Gas mix for a 35cc Quadra    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Gas mix for a 35cc Quadra
Page: [1]
Login
Gas mix for a 35cc Quadra - 9/18/2012 1:54 PM
leerider
Score: 100
Last Login: 4/17/2013
Status: offline
I have a Quadra 35cc motor and the manual says to mix the gas 85% methanol 10% oil and 5% nitro how would you mix up 2 gallons?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Gas mix for a 35cc Quadra - 9/18/2012 3:23 PM
porthole200
Score: 100
Last Login: 5/15/2013
Status: offline
I have a Quadra 35 that I have been flying for several years now. The fuel mix is just like a chainsaw engine. 16 to 1, or 20 to 1 gasoline to oil mix. I have no idea where you got that picture from. I have the original owners manual and it lists the mixtures as I stated above. Hope this helps.
Hide Signatures
(in reply to leerider)
       Post #: 2
RE: Gas mix for a 35cc Quadra - 9/18/2012 3:29 PM
leerider
Score: 100
Status: offline
Thats out of the Quadra manual
Hide Signatures
(in reply to porthole200)
       Post #: 3
RE: Gas mix for a 35cc Quadra - 9/18/2012 3:30 PM
leerider
Score: 100
Status: offline
what size prop are you running
Hide Signatures
       Post #: 4
RE: Gas mix for a 35cc Quadra - 9/18/2012 3:31 PM
jetmech05
Score: 133
Last Login: 5/25/2013
Status: offline
I am confused here is it gas or glow? For glow as you posted in the pic, it would be 25.6 oz of oil to 2 gallons, and 12.8 oz of nitro.....mixing your own fuel is expensive, why not use a commerical brand? For gas run a good synthetic oil after break in at 40:1, during break in run a good ashless oil like Lawn Boy at 32:1. I've started running ethonol free.
Hide Signatures
       Post #: 5
RE: Gas mix for a 35cc Quadra - 9/18/2012 5:49 PM
scale only 4 me
Score: 319
Status: offline
There were Glow Conversions for the early Gasers, that might be what he has.
quote:
ORIGINAL: leerider
It's just Math,, per gallon below, double for 2 gallons
85% of 128oz = 108.8 oz. Meth.
10% = 12.8 oz oil
5% - 6.4 oz nitro
Good luck
Hide Signatures
(in reply to jetmech05)
       Post #: 6
RE: Gas mix for a 35cc Quadra - 9/18/2012 6:27 PM
bikerbc
Score: 116
Status: offline
I have several Quadras and have run them for years..They are just the same as any of our other two cycle motors like our chain saws or our weed whackers . They run on mixed gas...I like to use Amsoil at about 40 to 1 .. I have never had a problem ..Everybody will have their own favorite mix and that just goes to show it's not all that critical...I also run DLE20's and DLE'30s and I and I am running a MVVS 35 along with two Zenoah G62's and they all run on the same mix along with the dirt bikes and the lawn mower etc etc etc... and they are all running fine..They will out last me...I do really try to keep my gas fresh and clean...I keep it as cool as I can and I store it in the dark . I have a locked storage shed detached from the house where I can keep my gasoline jugs...I would suggest just mixing up two gallons of mix gasoline with what ever mix synthetic oil you fancy at arond 35 to 1 ... One thing I have been told is that you are not supposto ever use water cool oil mix in an air cool motor . I do not know why ..So dont use your outboard motor gas in your plane.....
_____________________________
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
       Post #: 7
RE: Gas mix for a 35cc Quadra - 9/18/2012 6:59 PM
leerider
Score: 100
Status: offline
I'm not real sure what engine I have I"m told its a 35 but I don't know how to tell what engine I have the only thing I have found is on the S/N the first # is a 3 which I read that the 3 means its a 35cc here are some pic if it helps
also should I just use a 20: to 1 or use the 85% of 128oz = 108.8 Meth 10% = 12.8 oz oil 5% - 6.4 oz nitro
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to scale only 4 me)
       Post #: 8
RE: Gas mix for a 35cc Quadra - 9/18/2012 7:24 PM
OldScaleGuy
Score: 120
Last Login: 5/24/2013
Status: offline
Yours is a gasoline engine. The picture is the fuel mixture for a glow engine. There are many discussions regarding types of oils and ratios. Personally i would go with a mid grade gasoline and Red Line oil at 40:1, that is 3.2 ounces of oil for every gallon of gasoline. However, any good oil at 32:1 to 40:1 will be fine. For example Lawn Boy or Stihl, etc. Do not add any other oils or nitro.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 9
RE: Gas mix for a 35cc Quadra - 9/18/2012 7:36 PM
Steve Percifield
Score: 108
Status: offline
I agree with oldscaleguy. This is a gasoline engine not a glow engine. It runs just like your weedeater, leaf blower, chain saw , or what ever. Use a gasoline/oil mix. 40-1 is fine. 32-1 is better, (IMO). Do not run alcohol through this engine.
