RE: Fleet Brotherhood    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Graupner Vintage glider- Amigo 4 - ARF
Seller:  cat-boi
Details:   $98.46   |  5/23/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: Fleet Brotherhood
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Fleet Brotherhood - 11/4/2012 2:02 AM
HOT COALS
Score: 100
Last Login: 5/23/2013
Status: offline
    STEVE , WHEN YOU ARE READY FOR SPRAY GUN.  GET THE ONE WITH MULTIPLE SETTINGS. IT WILL PAYOFF IN THE LONG RUN. NOT SURE WHICH ONE TO GET.  ASK  UR  AUTOBODY GUY.  IT DEPENDS ON HOW OFFTEN  U USE IT.   HANK # 20
Hide Signatures
(in reply to HOT COALS)
       Post #: 276
RE: Fleet Brotherhood - 11/4/2012 2:11 AM
retransit
Score: 125
Status: offline
The gun I use will give a pattern of about four inches down to almost nothing. It has three knobs on it to adjust pattern, fluid and pressure. I've been doing this for so long, I don't need to know what the pressure is because I Can feel it at the spray tip. I make an inital pressure adjustment at the compressor of 40 p.s.i. and go from there. The longer the hose, the less the pressure will be at the gun. That is why it is a good idea to have a small pressure gage mounted at the inlet to the gun. I have that setup on my larger spray guns, but I don't feel it's necessary on the smaller Kobalt gun I use frequently.
In the pics below, it shows the quart capacity cup guns I bought at various times at Sears over the last 45 years. The newest one is an HVLP gun. The other pic shows a cheap small gun I bought from Harbor Freight about 20 years ago and it is good enough for primer.
Bob
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
       Post #: 277
RE: Fleet Brotherhood - 11/4/2012 2:18 AM
retransit
Score: 125
Status: offline
The gravity feed gun in the picture at the right (with the plastic cup) in my post above is the Kobalt gun. It has all the adjustments you need for spraying models or if you like, furniture, etc. If you were painting a car, you would need something like that HVLP gun that I have. The Kobalt gun is about $40 and does a good job. No need to go overboard.
Bob
Club Saito #800
Hide Signatures
       Post #: 278
RE: Fleet Brotherhood - 11/4/2012 4:08 AM
smkrcflyer
Score: 105
Status: offline
I see Lowes has two.
http://www.lowes.com/ProductDisplay?partNumber=301339-47120-SGY-AIR87&langId=-1&storeId=10151&productId=3360952&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
http://www.lowes.com/ProductDisplay?partNumber=301329-47120-SGY-AIR88&langId=-1&storeId=10151&productId=3360948&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
Steve
Club Saito #638, Ultra Sport BH #67, Cub BH #71, Fleet BH #21, Spitfire BH #165
Hide Signatures
(in reply to retransit)
       Post #: 279
RE: Fleet Brotherhood - 11/4/2012 4:11 AM
smkrcflyer
Score: 105
Status: offline
Hear are some pictures of the elevator repair.
Click for fullsize
Click for fullsize
Steve
Hide Signatures
(in reply to smkrcflyer)
       Post #: 280
RE: Fleet Brotherhood - 11/4/2012 4:14 AM
smkrcflyer
Score: 105
Status: offline
I put some paint on a sample part I made. It looks like the color will be good with some primer under it.
Click for fullsize
Steve
Hide Signatures
       Post #: 281
RE: Fleet Brotherhood - 11/4/2012 4:20 AM
smkrcflyer
Score: 105
Status: offline
I do have another problem with the Fleet, finding a place to keep it. Between my son and I we have 14 planes but its a good problem to have. I'm sure I will make room for it.
Click for fullsize
Click for fullsize
Steve
Hide Signatures
       Post #: 282
RE: Fleet Brotherhood - 11/4/2012 4:27 PM
retransit
Score: 125
Status: offline
The gun for $37.96 has the air adjustment on the bottom of the handle, the $54.96 gun has it above the handle, below the fluid lever adjustment. I have the cheaper model, and after seeing the higher priced model, I like mine better because you can adjust the angle of the cup. The other model's cup looks like it is fixed.
I don't see any advantage to the higher priced model.
Bob
Club Saito #800
Hide Signatures
       Post #: 283
RE: Fleet Brotherhood - 11/4/2012 4:29 PM
retransit
Score: 125
Status: offline
Use of walls, ceilings for storage?
Bob
Club Saito #800
Hide Signatures
       Post #: 284
RE: Fleet Brotherhood - 11/4/2012 4:30 PM
retransit
Score: 125
Status: offline
quote:
ORIGINAL: smkrcflyer
Steve, what type of paint is that?
Club Saito #800
Hide Signatures
       Post #: 285
RE: Fleet Brotherhood - 11/4/2012 7:40 PM
smkrcflyer
Score: 105
Status: offline
The paint is exterior semi gloss latex. I know its not fuel proof so I'm going to experiment with clear Lusterkote on my sample part.
Steve
Hide Signatures
       Post #: 286
RE: Fleet Brotherhood - 11/6/2012 12:49 AM
smkrcflyer
Score: 105
Status: offline
Thanks for the info on the sprayer.
