New project boat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> New project boat
Page: [1]
Login
New project boat - 9/20/2012 2:29 AM
damfurst
Score: 100
Last Login: 4/28/2013
Status: offline
Got one of those Syma Blue Whale 22" boat the other day. Took some video of it running stock on both a 1800mah 35c 2s and 1800mah 35c 3s yesterday. Plan on putting some brushless motors in it, a rudder, and hobby grade radio. I think it has some potential even though the hull is very heavy..
http://youtu.be/qVCHid_FXiE
Hide Signatures
       Post #: 1
RE: New project boat - 9/25/2012 4:11 AM
sundogz
Score: 129
Last Login: 5/22/2013
Status: offline
Wes, there is a thread on OSE on modding this boat. It might have some useful info in it. Here's the link.
_____________________________
Arpro Mono,Genesis,Tenshock Essenz, PowerJet Viper,ABC Jet Ski,TearInto Jet Sprint, Legend & Discovery Sailers, JetCat proto
Hide Signatures
(in reply to damfurst)
       Post #: 2
RE: New project boat - 9/25/2012 5:26 AM
damfurst
Score: 100
Status: offline
quote:
ORIGINAL: sundogz
Thanks Dave I'll have a look and maybe post too.
Hide Signatures
(in reply to sundogz)
       Post #: 3
RE: New project boat - 9/26/2012 1:07 AM
SkR8Pn
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: damfurst
Big difference between 2s and 3s... I like the boat.
Do you plan on changing the prop also?
I have no idea about prop boats so i'll keep on checking in to see what you get up to.
Ja
SCX10 Truggyx2, Wraith
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 4
RE: New project boat - 10/14/2012 3:15 AM
damfurst
Score: 100
Status: offline
No I don't plan to change the props skr8pn. Partly because these props screw on one right handed the other left handed so I would have to change the prop shafts also. Might have to if the props won't stand the brushless motors.
Have been working on mounting a rudder which went better than expected. I waterproofed a servo but haven't got it mounted yet. The motors and esc's showed up from Hobbyking this week so have been busy soldering on them. Found out that the Birdie 50a esc's only work with stick radios, so I will either have to buy another pistix from Ose or switch to my 4 ch Tactic which I just got another rx for. I think I'll do the latter.
After gutting the electronics and motors I tried fitting the new motors into the mounts. Discovered that I had to turn the mount themselves 180 around and also cut the farthest back support that was there for the other motors. The motors I'm using are 2632 3400kv outrunners. They have 2.3mm shafts so I can use the drive system that they came with. Here are some pics of my progress.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by damfurst -- 10/14/2012 3:51 AM >
Hide Signatures
(in reply to SkR8Pn)
       Post #: 5
RE: New project boat - 10/17/2012 4:08 AM
damfurst
Score: 100
Status: offline
I've been able to get the motors mounted using the mounts that came with the boat. I had to however use a dremel to modify them a little so that motors fit into them straight. Mounted the servo in the middle back of the hull with a couple of pieces of aluminum angle that were bolted to a servo mount and then shoe gooed to the bottom of the hull. Also, mounted both 50A esc's by the motors on the inside wall of the hull. Next to work on the water pickups in the hull.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by damfurst -- 10/17/2012 4:54 AM >
Hide Signatures
       Post #: 6
RE: New project boat - 10/20/2012 3:24 AM
damfurst
Score: 100
Status: offline
I tried something different for me in doing the water pickups. I mounted them through the bottom of the hull using some old scraps of brass tubing that I angled slightly with a dremel. I then drilled holes on either side of the servo just large enough for the tubing to slide into and shoe goo'd them into place. I then ran silicon tubing from the pickups to the esc's and then towards the left back to a tee. I brought both lines together to one exhaust hole out the back. Will have to see if this works or not. I also mounted the rx on the inside left wall ahead of the esc on that side. Ran the wires and did a radio test and everything worked. Just have to take it out and see how she runs. I'll get video of it too.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: New project boat - 10/20/2012 5:26 PM
sundogz
Score: 129
Status: offline
Looks good, Wes. I have installed a similar water pickup in my Foki mono, but it got hot last time out, so will need to add another. That is how I like to mount my receiviers as well, high and dry. Looking forward to the videos!
Hide Signatures
       Post #: 8
RE: New project boat - 10/21/2012 9:35 PM
seehuusen
Score: 100
Last Login: 5/25/2013
Status: offline
nice little build there mate I was thinking of doing a similar conversion, but with one motor only
Are the little propeller looking thing on the drive shaft a fan or something (right in front of each motor)
Hide Signatures
       Post #: 9
RE: New project boat - 10/21/2012 10:08 PM
damfurst
Score: 100
Status: offline
They are supposed to be a cooling fan, but I would call them or something. Just didn't take them off because I thought I might throw the balance off on the couplers . Thanks for the comment.
