P90-RXi    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> P90-RXi
Page: [1]
Login
P90-RXi - 9/18/2012 3:09 AM
Guillermo Ibanez
Score: 100
Last Login: 5/20/2013
Status: offline
HI:
When is suppose to be released this new turbine?
I just paid for a P-100 RX but now that I saw the P90 RXi on the forum (Airpower 2.012 thread), I like the P90 because it has more thrust.
Can you tell me the turbine specifications for compare with the P-100?
I saw also that the P90 is cheaper than the P-100?
Will this mean that P-100 is better choice?
_____________________________
Guillermo Ibanez
Hide Signatures
       Post #: 1
RE: P90-RXi - 9/18/2012 10:56 AM
asimace
Score: 100
Last Login: 4/24/2013
Status: offline
I think it mainly depends on the airframe you are going to use it in.
The new P90-RXi looks like an evolution of the P80 as per size and weight.
The new features are the BUS connection capability, internal temp sensor, fuel pump, valves and kerosin start so the connections are very simple, one lead and one fuel tube.
The P100 is much smaller and lighter than the P90-RXi but has higher RPM, both have similar thrust.
Mauri
Hide Signatures
(in reply to Guillermo Ibanez)
       Post #: 2
RE: P90-RXi - 9/18/2012 8:27 PM
Guillermo Ibanez
Score: 100
Status: offline
Thanks Mauri
Need to see specifications to take a decition.
Hope Jetcat answer soon about when is going to be released the P90-RXi, cost, weight, fuel consumpion, etc.
BRG
Guillermo Ibanez
Hide Signatures
(in reply to asimace)
       Post #: 3
RE: P90-RXi - 9/21/2012 4:04 PM
modtron
Score: 100
Last Login: 5/21/2013
Status: offline
Comparison details from the new 2012 JetCat catalogue ........
P80
Diameter - 112.00 mm
Length - 315.00 mm
Weight - 1360 gms
Idle - 35000 rpm
Max - 125000 rpm
Thrust - 97 N
Temp range - 510 /700
Fuel Flow - 95 / 275 ml/min
P90RXi
Length - 300.00 mm
Weight - 1435 gms
Idle - 35000 rpm
Max - 130000 rpm
Thrust - 105 N
Temp range - 490 /690
Fuel Flow - 95 / 370 ml/min
P100RX
Diameter - 97.00 mm
Length - 235.00 mm
Weight - 1080 gms
Idle - 40000 rpm
Max - 154000 rpm
Thrust - 100 N
Temp range - 490 /700
Fuel Flow - 80 / 390 ml/min
As for availability - at JetPower, they were saying by the end of this year - 2012.
modtron
Oxford UK
Hide Signatures
       Post #: 4
RE: P90-RXi - 9/22/2012 9:01 AM
BaldEagel
Score: 118
Status: offline
From the spec of the P90 Rxi above it looks like JetCat still have a lot of P80 parts to get rid of. LOL
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to modtron)
       Post #: 5
RE: P90-RXi - 9/22/2012 9:53 AM
modtron
Score: 100
Status: offline
The P80 will be dropping in price very soon and they have plenty of parts for back up for many years to come.
modtron
Oxford UK
Hide Signatures
(in reply to BaldEagel)
       Post #: 6
RE: P90-RXi - 9/22/2012 3:15 PM
BaldEagel
Score: 118
Status: offline
If P80 comes down any more, it could be the first turbine to be offered at under £1000.00 now that would be a first and it would get rid of the spare parts very quickly.
Mike
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