I have the new rudder built. I used two pieces of 3”x ¼” for the lower part then I put a piece of 1/4x1/2 along the top and added another 3”x1/4 with the grain running the other way too make the top. This should be strong and with the grain running in different directions it should not warp. Now I need to cut holes to reduce the weight. Does anyone know the rule for spacing the holes? I read someplace that it should be grater then the thickness of the wood.
Click for fullsize
Click for fullsize
Steve
Hide Signatures
       Post #: 287
RE: Fleet Brotherhood - 11/6/2012 10:30 PM
retransit
Score: 125
Status: offline
Steve, I don't think you have to worry about saving weight by cutting holes. I'd leave it and use 1/16 balsa for simulated ribs.
Bob
Club Saito #800
Hide Signatures
       Post #: 288
RE: Fleet Brotherhood - 11/6/2012 11:56 PM
smkrcflyer
Score: 105
Status: offline
That's a good idea. I'll hold off cutting holes until I balance it and if its tail heavy then I can cut holes as needed. I can move on to the N struts now they did not come with the plane.
Steve
Hide Signatures
       Post #: 289
RE: Fleet Brotherhood - 11/9/2012 12:12 AM
Fleet
Score: 100
Last Login: 11/14/2012
Status: offline
Re-subscribing. Don't ask, its a long story.
Ray W.
Fleet Brotherhood #7
Hide Signatures
       Post #: 290
RE: Fleet Brotherhood - 11/9/2012 12:48 AM
knucklebutt
Score: 100
Last Login: 5/22/2013
Status: offline
Careful with that "Lustercoat" We reffer to it as "Lustercrap" at our field. One guy used it on his 1/4 scale cub, sitting in his van on a hot day it ran (yes ran like dripped) and turned brown
Denis (some number between 3 and 6 I think)
Hide Signatures
       Post #: 291
RE: Fleet Brotherhood - 11/9/2012 3:06 AM
retransit
Score: 125
Status: offline
Denis, you're #3.
About Lustrekote; the only problem I had here in Florida is that it blushed on humid days. (Isn't that all the time?) Also, too much buidup and it will crack.
You live too close to the sun Denis. I know, my son lives in Chandler.
Bob
Club Saito #800
Hide Signatures
(in reply to knucklebutt)
       Post #: 292
RE: Fleet Brotherhood - 11/9/2012 12:15 PM
smkrcflyer
Score: 105
Status: offline
Is there a better clear that’s fuel proof that can go over latex paint?
Steve
Hide Signatures
       Post #: 293
RE: Fleet Brotherhood - 11/9/2012 1:22 PM
retransit
Score: 125
Status: offline
I don't know. Never shot clear over latex.
Bob
Club Saito #800
Hide Signatures
       Post #: 294
RE: Fleet Brotherhood - 11/9/2012 2:46 PM
knucklebutt
Score: 100
Status: offline
Yes I now use house paint (Latex) on all my aircraft: I have been clear coating with "warbird Colors Satin" Its water based and sprays very well
http://www.warbirdcolors.com/welcome.asp
Denis #3
Hide Signatures
       Post #: 295
RE: Fleet Brotherhood - 11/9/2012 2:47 PM
knucklebutt
Score: 100
Status: offline
quote:
ORIGINAL: retransit
Denis, you're #3.
Bob
Bob is your son active in R.C. should i know him: I live right across the street from Chandler Airport
Hide Signatures
       Post #: 296
RE: Fleet Brotherhood - 11/9/2012 3:07 PM
smkrcflyer
Score: 105
Status: offline
I don't think you can get clear coat from Warbird anymore. On the web site it has the following;
I am currently experiencing a manufacturing issue which has caused me to be out-of-stock on several key colors, including primer & clear coat. I am working with the manufacturer to fix the problem.
I also read on another forum that they may not be able to supply clear coat in the new formula and most people are using gas now and don't need it.
Steve
Hide Signatures
       Post #: 297
RE: Fleet Brotherhood - 11/9/2012 3:15 PM
knucklebutt
Score: 100
Status: offline
Yeah I saw that Hummmm: ALSO I have used "Rustoleum" clear from a rattle can when I re-built and painted some wheel pants on a friends GeeBee. Its gas so there wasn't a problem. I have used Rustoleum on several small projects with very good results.
Denis #3
Hide Signatures
       Post #: 298
RE: Fleet Brotherhood - 11/9/2012 8:20 PM
Fleet
Score: 100
Status: offline
Call me really old fashion but I'm sticking with Randophs nirtate and butyrate dopes and color. Since my 1/3 scale Fleet site has been largely erased of photos, I'll start here with some new.
Lower wing with "Get Stencils" roundells and numbers. Covered with Coverite and lots of dope to fill the weave and voila! A huge dollar bill to cover, dope and paint this bird.
So far , about a gallon of thinned clear buty with 1/2 gallon of thinned AN orange/Yellow. Lots of retarder used which is a Godsend.
I had to order a 2nd quart of color and my fears were confirmed when a different batch was pulled and the newer is a shade or so darker. I like the darker but now its more painting.
I opted not to bother my buddy who has an EPA and State Cert. paint booth. Can't really call it a booth as he puts city busses in it as well as FedEX trucks.
Anyway, its all brush work for that scale appearance. Nothing goes more un-noticed than scale brush strokes. tongue in cheek.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 299
RE: Fleet Brotherhood - 11/9/2012 9:15 PM
retransit
Score: 125
Status: offline
Nope, he's not an active RC'er.
Bob
Club Saito #800
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
