Mufflers for gas engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> Mufflers for gas engines
Page: [1] 2   next >   >>
Login
Mufflers for gas engines - 9/17/2012 12:24 PM
crooked stripe
Score: 100
Last Login: 12/5/2012
Status: offline
New to gas engines. Installed a 20 DLE in a plane and am very happy with it. Expect the noise. I was told to change the prop. I am getting a lot of cracking from sound barrier speeds of the prop. I am running a 15 x6 but going to try a 16x6 hoping it will slow down. What do you all know about mufflers and where to get them. I don't  want to be asked not to fly that plane at our field. All info will be appreciated, John
Hide Signatures
       Post #: 1
RE: Mufflers for gas engines - 9/17/2012 1:12 PM
dmowery
Score: 100
Last Login: 5/18/2013
Status: offline
Dont fly without one Any Hobby shop that sells  planescan -contact DL and they have or know where to get one
_____________________________
Owner of -rcskyjumper
Chutes and jumpers and suport items
Hide Signatures
(in reply to crooked stripe)
       Post #: 2
RE: Mufflers for gas engines - 9/17/2012 1:53 PM
RCVFR
Score: 141
Last Login: 5/19/2013
Status: offline
You are under propping the engine. Try a 17X6, shd get around 8300- 8500 rpm.
Sometimes, things are exactly as they appear to be.
Hide Signatures
       Post #: 3
RE: Mufflers for gas engines - 9/17/2012 2:31 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
Quietest you can get for that are cannisters but they aren't cheap. But even can's wont help with prop rip.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to RCVFR)
       Post #: 4
RE: Mufflers for gas engines - 9/17/2012 5:48 PM
opjose
Score: 280
Status: offline
Given the RPM's what you are hearing is coming from the muffler.
Your prop is not approaching the sound barrier.
All too often people confuse engine sounds with prop sounds on smaller gassers like yours.
Your muffler is an unbaffled "can" type muffler, which is almost as noisy as running no muffler.
FYI: Syssa makes noise quieting restrictor inserts for their engines.
I was in the same situation as you, where the so-called "experts" kept telling me that my engine was noisy due to prop noise and I should change my prop.
To that I merely answered by installing the inserts and starting the engine back up.... they went off to remove the remnants of their foot from their mouths....
Check out the Syssa "tone" inserts, in lieu of installing a canister you could opt for making and installing something like that. It seems easy to do.
We have several DLE 20's on our club trainers and yup, they are noisy, and no it's not the prop.
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 5
RE: Mufflers for gas engines - 9/17/2012 10:01 PM
acerc
Score: 221
Status: online
J-Tec also has silencer's.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to opjose)
       Post #: 6
RE: Mufflers for gas engines - 9/18/2012 1:57 AM
crooked stripe
Score: 100
Status: offline
I will look deeper into some sort of muffler. I saw the muffler inserts from Syssa and I was going to buy but I found no size or price listed. I did see that If you bought one of  their motors you could purchase the inserts. I gave them a call and got nothing but an answering device. Hopefully tomorrow they will call. I will now look into J-Tech and see what I can find out. Thank you all for the response. I will post to let you know what I do. Thanks again, John
Hide Signatures
(in reply to acerc)
       Post #: 7
RE: Mufflers for gas engines - 9/18/2012 2:34 AM
acerc
Score: 221
Status: online
You could always do the steel wool up the pipe. I have one that way and it's quite as a mouse.
Robert
Hide Signatures
       Post #: 8
RE: Mufflers for gas engines - 9/18/2012 3:23 AM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: crooked stripe
I don't think the Syssa muffler with fit the DLE 20.
I used them as an example of one solution that works fairly well and does not look hard to replicate with a little light metal work.
Hide Signatures
       Post #: 9
RE: Mufflers for gas engines - 9/18/2012 3:29 AM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: acerc
I've seen several people recommend this...
I would like to try it but I have a nagging question for you.....
Steel wool ignites VERY EASILY ( just take a match to it and see ), and it doesn't need high heat for ignition. A small spark is enough to get it going if it is heated.
Given that the exhaust on a gas engine is basically a hot flame on the virge of going out, doesn't the steel wool ignite while in the muffler?
Have you ever looked at it or removed it after use?
Does it still feel and behave like Steel Wool after it has been removed, or has it turned into brittle oxidized metal?
I'm afraid of the latter getting back into the cylinder head accidentally.
If it does ignite I wonder if something thicker and less prone to ignite might work just as well, such as the heavier steel wire often used for drain traps?
The stuff sold for catching lint coming out of clothes washer hoses may do an even better job.
Hide Signatures
(in reply to acerc)
       Post #: 10
RE: Mufflers for gas engines - 9/18/2012 5:03 AM
tailskid
Score: 199
Status: offline
Isn't there some 'exhaust' direction and some 'blowback' INTO the engine with every stroke in a two stroke engine? Won't that suck the steel back into the engine?
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 11
RE: Mufflers for gas engines - 9/18/2012 6:09 AM
Mk23socom
Score: 118
Status: offline
quote:
ORIGINAL: opjose
quote:
ORIGINAL: acerc
I think he is leaving out a key piece of info here.. The steel wool that us as modelers are accustomed to using and seeing is mostly the very fine stuff used for buffing when weathering and things such as that.. At least that's my opinion about it. I used to use it alot as a kid but up until just now, totally forgot about the coarser grades of the steel wool. I THINK that is what he is refering to rather than the fine stuff that you may be thinking about. Otherwise, I agree with your concerns exactly.
Kirby C.
I gotta have more cowbell!
Hide Signatures
       Post #: 12
RE: Mufflers for gas engines - 9/18/2012 5:31 PM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: Mk23socom
Yup it would stand to reason that thicker steel wool requires a higher ignition temp, but I don't think the difference is excessive enough to warrant using steel wool in the muffler.
