RE: O.S. 60GT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: O.S. 60GT Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: O.S. 60GT - 9/24/2012 10:18 PM
Truckracer
Score: 309
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: wyo69cowboy
Hope we get some more photos soon of the crank and bearings, etc. It does appear to be an aluminum rod, which is the first large gasser I can think of with that feature. I asked a while back on one of these forums about steel vs aluminum rods, especially in the small 20cc size, and the answers were generally that steel was used for durability...
Many of the cantilever crank gassers such as the Brisons and FPE engines used aluminum rods w/ cupped needle bearings. Not at all uncommon.
Hide Signatures
(in reply to wyo69cowboy)
       Post #: 26
RE: O.S. 60GT - 9/24/2012 10:34 PM
earlwb
Score: 599
Last Login: 6/19/2013
Status: online
Using a steel rod lets you harden the ends of the rod and use it for the outer race for the needle bearings, then with a hardened crankpin and wrist pin you can save a lot on how big the rod is overall. Using a aluminum rod is not a problem as they have done it for many years on engines, such as motorcycle engines for example. But then the needle or roller bearings need to be made with at least a outer race then.
Does the OS engines use a special OS carb that is incompatible with Walbro parts? Although OS makes some really good engines, it would be nice to have a way to at least  replace the diaphragms if the need arises.  I don't remember seeing rebuild kits for their gasser engine carbs.
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Truckracer)
       Post #: 27
RE: O.S. 60GT - 9/24/2012 10:38 PM
wyo69cowboy
Score: 105
Last Login: 6/17/2013
Status: offline
ah so...didn't know that. Just a few Brisons around here, and very few FPE's, if any, that I've seen, but the Brison's do have a good reputation FWIW. I've always wondered about the aluminum rod usage, thinking it would be lighter, but didn't account for the hardened steel rod being the outer bearing "race"; therefore making a simpler bearing setup. Maybe no weight penalty either way if done right...
Crashing my way to being a better pilot!
Saito Club# 679
Hide Signatures
       Post #: 28
RE: O.S. 60GT - 9/24/2012 11:55 PM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
Aluminum with a hard steel sleeve for the needle bearings?
Hide Signatures
       Post #: 29
RE: O.S. 60GT - 9/25/2012 8:08 AM
TimBle
Score: 162
Status: offline
aluminium rods are lighter. Even a 2 gr saving has a benefit when we look at the acceleration of the conrod. The  designer wants the lightest and strongest piston and rods that can be built to last the projected lifespan of the engine.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 30
RE: O.S. 60GT - 9/25/2012 2:57 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: TimBle
Hmmm! Weighing rods from an SAP 180HP (tungsten steel) and a rod from a DLE30 (aluminum) the lighter one is the tungsten steel by about 15%....I was surpised at that finding too. Todd Syssa designed his rods for super strength yet low weight regardless of cost, which doesn't mean every manufacturer would use the stronger but much more expensive rod. I've owned two Syssas and run them hard for two years, and have followed the Syssa thread for 3 years. I have not had nor heard of one issue with the rod
Regards,
MattK
Hide Signatures
(in reply to TimBle)
       Post #: 31
RE: O.S. 60GT - 9/25/2012 3:00 PM
Truckracer
Score: 309
Status: offline
quote:
ORIGINAL: MTK
quote:
ORIGINAL: TimBle
But ...... the DLE 30 rod is steel too, not aluminum!
Hide Signatures
(in reply to MTK)
       Post #: 32
RE: O.S. 60GT - 9/25/2012 3:05 PM
MTK
Score: 203
Status: offline
Not sure what engine it was. I thot he said DLE. I don't own a 30 cc so I don't have personal experience, What I saw was at his shop in Conn
Regards,
MattK
Hide Signatures
       Post #: 33
RE: O.S. 60GT - 9/25/2012 5:51 PM
closetguy
Score: 166
Status: offline
MVVS and Evolution have aluminum rods also,i never had a problem with them.
some where i seen a price for the OS60 in Yen and had been converted to USD, it came out to 870.00 if i remember it rite.
Hide Signatures
(in reply to MTK)
       Post #: 34
RE: O.S. 60GT - 12/4/2012 12:53 PM
avionul
Score: 100
Last Login: 6/13/2013
Status: offline
I have 2 55 they are the best
Hide Signatures
       Post #: 35
RE: O.S. 60GT - 1/4/2013 11:51 PM
Broken Wings
Score: 141
Last Login: 6/15/2013
Status: offline
Has anyone received one of the new 60's...
