RE: Fleet Brotherhood    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: Fleet Brotherhood
Page: <<   < prev  15 16 17 18 [19] 20 21 22 23 24   next >   >>
Login
RE: Fleet Brotherhood - 1/27/2013 3:39 PM
dabrown
Score: 100
Last Login: 6/19/2013
Status: offline
Thanks Bob and Hank,
I'll try the pin on a stick method with Elmers today. The drops will be going onto the pink tape which has one coat of dope on it and has been sanded. Hope it goes as easy as you make it look!
Now have everything covered Koverall applied with Stix-it, one coat non-taughtening Randolph butyrate dope, hair setting pinked tape, 2nd coat dope. Believe it's ready for color; fabric weave will still show. Won't be able to spray for a while until it warms up.
BTW, I was able to cover the top and sides with one piece of Koverall, except for the top front deck. I'll do that as a separate piece. We discussed this before as a way to avoid having to trim at the shallow angle between the top and sides. Koverall can shrink/stretch quite a bit but I wasn't able to take up all the excess at the front top.
Dave
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Fleet Brotherhood #10
Hide Signatures
(in reply to retransit)
       Post #: 451
RE: Fleet Brotherhood - 1/27/2013 3:59 PM
Kinner
Score: 100
Last Login: 6/20/2013
Status: offline
Here is a shot of a real Fleet with noted rib stiching which actually are screws but the spacing is good.   Note that spacing doubles when applied withing the prop wash.  Normal practice per Fed Regs.
On my 1/3 scaler, spacing was about 1/2 inch apart.
Under the wing walk antiskid, is a light corrigated metal sheet under the fabric.   I also noted that the ailerons are stitched and ribs are not as plans.
Hope this helps.   If you get good at rebuilding, I'll send you my Fleet.
Ray W.
Click for fullsize
Click for fullsize
Fleet Brotherhood #7
Hide Signatures
(in reply to dabrown)
       Post #: 452
RE: Fleet Brotherhood - 1/27/2013 7:19 PM
skipb
Score: 110
Status: offline
Does anyone have a Concept Fleet construction manual they could copy for me? Let me know cost & postage.
Skipb
Hide Signatures
(in reply to Kinner)
       Post #: 453
RE: Fleet Brotherhood - 1/27/2013 7:51 PM
HOT COALS
Score: 100
Last Login: 5/31/2013
Status: offline
   BOB, That was only a example. they do come at the right spacing. They come in a plastic roll. Also comes in crome plastic.  HANK  # 20
Hide Signatures
       Post #: 454
RE: Fleet Brotherhood - 1/27/2013 7:56 PM
HOT COALS
Score: 100
Status: offline
I can make you a copy skipb. No chrg.  HANK #20   817-691- 4411 .
Hide Signatures
(in reply to HOT COALS)
       Post #: 455
RE: Fleet Brotherhood - 1/27/2013 8:17 PM
HOT COALS
Score: 100
Status: offline
    Dave, If your not going to paint soon. I would cover your parts with saran wrap,to keep the dust off.  I also do this to my planes if I am not going to fly them for a while.  Also will keep out the bees,hornets, wasps. which is a big problem for me here in TX . I had to  recover 2 of my fleet's .  HANK # 20.
Hide Signatures
       Post #: 456
RE: Fleet Brotherhood - 1/27/2013 9:52 PM
Kinner
Score: 100
Status: offline
From Sam's Club or equiv, I bought a box of industrial garbage can liners in clear.  I wraped my 1/4 Cub wings, fuse and tail feathers after I framed it up.  20 years later and I uncovered it all last week after I lost my Fleet.
Absolutely no dust, bugs, roach droppings, etc.  Bags had that much dust on the outside and nothing got through.  I don't have mice so it never came to that.   Maybe the 20 gallon or larger bags would do you well.
Ray W.
Hide Signatures
       Post #: 457
RE: Fleet Brotherhood - 1/27/2013 10:17 PM
retransit
Score: 125
Last Login: 6/16/2013
Status: offline
When you fly it, some of the dust comes off.
Bob
Club Saito #800
Hide Signatures
       Post #: 458
RE: Fleet Brotherhood - 1/28/2013 1:13 AM
Kinner
Score: 100
Status: offline
Maybe that is all that holds it together.
Ray W.
Hide Signatures
       Post #: 459
RE: Fleet Brotherhood - 1/28/2013 1:35 AM
dabrown
Score: 100
Status: offline
My problem has been mice. Hungry ****s with a balsa appetite. For stored airplanes, I put tape over any openings. They like to get inside and feast on your ribs, etc. Also had issues with wasps and cleaning mud nests out of wings.
dave
Hide Signatures
       Post #: 460
RE: Fleet Brotherhood - 1/29/2013 7:04 PM
skipb
Score: 110
Status: offline
Hank-
Sent pm with instructions and above all else thank you.
Skipb
Hide Signatures
       Post #: 461
RE: Fleet Brotherhood - 1/30/2013 3:09 AM
retransit
Score: 125
Status: offline
I had three aditional flights today to get the trimming sorted out. At the end I was loading up the fuselage and I struck an overhead shelter upright with the elevator.
