Timing on DLE20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Timing on DLE20 Page: [1] 2   next >   >>
Login
Timing on DLE20 - 9/20/2012 5:42 PM
oldtyme
Score: 158
Last Login: 5/6/2013
Status: offline
I know this is probably covered numerous times somewhere but I want to ask the simplest way to time a DLE20. I haven't tried to use it yet and I have bought 2 engines. I am considering buying either an ignition module from a DLE30 or a DLE55 to prevent the notorious #4 issue. I don't know how to re-time/time these little engines so I am looking for the basic way to do it. I have read that the engine can be made to run with it's supplied ignition module so I'm just pondering the best way for ME to go.
Andy
_____________________________
AMA 16066
Hide Signatures
       Post #: 1
RE: Timing on DLE20 - 9/20/2012 6:09 PM
bgw45
Score: 113
Last Login: 6/18/2013
Status: offline
OT, ignore the #4 concerns till they become an issue for you. I have worked with several 20s at my home field and none of the guys have been concerned with the advance issue. Tune it, fly it and enjoy it.
Hide Signatures
(in reply to oldtyme)
       Post #: 2
RE: Timing on DLE20 - 9/20/2012 7:07 PM
karolh
Score: 315
Last Login: 6/19/2013
Status: offline
Ditto that, as the guys at my field have no problem running theirs.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to bgw45)
       Post #: 3
RE: Timing on DLE20 - 9/20/2012 8:34 PM
ahicks
Score: 669
Status: offline
X3!!
Hide Signatures
(in reply to karolh)
       Post #: 4
RE: Timing on DLE20 - 9/20/2012 9:09 PM
w8ye
Score: 318
Status: online
Center the sensor on the crankcase casting seam and go fly.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to ahicks)
       Post #: 5
RE: Timing on DLE20 - 9/20/2012 9:35 PM
Indiomike
Score: 120
Status: offline
w8ye
I'm looking at my DLE20 from the front and with the engine inverted. I see that the sensor is centered on the casing seam. At that position, how many degrees BTDC is that? If I should ever want to go with a standard RCEXL ignition and set the timing to 28 degrees BTDC, how far to the right (in mm's) would I need to move the sensor to get it there. Not having a degree wheel and not worried if timing is +/- off a couple of degrees from 28 degrees.
Mike
Hide Signatures
(in reply to w8ye)
       Post #: 6
RE: Timing on DLE20 - 9/20/2012 10:29 PM
karolh
Score: 315
Status: offline
The difference between a #4 RC exl ignition and a std. one is not in the mounting position of the sensor on the case but rather in the electronic makeup inside the ignition. So if you ever need to change your ignition just get a standard unit and bolt the sensor on using the existing mounting holes and you will be good to go.
Karol
Hide Signatures
(in reply to Indiomike)
       Post #: 7
RE: Timing on DLE20 - 9/20/2012 10:53 PM
Indiomike
Score: 120
Status: offline
karolh
I think I read somewhere that the timing was factory set somewhere around 44 degrees BTDC on DLE20. Yes, I understand that the #4 ignition has a advance curve unlike the standard RCEXL unit. Are you saying that the sensor should be mounted in the same location whether you have a #4 or standard ignition?
Now I remember. On Wrongway RC site, he states that if you replace the #4 ignition with a standard one such as the DLE55 has, you have to adjust the timing location to 28 degrees BTDC. Now, if the sensor is at 28 degrees when centered on the casing line, all is well. But, if it is something else, then it has to be shifted one way or the other. Unless I don't understand timing, timing is adjusted by moving the sensor left or right by loosening the two screws and sliding the sensor left or right.
Can you or someone tell me how many degrees BTDC is the sensor when centered on the engine casing line?
Mike
Hide Signatures
       Post #: 8
RE: Timing on DLE20 - 9/20/2012 11:38 PM
oldtyme
Score: 158
Status: offline
quote:
ORIGINAL: Indiomike
karolh
Mike
Mike..........that's exactly what I was asking on my original post and I don't have an angle wheel or anything else like that.
AMA 16066
Hide Signatures
       Post #: 9
RE: Timing on DLE20 - 9/20/2012 11:57 PM  1 votes
All Day Dan
Score: 156
Status: offline
Follow this video. Dan.
http://www.youtube.com/watch?v=GBXFpxWg7vY
Dan
Hide Signatures
       Post #: 10
RE: Timing on DLE20 - 9/21/2012 12:40 AM
w8ye
Score: 318
Status: online
The ignition is not set at 40 or 44 degrees from the factory. That was some nerd at Tower that said that. He measured the timing on a degree wheel but turned the crankshaft the opposite direction of rotation.
As the spark plug fires when the magnet leaves the sensor, he was a whole sensor width off.
I measured my DLE 20 and it is around 32 degrees with the sensor on the casting seam. They run OK in that position with either the #4 ignition or a standard one.
So if you get another ignition unit, just leave the orginal sensor alone and plug it into your new ignition unit if you are not good with timing.
Original AMA #31261
Hide Signatures
(in reply to All Day Dan)
       Post #: 11
RE: Timing on DLE20 - 9/21/2012 12:46 AM
w8ye
Score: 318
Status: online
Here's the degree wheel that Max uses. Just print it out and glue it to a piece of poster board, aluminum, acylic, or plywood.
