Running 2 Brushless ESCs on 1 Reciver?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> Running 2 Brushless ESCs on 1 Reciver?
Page: [1]
Login
Running 2 Brushless ESCs on 1 Reciver? - 9/17/2012 10:46 PM
collector1231
Score: 148
Last Login: 5/24/2013
Status: offline
 Would this work using a Futaba Y Connector,or would I blow something, and what would i do with the Battery plug? I've turned into a speed freak and want to run 2 brushless motors in an rc car.
_____________________________
I may have 3 wheel drive and 1 wheel for brakes, but i''m still gonna win!
Hide Signatures
       Post #: 1
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/17/2012 10:51 PM
Haddi Taha
Score: 183
Last Login: 5/11/2013
Status: offline
Don't know, but sounds interesting. I am assuming that you don't want one big motor correct?
Thunder Tiger MT4- Hobbywing 4274sd 2200kv motor- Savox 1256tg Servo
Hide Signatures
(in reply to collector1231)
       Post #: 2
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/17/2012 10:56 PM
savagecommander
Score: 171
Last Login: 5/12/2013
Status: offline
y harness to the radio would work. run the battery connectors in parallel. did it on a twin engine flyer
Hide Signatures
(in reply to Haddi Taha)
       Post #: 3
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/18/2012 3:06 AM
collector1231
Score: 148
Status: offline
quote:
ORIGINAL: Haddi Taha
Absolutely correct.  I am planning to get a E-Maxx (original)and modify it for bl.
Hide Signatures
       Post #: 4
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/18/2012 3:33 AM
PetRock
Score: 100
Last Login: 5/23/2013
Status: offline
The Y-cable would work: but you may find installing 2 brushless motors in an E-Maxx doesn't give you great bang-for-your-buck. A single budget motor (example) is enough to flip it over backwards if you stab the throttle, and give you top speeds that you can't sustain due to ballooning tires and the high center-of-gravity allowing the chassis to wallow all over the place.
Maybe start with one brushless motor and see how it handles?
Example: Look at how this Savage Flux handles with a single brushless: your E-Maxx chassis and tires aren't going to be any more composed.
Hide Signatures
       Post #: 5
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/18/2012 1:07 PM
collector1231
Score: 148
Status: offline
quote:
ORIGINAL: PetRock
THanks, i might just have to consider using 1 motor! Would this one give me enouth speed and power?  http://www.hobbypartz.com/ezbrposycoc1.html
Hide Signatures
(in reply to PetRock)
       Post #: 6
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/21/2012 8:02 PM
Scottgir
Score: 125
Last Login: 5/21/2013
Status: offline
Yeah, Emaxx and Savage designs lend themselves to using a beefier single motor with a big ESC and most importantly a BIG battery.
What you're describing is how you make a Clod Buster brushless. Using a Y connector and yes it works.
Hide Signatures
       Post #: 7
RE: Running 2 Brushless ESCs on 1 Reciver? - 9/21/2012 11:49 PM
nitrosportsandrunner
Score: 296
Status: offline
the ezrun 80a system is good. The redcat 1/8 scale earthquake comes with it and runs on 4s and does over 40mph. flips onto its back if you peg the throttle.
There have beeen a few who ran duel VXL systems on an emaxx. but there is no real advantage to doing so. Twin smaller motors dont really provide more power or run cooler than a single bigger motor.
Same is true of the brushed. The twin 550 motors dont put out the same power as a single titan 775 motor.
The ezrun 80 or 150a systems will do the job and be easier to install.
And as mentioned above, get a good battery. 5000mah and at least 30c.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to Scottgir)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
