Brake help pls    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Brake help pls
Page: [1]
Login
Brake help pls - 9/19/2012 1:38 PM
-Goat-
Score: 100
Last Login: 5/16/2013
Status: offline
  Mornin All, ...I've got an old Tamiya Nitrage that I'm tryin to keep runnin, and now stoppin. The brake is goin south and as Tamiya no longer has the parts, I need to find a brake rotor and discs. The Outside diameter of the rotor is 40mm,it is 1mm thick and the center is shaped like the center output dogbone cup(flat on 2 sides and round on the other sides). Does anyone know of other brake rotors that have similar configurations? I think the HPI Savage pads will work. I've found rotors with the right center but the diameter is too small. Any help would be greatly appreciated.
-Goat-
Hide Signatures
       Post #: 1
RE: Brake help pls - 9/19/2012 6:34 PM
Anthoop
Score: 121
Last Login: 5/17/2013
Status: offline
Is this the correct part? - http://www.fusionhobbies.com/Tamiya-Nitrage-5-2-Front-Brake-Set-p/ta53981.htm
_____________________________
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to -Goat-)
       Post #: 2
RE: Brake help pls - 9/19/2012 7:36 PM
-Goat-
Score: 100
Status: offline
Thank you for the reply Anthoop, I have looked into that before and it is the entire brake system and costs over 30 US dollars. I'm looking for a more readily available and cheaper solution as I only need the rotor.
-Goat-
PS - the rotor could have a center hex pattern of no more than 12mm and overall diameter of 40mm.
Hide Signatures
(in reply to Anthoop)
       Post #: 3
RE: Brake help pls - 9/20/2012 5:53 PM
Anthoop
Score: 121
Status: offline
Another idea would be to see if you could find some washers of the correct diameter and file the centre hole to fit (make the hole 12mm by drilling first..then file the flats), you could use either fibre or steel washers...as long as you can find the right diameter.
Sorry I can not help with a ready made match, everything I have is much smaller.
Hide Signatures
       Post #: 4
RE: Brake help pls - 9/20/2012 11:03 PM
-Goat-
Score: 100
Status: offline
Wow, that is a great idea Anthoop. Guess I'll head down to Fastenall and see what they have and then break out the ole Dremel tool. Thanks for your help, it is much appreciated.
-Goat-
Hide Signatures
       Post #: 5
RE: Brake help pls - 9/21/2012 5:15 PM
Anthoop
Score: 121
Status: offline
Let us know how it turns out.
Be sure to clamp the washer when drilling/dremeling(?)
Hide Signatures
       Post #: 6
RE: Brake help pls - 9/28/2012 4:43 PM
-Goat-
Score: 100
Status: offline
Everything went pretty good. I had some metal from a friends shop so I used a hole saw and made my own disc (and shed no blood). I was able to dremel out the center to a reasonable reproduction of the original in less than 1/2 hour. The HPI Savage brake pads #87150 fit perfectly and the system actually works better than the original system. Thanks for your input Anthoop, saved me some money and I actually enjoyed working it all out.
-Goat-
Hide Signatures
       Post #: 7
RE: Brake help pls - 9/28/2012 5:47 PM
Anthoop
Score: 121
Status: offline
Good man. Glad you did not lose any blood in the procedure.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