BTW, I had several Quadra's when they popular several years ago. I think yours is a 42 . I don't remember my 35's looking like that, the crankcase and flywheel are different than I remember.
steve
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 10
RE: Gas mix for a 35cc Quadra - 9/18/2012 8:52 PM
leerider
Score: 100
Status: offline
Thanks for the help, if anyone can tell me how to find out for sure what size it is that would be great thanks again for all the help
Hide Signatures
(in reply to Steve Percifield)
       Post #: 11
RE: Gas mix for a 35cc Quadra - 9/18/2012 9:49 PM
Mk23socom
Score: 118
Status: offline
Yes indeed, you won't have any issues if you run a decent weedeater/chainsaw mix in that engine. Most guys like that 30:1-40:1 range. I am a little more "aggressive" with my mixtures.. it has a lot to do with the fact that my pops has extensive small engine experience and after talking about a recommendation given to me by another modeler, who's opinions I respect immensely, we both decided that 100:1 Amsoil Sabre was what we would use.. I think all the info stated previously is all sound advice so you should be good!!
Kirby C.
I gotta have more cowbell!
Hide Signatures
       Post #: 12
RE: Gas mix for a 35cc Quadra - 9/18/2012 10:59 PM
Steve Percifield
Score: 108
Status: offline
http://www.bennettbuilt.com/Quadra.html
Bennett was the USA Quadra rep. They still have parts and support. Send your question and pictures to them. If anyone can ID your engine , thay can.
steve
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to Mk23socom)
       Post #: 13
RE: Gas mix for a 35cc Quadra - 9/19/2012 12:21 AM
scale only 4 me
Score: 319
Status: offline
Actually that looks like the q52,, the case splits differently than the 35,40,42
Look at the photos at the Link Steve posted
Hide Signatures
       Post #: 14
RE: Gas mix for a 35cc Quadra - 9/19/2012 3:45 PM
pappyd6
Score: 100
Status: offline
The Quadra 35 and 42 were rear exhaust.  This is probably the 52 with the side exhaust.
Hide Signatures
       Post #: 15
RE: Gas mix for a 35cc Quadra - 9/19/2012 4:11 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
for the older Q motors 32:1 penz air cooled is what I use on my 65 75 and 100's have had no problems for 18 yrs.all are still like new.I fly 3 to 4 times a week.
Hide Signatures
(in reply to pappyd6)
       Post #: 16
RE: Gas mix for a 35cc Quadra - 9/19/2012 4:54 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: leerider
You may be able to tell whether it's a petrol or alky engine by looking at the carb throat. If the carb venturi has about a 16-20mm opening, it's probably a gas engine. If it's much smaller, say around 10mm, it's probably an alky. Either fuel can be run on ignition so that doesn't buy you anything
Regards,
MattK
Hide Signatures
       Post #: 17
RE: Gas mix for a 35cc Quadra - 9/19/2012 5:59 PM
Gray Beard
Score: 314
Status: offline
I ran 32-1 in both the Quadra and Zinoah. I used the same mix for my chain saws so I never had old gas mixed, it always got used up. The Quadras and Zinoahs are still great engines but they weigh a lot more then the newer engines and don't produce the same power to weight. I still use the Zinoah G-62 when I have a bigger plane on hand. I have a place I can still get some parts for both, B&B or Bennett as mentioned. www.bennettbuilt.com I bought a spring starter for my G-62 about two years ago from them. The spring starter is a life saver as I have gotten older. I'm able to start it with just the one turn and release instead of flipping the prop and hurting the old arm. They have a bunch of cool stuff for these older engines. There phone # is 574-277-0499. I have there 2008 catalog on hand.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to MTK)
       Post #: 18
RE: Gas mix for a 35cc Quadra - 9/19/2012 6:03 PM
leerider
Score: 100
Status: offline
I just talked to B&B and the guy said its a 50 or 52
Hide Signatures
(in reply to Gray Beard)
       Post #: 19
RE: Gas mix for a 35cc Quadra - 9/21/2012 12:08 PM
leerider
Score: 100
Status: offline
The prop that came on the motor is a 18-6 so I changed it to a 20-8 do yall think this will make the plane fly better with the 18-6 it had no balls
Hide Signatures
       Post #: 20
RE: Gas mix for a 35cc Quadra - 9/21/2012 6:04 PM
Gray Beard
Score: 314
Status: offline
Yes, a 20 inch is more in line with the engine. 20X 8 is good but if you can borrow a couple of props with a different pitch you could test others. I use the Xoar 20X8 and 20X6 a lot on my Brison 40cc and both work very well. A Lot depends on the plane type too. I have only used that engine in stunt planes like the Extra and Sukhoi. It will be going back into another Sukhoi again next year.
I say borrow a couple of props because once you get into that size the cost of a prop really goes up and testing becomes an expensive proposition. At my field we borrow and loan quite a bit. As long as the shaft size is the same it works out. I bought several 18 inch props and I'm stuck with them. The just didn't work well for me.
Hide Signatures
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.860RCU1