I have to strip the covering, repair and paint the left elevator. Not at all something I wanted to do since I want to feel comfortable with the plane before our Giants event.
Bob
Click for fullsize
Club Saito #800
Hide Signatures
(in reply to skipb)
       Post #: 462
RE: Fleet Brotherhood - 1/30/2013 4:41 PM
dgliderguy
Score: 115
Status: offline
Bob- This is so like me! More than half the damage my models incur happens before I even get them out on the runway.
Be sure to check your servo gears. That's one I've missed before.
Glider junkies creed: No glider, no lift, no reason to live.
Hide Signatures
       Post #: 463
RE: Fleet Brotherhood - 1/30/2013 4:46 PM
retransit
Score: 125
Status: offline
Thanks for the servo check reminder.
Bob
Club Saito #800
Hide Signatures
(in reply to dgliderguy)
       Post #: 464
RE: Fleet Brotherhood - 1/30/2013 5:41 PM
knucklebutt
Score: 100
Status: offline
Ive done that to my rudder a few times now: you think I would leard (errr Learn)
Denis
Hide Signatures
       Post #: 465
RE: Fleet Brotherhood - 1/30/2013 6:15 PM
Kinner
Score: 100
Status: offline
The older I get, the narrower my vision becomes...it seems.   Not to mention, left is right and right is left.   Common cause for old guys to get dumb thumbs turning a short final with model Fleets.
alas
Ray W.
Hide Signatures
(in reply to knucklebutt)
       Post #: 466
RE: Fleet Brotherhood - 1/30/2013 7:13 PM
retransit
Score: 125
Status: offline
One day with my first Fleet I made a sudden stop to avoid flattening a squirrel and my plane jumped chocks in my van and came rushing forward, tail first, into the back of my seat................rudder fix!
Bob
Club Saito #800
Hide Signatures
       Post #: 467
RE: Fleet Brotherhood - 1/30/2013 7:43 PM
Kinner
Score: 100
Status: offline
I'm thinking that biplanes may not be for me.
I'm cramming my NE-2 together so as to bone up on flying skills I need from such a long layoff.   So, the 1/3rd scale will have better chances of surviving my stick work.
Ray W
Hide Signatures
       Post #: 468
RE: Fleet Brotherhood - 2/1/2013 4:02 AM
retransit
Score: 125
Status: offline
I finished the structural repair of my Fleet's elevator. Next is re-covering.
I added diagonal braces to reduce the tendency of the structure to warp. We'll see if it actually works.
Bob
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Club Saito #800
Hide Signatures
       Post #: 469
RE: Fleet Brotherhood - 2/4/2013 1:52 AM
dabrown
Score: 100
Status: offline
I went to Home Despot and found some aluminum duct material. It's a 4 inch duct, used for dryer vents, I think. $3.88 per sheet which I think is 12 in by 24 in. I bought 2.
The larger piece in the photos covering the cockpit I epoxied in place. The rear panel and the headrest are held in place with screws. Took me 5 tries to do the headrest. Next time I'll buy 4 sheets.
You can cut this stuff with scissors. I used two boards with the alum in between to bend the edges hard to see in the pics it was tricky.
Dave
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 470
RE: Fleet Brotherhood - 2/4/2013 2:51 AM
retransit
Score: 125
Status: offline
Nice work, Dave.
Bob
Club Saito #800
Hide Signatures
       Post #: 471
RE: Fleet Brotherhood - 2/4/2013 5:42 PM
Mein Duff
Score: 110
Status: offline
Nice bends on that head rest Dave.... what thickness is that material...looks like about .5 mm
Fleet Brotherhood #5
Half A Wing, Three Engines and A Prayer
Hide Signatures
       Post #: 472
RE: Fleet Brotherhood - 2/5/2013 4:30 AM
HOT COALS
Score: 100
Status: offline
  I am now working on a new fleet for a friend. Who bought a kit from me.  when I build the stab. inst. call for 4 pcs balsa . What I do I take 2 1/16 ply . Sandwich in between. the balsa. I found this limited the warpage.  In the fire wall sect. I use triangle aluminum 1/2 inch instead of the hard wood. With  1/2 by 3/8 wood srews taped in.  HANK #20
Hide Signatures
(in reply to Mein Duff)
       Post #: 473
RE: Fleet Brotherhood - 2/5/2013 4:45 AM
HOT COALS
Score: 100
Status: offline
  Good photos  Dave, I used the same stuff on my stinson sr 9. Which is still incontuction stage for the moment. I used 7mm which is very thin. . Which also can be used on leadining edgers .  Home depot sells rubber wasers, that I use for motor vibration.   HANK # 20.
Hide Signatures
       Post #: 474
RE: Fleet Brotherhood - 2/5/2013 4:57 AM
HOT COALS
Score: 100
Status: offline
  I am going to take photos in contuction steps . How I put my fleets together.  I can't complain they will be around for long time.  What I will need is some one address.  to post my photos.  HANK #20.
Hide Signatures
       Post #: 475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