Club Saito member #715
Club Jett member #12
Hide Signatures
(in reply to avionul)
       Post #: 36
RE: O.S. 60GT - 1/6/2013 5:48 PM
RAMMJETT
Score: 100
Last Login: 5/8/2013
Status: offline
when lightening a rod by using aluminum you don't have to lighten the whole rod(simply weighing a complete aluminum or steel rod would tell you little about what one was actually lighter. you need to weigh the top 1/3 of the rod) ,generally only the top 1/3 of the rod is considered reciprocating mass ,the lower 2/3 of the rod is considered rotary mass and only this mass is included when balancing the cranks rotary mass. yep you guessed it you can not balance reciprocating mass in a single and that is why it's so critical to keep weight down in the top end of a engine (as RPM doubles the weight of the reciprocating mass squares )
this is also why a twin runs so smooth the piston counters the weight of the opposing piston if the designer gets it right and the rotary mass is balanced well you will have a limited vibration 90 degree from the reciprocating mass and you have your self a smooth engine.even in this case it is beneficial to have the top end as light as possible , the lighter it is the more HP it will produce because less energy will be spent trying to overcome the weight of the piston.
the problem is there is no exact science for how much rod to include when balancing rotary mass ,it's more like voodoo LOL .and as you know many get it wrong.Roger
Hide Signatures
(in reply to Broken Wings)
       Post #: 37
RE: O.S. 60GT - 1/6/2013 5:53 PM
ghoffman
Score: 163
Status: offline
My buddy Matt got his Thursday.
Hide Signatures
       Post #: 38
RE: O.S. 60GT - 3/22/2013 10:18 PM
Broken Wings
Score: 141
Status: offline
Any news?.....
Hide Signatures
(in reply to ghoffman)
       Post #: 39
RE: O.S. 60GT - 3/23/2013 2:36 AM
airraptor
Score: 131
Status: offline
the mag review doesnt show it as being very strong. Turning a ZOAR 22x8 at 6,161 rpm... weak zoar 24x8 at 5,889
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 40
RE: O.S. 60GT - 3/23/2013 3:09 AM
Broken Wings
Score: 141
Status: offline
I want to use it in a Ziroli Stuka. I'm more interested in reliability, sound level, ease of use, etc...
If you don't mind me asking, which magazine was it? I'd like to read it.
I found this from http://www.keimod.com/shop/product_info.php?products_id=747
INCLUDES: O.S. GT60 Gasoline Engine, IG-02 Electronic Ignition, CM6 Spark Plug, Instruction Manual
SPECS:
Displacement: 3.656 (59.91cc)
Bore: 1.732" (44.0mm)
Stroke: 1.551" (39.4mm)
RPM Range: 1,600-8,000 RPM
Output: 6.00 hp @ 7,000 RPM
Weight: Engine, 49.38 oz (1400 g)
Ignition module, 3.7 oz (105 g)
Suggested Propeller Size and RPM Data:
22x8 7,650 RPM
22x10 6,900 RPM
23x8 7,000 RPM
24x8 6,550 RPM
24x10 6,150 RPM
Hide Signatures
(in reply to airraptor)
       Post #: 41
RE: O.S. 60GT - 3/23/2013 7:24 AM
airraptor
Score: 131
Status: offline
model Airplane news May 2013 issue.
AMA # 186123
Hide Signatures
       Post #: 42
RE: O.S. 60GT - 3/23/2013 1:43 PM
ghoffman
Score: 163
Status: offline
We tested the OS GT-60 a couple of weeks ago. It was 18F out and it turned a Mej 24-10TH at 5950 RPM and was 89 dBA @ 20 feet with the stock, supplied muffler.  However, it started backwards about 1/2 the time.
Hide Signatures
       Post #: 43
RE: O.S. 60GT - 3/24/2013 11:24 PM
MTK
Score: 203
Status: offline
I saw that MAN review. I wasn't surprised at the numbers their test guy got. I think it was the same guy that got 4600 rpm on the 33GT turning a 20x10. Well, it just ain't so....But as always, YMMV
Regards,
MattK
Hide Signatures
       Post #: 44
RE: O.S. 60GT - 3/25/2013 12:00 AM
Broken Wings
Score: 141
Status: offline
I ordered one, I hope it turns out to be a good engine.
Hide Signatures
(in reply to MTK)
       Post #: 45
RE: O.S. 60GT - 3/26/2013 11:28 PM
Broken Wings
Score: 141
Status: offline
I received the GT60 engine today and one of the first things I noticed is the Engineers at OS included a web in the exhaust port.
Notice the match between the liner and the aluminum casting........
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 46
RE: O.S. 60GT - 3/26/2013 11:33 PM
Broken Wings
Score: 141
Status: offline
Another picture.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 47
RE: O.S. 60GT - 3/27/2013 2:43 AM
airraptor
Score: 131
Status: offline
The exhaust port looks good for a tuned pipe but the transfers look a bit high but maybe thats your picture. it looks well made but price is to high for my blood. unless its is the new king in the pylon world where the MVVS/EVO 58 rules now.
AMA # 186123
Hide Signatures
       Post #: 48
RE: O.S. 60GT - 3/27/2013 3:02 AM
Truckracer
Score: 309
Status: offline
quote:
ORIGINAL: Broken Wings
I thought that engine uses a plated bore just like most gas engines ....no liner.
Hide Signatures
       Post #: 49
RE: O.S. 60GT - 3/27/2013 5:14 PM
Broken Wings
Score: 141
Status: offline
quote:
ORIGINAL: Truckracer
You Win!!!
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.281RCU1