Make sure you use the icon at the lower right and get the enlargable image to full size if you are using the icon.
Here I made it a little bigger so you can see what it looks like. Just right click and save the image then print it out.
Click to see fullsize image.
Click for fullsize
< Message edited by w8ye -- 9/21/2012 9:00 AM >
Original AMA #31261
Hide Signatures
(in reply to w8ye)
       Post #: 12
RE: Timing on DLE20 - 9/21/2012 12:47 AM
oldtyme
Score: 158
Status: offline
Thanks W8ye..............that makes it simple enough for me!!
Also..........why do you think that the DLE55 ignition module.....which is what I intend to buy if any........is only $74 and the DLE20 is $89??????
AMA 16066
Hide Signatures
(in reply to w8ye)
       Post #: 13
RE: Timing on DLE20 - 9/21/2012 1:39 AM
RiverLarry
Score: 100
Status: offline
Just order a  RCEXL    cost   $54.95 and comes with a free tester      and you will never look back !!!!
 call   678 372 7697           R/L
Hide Signatures
       Post #: 14
RE: Timing on DLE20 - 9/21/2012 2:16 AM
Indiomike
Score: 120
Status: offline
w8ye
Thanks for that. Knowing the timing is 32 degrees with the sensor centered is what I was looking for.
oldtyme
You can get the DLE55 ignition at a much better price than you quoted at either Wrongway RC or MileHigh RC.
Mike
Hide Signatures
(in reply to RiverLarry)
       Post #: 15
RE: Timing on DLE20 - 9/21/2012 2:40 AM
w8ye
Score: 318
Status: online
quote:
ORIGINAL: oldtyme
I figure their stock of ignitions for the DLE 20 is newer and reflects the new price?
Original AMA #31261
Hide Signatures
       Post #: 16
RE: Timing on DLE20 - 9/21/2012 4:46 AM
karolh
Score: 315
Status: offline
I would much prefer to buy a RC exl ignition as a replacement than another a DLE one.
Karol
Hide Signatures
       Post #: 17
RE: Timing on DLE20 - 9/21/2012 1:42 PM
ahicks
Score: 669
Status: offline
I agree Karol, but that's not going to happen until my OEM (#4) module dies for some reason?
Also, wanted to add that I would shop that price around myself. If you take the # 3 and 4 modules out of the picture, the rest of the Rcexl modules with spark plug boots that fit the CM-6 plug are the same. There's nothing special about them, and you can buy them anywhere - for less than 50.00 as a rule. Sometimes much less? They'll all work fine on the 20 or 30cc DLEs.
Hide Signatures
       Post #: 18
RE: Timing on DLE20 - 9/21/2012 2:26 PM
raptureboy
Score: 183
Status: offline
Why create a problem that doesn't exist? Once you break the engine in it's not a problem, I have 3  on the original ignitions and they work fine. It's all in the tuning.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 19
RE: Timing on DLE20 - 9/26/2012 8:09 AM
Mikecam
Score: 120
Last Login: 6/15/2013
Status: offline
Works on my DLE 55 for $24
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=10996
Hide Signatures
(in reply to raptureboy)
       Post #: 20
RE: Timing on DLE20 - 9/28/2012 6:55 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
Hi guys, if you set the timing at 32 degrees or whatever sitting on the bench, when the engine gets up to top rpms doesn't the built in advance curve actually advance the timing more than that? How much?
Thanks, Ernie Misner
Hide Signatures
(in reply to Mikecam)
       Post #: 21
RE: Timing on DLE20 - 9/28/2012 7:18 AM
w8ye
Score: 318
Status: online
The RCEXL ignition retards from your setting at idle to around 4 - 6 degrees and by somewhere above 4000 it is at your full advane of 28 - 32 degrees
Original AMA #31261
Hide Signatures
(in reply to Ernie Misner)
       Post #: 22
RE: Timing on DLE20 - 9/29/2012 12:46 AM
Ernie Misner
Score: 130
Status: offline
Ahhhh thanks Jim, so you are actually setting it for high speed although the engine isn't even running. Amazing.
Thanks, Ernie
Hide Signatures
(in reply to w8ye)
       Post #: 23
RE: Timing on DLE20 - 9/29/2012 1:33 AM
w8ye
Score: 318
Status: online
Setting still the timing is at full advance. When you flip the prop the timing goes to its minumum value.
With the engine running faster and faster, the timing eventually gets to full advance up around 4500 rpm.
Original AMA #31261
Hide Signatures
       Post #: 24
RE: Timing on DLE20 - 9/29/2012 1:45 AM
ahicks
Score: 669
Status: offline
The DLE 20 goes to full advance in a single leap, down closer to 2500 rpm. That's the basis of the issue with it if there is one, noticed more often on it's way down as it retards. The standard Rcexl module, like the one used on the 55, does it in a few steps, a REAL curve, not a single step/on-off switch kind of thing, and it does it at a higher rpm where the chances of it being noticable are slim to none. Not sure what rpm that one's "all in" at. Could be the 4500 your thinking, dunno. -Al
Hide Signatures
(in reply to w8ye)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Timing on DLE20
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