Hide Signatures
(in reply to seehuusen)
       Post #: 10
RE: New project boat - 10/23/2012 1:45 PM
SkR8Pn
Score: 100
Status: offline
Hey, looks like someones been busy.. It's looking great!
With dual props, do the motors rotate the same direction or opposite to each other? I'm thinking opposite but really dont know. Is there an advantage to using dual props over single?
Cheers
J
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 11
RE: New project boat - 10/24/2012 2:18 AM
damfurst
Score: 100
Status: offline
quote:
ORIGINAL: SkR8Pn
Cheers
J
The motors rotate opposite to each other that way there isn't any torque roll. There are advantages and disadvantages. Advantages are 1st no torque roll as long as the props are rotating different directions, 2nd more power to a given hull should equate to a higher speed over a single prop but this is where the disadvantages come into play. Dual props means dual everything motors, esc's, sometimes batteries, so twice the weight. But they are fun to mess with. Maybe somebody reading this will chime in as well as I don't know everything.
I did try running this yesterday morning but we had kind of bust. I ran at first at 1/3 throttle and it looked good. Went to go to full throttle and it tore the couplers up by spinning inside of them and mellting them a little. So now I need to find some different couplers. lol
Hide Signatures
       Post #: 12
RE: New project boat - 10/24/2012 4:09 PM
SkR8Pn
Score: 100
Status: offline
Thanks damfurst, i often wondered what the go was with dual props.
Can you get away with using a straight type coupler? Or are they dogbone type to accomdate the motors being offset to the prop shaft?
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 13
RE: New project boat - 10/24/2012 4:50 PM
damfurst
Score: 100
Status: offline
Yes I think I can use either straight coupler's if I can find some that are long enough or ujoint ones.
Hide Signatures
       Post #: 14
RE: New project boat - 10/25/2012 3:29 AM
SkR8Pn
Score: 100
Status: offline
quote:
ORIGINAL: damfurst
cool, are the ujoint type noisy? I've seen a few of the jet sprints with them in video and they seem to be..... but that could be a number of causes with those little rippers lol...
 will be good to see a vid of it in action when you get the chance..
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 15
RE: New project boat - 10/28/2012 1:56 AM
damfurst
Score: 100
Status: offline
I don't know if the u joints will be noisy or not. I'm trying some out that I haven't used before so I'm hoping that they will be the right length. Looking to have them next week i hope. I do have a graupner ujoint in my tear into and it's not noisy at all, but I'm also running the bearing mod in it as well.
Hide Signatures
       Post #: 16
RE: New project boat - 10/29/2012 12:48 AM
seehuusen
Score: 100
Status: offline
Looking good there mate!! Can't wait to see a vid of it in action
bought my NQD copy of this boat today @ AU$55 it's a bargain I reckon
This will be a single motor version though, I'll write something up when I get to building it (right now I just ordered the bits for a second Tear Into Jet Boat )
Cheers
Martin
Hide Signatures
       Post #: 17
RE: New project boat - 11/1/2012 2:19 AM
SkR8Pn
Score: 100
Status: offline
quote:
ORIGINAL: seehuusen
Cheers
Martin
It looks evil, i lkie it!
I love the actual ebay ad, when you scroll down to check all the details out...... "This boat only works in water!" There goes my plans of taking it to the park to do some drifting on the grass.....
Any updates damfurst? Keen to see what you've been up to on this build.
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 18
RE: New project boat - 11/1/2012 11:39 PM
seehuusen
Score: 100
Status: offline
quote:
ORIGINAL: SkR8Pn
BAAAHAHA, yeah that made me chuckle too
My boat arrived today!! YAY for Aussie colours!
Click for fullsize
Hide Signatures
       Post #: 19
RE: New project boat - 11/2/2012 2:26 AM
SkR8Pn
Score: 100
Status: offline
quote:
ORIGINAL: seehuusen
quote:
ORIGINAL: SkR8Pn
Man check that name out... Balaenoptere musculus.....Blue whale.
start a build thread!
Remember to only use it in water
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 20
RE: New project boat - 11/14/2012 5:39 AM
seehuusen
Score: 100
Status: offline
any updates on the build?
Hide Signatures
       Post #: 21
RE: New project boat - 11/16/2012 1:45 AM
damfurst
Score: 100
Status: offline
Sorry for the hold up but I'm waiting on some money then I can order what I need.
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