I'll need to test a thicker grade wool with a match to find out though.
I do wonder if those thick stainless steel meshes used for lint catches would be a much better solution.
Hide Signatures
(in reply to Mk23socom)
       Post #: 13
RE: Mufflers for gas engines - 9/18/2012 5:32 PM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: tailskid
Yes, especially if any of it combusts or corrodes...
Hide Signatures
(in reply to tailskid)
       Post #: 14
RE: Mufflers for gas engines - 9/18/2012 6:48 PM
Gray Beard
Score: 314
Status: offline
For a few bucks try a 17X6 Xoar prop on that little engine. Other then changing over to a pipe most everyone I fly with is using the stock muffler. They work fine as they are. Even a Xoar 16 inch should be better then the 15. You want a prop selection anyway and they are a bunch cheaper then a new muffler. The 17 may be just a tad big.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 15
RE: Mufflers for gas engines - 9/18/2012 7:55 PM
opjose
Score: 280
Status: offline
Yeah that's a good combo.
We have three Telemaster's with DLE 20's as our club trainers.
We tried the 17x6 prop on them but found that the engine is FAR too powerful for this 70-90 sized plane for training purposes... even with the throttle maxed out at 40%!!!!
Each landing cost us a prop too...
So we stepped down to smaller props, which of course made the engine louder with the higher RPMs.
Hide Signatures
(in reply to Gray Beard)
       Post #: 16
RE: Mufflers for gas engines - 9/19/2012 5:01 PM
bbbair
Score: 100
Status: offline
Hey Guys,
I just saw the same question & this answer the other day on a different thread - yours to consider...
From a fellow in Kansas City Mo;
On my DLE 20 I plan on finding some brass tubing that is a tight slip-fit into the exhaust stack, drilling a series of holes in the top of it, and then inserting it into the exhaust stack. I will secure the tube with a sheet-metal screw.
This will act as a baffle and increase the silencing effect. I noticed the DLE 20 muffler has no baffles and the exhaust can exit the engine and go directly down the pipe. This is likely why it has been described as a bit on the loud side. I will put in the stainless steel stuffing as well and that should take care of the sharp tones.
I have done this process for years and most bystanders have commented on a "mellow" tone. When I feel the need for speed and lots of noise, I get out one of my old Quickee's with a short pipe and have at it!
(The stainless steel stuffing used, is scouring pads and you can get it at hardware stores.)
What I plan to do is use the brass tubing and leave out the stainless steel wool on the first trial and add it IF REQUIRED.
It's Time to Kick the Tires and Light the Fires!
Hide Signatures
       Post #: 17
RE: Mufflers for gas engines - 9/19/2012 5:22 PM
opjose
Score: 280
Status: offline
Scouring pads use relatively fine steel wool, which easily combusts.
I don't think this is a good idea.
Hide Signatures
(in reply to bbbair)
       Post #: 18
RE: Mufflers for gas engines - 9/19/2012 6:28 PM
Gray Beard
Score: 314
Status: offline
Just adding in brass tube with holes drilled into it will quiet them down but also adds back pressure. The trick would be hitting the engines happy place where it doesn't harm the engines performance. I just got my new Tower catalog yesterday and saw Bisson is making mufflers for DLE engines. I thought of ths post right away. They don't have the 20 listed but if you phone them they may have them for the 20 but didn't make it into the catalog? Bisson mufflers have baffling and are very quiet. I use them often on glow engines. If they have them for the 20s that may be another way to go.
Hide Signatures
       Post #: 19
RE: Mufflers for gas engines - 9/19/2012 7:03 PM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: Gray Beard
Thanks for the info!
I guess we'll be calling them for our club trainer's engines.
Hide Signatures
       Post #: 20
RE: Mufflers for gas engines - 9/19/2012 8:51 PM
Gray Beard
Score: 314
Status: offline
Perhaps it's because of the very open area I fly from but I haven't noticed the DLEs being that loud? One fellow did have a big twin that was ear shattering one day, I knew he had just changed canisters and thought it was that but the next day it was quiet again, all he did was changed the prop to a different manufacture and it was quiet again. I just don't recall what the loud prop was and what brand he went to the next day.
Post up if Bisson has them for the 20 yet? There mufflers are real mufflers, not just open boxes.
Hide Signatures
       Post #: 21
RE: Mufflers for gas engines - 9/19/2012 9:15 PM
tailskid
Score: 199
Status: offline
We just had a DLE55 get a "NO FLY" because he was at 108 Db this last saturday...don't know what prop he was using, but I don't think he was even at full throttle (@10').
# 93 in Club Saito
Hide Signatures
       Post #: 22
RE: Mufflers for gas engines - 9/19/2012 9:17 PM
opjose
Score: 280
Status: offline
Personally I don't find them loud.
I think the higher pitch tone of the small engine tends to be more annoying, so people perceive that as an increased sound level.
Hide Signatures
       Post #: 23
RE: Mufflers for gas engines - 9/24/2012 2:20 AM
KWJ48
Score: 103
Status: offline
I'm loving my DLE 20 with a 17x6 JXF prop.
Here's a silencer from Valley View. I've bought from them before, good company to deal with.
http://www.valleyviewrc.com/estore/muffler-silencer-20cc-30cc-55cc-111cc.html#
PRO BRO #2567
Hide Signatures
       Post #: 24
RE: Mufflers for gas engines - 9/24/2012 6:53 PM
bbbair
Score: 100
Status: offline
...Post up if Bisson has them for the 20 yet? There mufflers are real mufflers, not just open boxes.
Here is what you are looking for;
http://www.bissonmufflers.com/en/muffler_search_results.html?engine_man=%3DDL&imageField.x=14&imageField.y=10
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
