part !
Hide Signatures
       Post #: 21
jetnuno
Score: 105
Status: offline
I think it will be interesting to start a thread with this.....
Hide Signatures
(in reply to Nhalyn)
       Post #: 22
RE: Jetcat P90-RXi - 10/11/2012 6:40 AM
chrigui
Score: 100
Status: offline
quote:
ORIGINAL: bluescoobydoo
i can do it...
Hide Signatures
       Post #: 23
RE: Jetcat P90-RXi - 10/11/2012 4:29 PM
Ramz
Score: 106
Last Login: 5/14/2013
Status: offline
So we haven't seen the engine with the front cover off and we are already saying that it will be an expensive pain to service? How about we wait for some more information and pictures of the 90rxi before we pass judgement.
In 5 years from now, most of us won't buy a turbine unless it has everything internal.
Hide Signatures
       Post #: 24
RE: Jetcat P90-RXi - 10/11/2012 4:36 PM
Jamie C
Score: 115
Status: online
Jetcat have the P90 RXI listed on their website as 1950 Euros.
Hide Signatures
(in reply to Ramz)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
