Check my fuel math?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Check my fuel math?
Page: [1]
Login
Check my fuel math? - 9/21/2012 6:35 AM
Kmot
Score: 168
Last Login: 5/24/2013
Status: offline
I need fuel with 7% oil by volume.
I have Powermaster 15% Sport fuel, which is 18% oil by volume.
My math is as follows:
128 oz of fuel =
86 oz of methanol
23 oz of oil
19 oz of nitromethane
If I take 16 oz of the fuel, I have:
10.725 oz of methanol
2.875 oz of oil
2.4 oz of nitromethane
The above is still 18% oil by volume.
Now, by my calculations, if I add 30 oz of pure methanol to the 16 oz of this Powermaster fuel, I will have:
46 oz of 7% oil by volume, fuel.
Which would be:
40.725 oz of methanol
2.875 oz of oil
Anyone see anything wrong with my math?
Thanks!
_____________________________
~Tom~
Hide Signatures
       Post #: 1
RE: Check my fuel math? - 9/21/2012 12:00 PM
1QwkSport2.5r
Score: 155
Last Login: 5/25/2013
Status: online
quote:
ORIGINAL: Kmot
128 oz of fuel =
86 oz of methanol
23 oz of oil
2.875 oz of oil
Which would be:
2.875 oz of oil
Thanks!
You have 88.5% methanol, 6.25% oil, 5.2% nitromethane. in 46oz of mixed fuel, you would need 3.22oz of oil to have 7%. I would just subtract the small amount of methanol to bring the oil up. If you dropped the methanol by 6oz to 34.725, you would have 86.8% methanol, 7.2% oil, 6% nitromethane which gives you 40oz of mixed fuel instead of 46oz.
When mixing in odd quantities, I use graduated cylinders and measure in mL instead of fluid ounces as its easier to be more precise.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Kmot)
       Post #: 2
RE: Check my fuel math? - 9/21/2012 3:59 PM
hauckf
Score: 100
Last Login: 5/18/2013
Status: offline
And the answer is........ Add 201 oz methanol to a gallon of the Powermaster fuel, or 47 oz of methanol to 30 oz of the Powermaster to get a final product containing 7% oil and 5.8% nitro. In other words, multiply the starting amount of Powermaster by 1.57, and that is how much methanol to add to it.
Hide Signatures
(in reply to Kmot)
       Post #: 3
RE: Check my fuel math? - 9/21/2012 5:30 PM
Kmot
Score: 168
Status: offline
Thanks for the replies guys!
Let me try to understand this.
You are dividing the 46 oz total fuel by the oil content of 2.875 oz to get the oil by volume of 6.25%, correct?
The way I look at it, the 46 oz total is not the figure to use, but instead the 40.725 oz of methanol is. Because that is actually how much methanol there is. When this is calculated with 2.875 ounces of oil, the oil by volume becomes 7%, does it not?
Why am I unable to understand this?
~Tom~
Hide Signatures
(in reply to hauckf)
       Post #: 4
RE: Check my fuel math? - 9/21/2012 5:59 PM
hauckf
Score: 100
Status: offline
To calculate the percent by volume on any component of the fuel, you divide the amount of that component in the fuel by the total amount of fuel, not the amount of methanol. In your original post, you multiplied the percent of oil in the gallon (18%) by total amount of fuel (128 oz), to get the amount of oil in the gallon, right? If I gave you 46 oz of fuel and told you it was 7% oil, wouldn't you calculate the amount of oil in that 46 oz of fuel the same way?
Hide Signatures
(in reply to Kmot)
       Post #: 5
RE: Check my fuel math? - 9/21/2012 8:04 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: hauckf
This is right on the money. Well said. Its no different if someone buys a gallon of premix and adds oil to bring the oil content up. By doing this, the other components will change concentrations since the overall amount of liquid is being increased by "X" amount of ounces. 20% oil in 1 gallon of 10% nitro fuel ends up being 25.6oz oil, 12.8oz nitro and 89.6oz methanol. Add 2 ounces of oil to this mixture increased the overall volume of liquid by 2 ounces and thus divide each component by the new volume of 130 ounces. 27.6 ounces of oil is now 21.2%. The nitro drops to 9.8% and methanol drops to 68.9%. Obviously this wont add up to 100% necessarily because of the calculator rounding up or down. You get the idea though...
Hide Signatures
       Post #: 6
RE: Check my fuel math? - 9/21/2012 9:47 PM
Kmot
Score: 168
Status: offline
DING!
Now I get it. Thanks!
~Tom~
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 7
RE: Check my fuel math? - 9/21/2012 10:00 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: Kmot
DING!
Quite welcome.
Hide Signatures
(in reply to Kmot)
       Post #: 8
RE: Check my fuel math? - 9/21/2012 10:02 PM
hauckf
Score: 100
Status: offline
Glad we could help. Now I have a question: What is fuel with 7% oil used for?
Hide Signatures
(in reply to Kmot)
       Post #: 9
RE: Check my fuel math? - 9/22/2012 1:44 AM
Kmot
Score: 168
Status: offline
Will be testing a special intake manifold for the ASP radial engine. Like the Seidel and Moki engines, it allows the use of 7% oil fuel.
~Tom~
Hide Signatures
       Post #: 10
RE: Check my fuel math? - 9/22/2012 2:27 AM
Old Fart
Score: 158
Status: offline
Tom can you keep us up to date on the manifold? i've run a friends 770 and it's been hard to keep the lower cylinders lit evenly till we added 7% unleaded petrol to the mix.
Cheers,peter
Watch out for the ground eh?
Hide Signatures
(in reply to Kmot)
       Post #: 11
RE: Check my fuel math? - 9/22/2012 2:52 AM
rockin daddy
Score: 100
Last Login: 3/13/2013
Status: offline
Hey Old Fart:
I have a Saito 325 and an ASP 400 sitting waiting for this slow old builder(me)  to finish the planes.  Have been mixing my own fuel for many years.  Usually use it in my Saito 4-strokes and a few 2-strokes I fly on occasion.  I use 20% oil(10% castor and 10% Klotz), and  10 % Nitro.   I can mix fuel for less than $8.00/ gal.   I have heard of using 5~ 7% gasoline to give the glow engines a little "kick".   Have you had a bit of experience with the addition of gasoline to the glow fuel mix???
Have a couple of twin Saito 4-cycle motors that sometimes one of the cylinders will loose the "fire" when I throttle down to half when on the back side of a loop and the motor continues to run at 1/2 speed, running on just one cylinder.   The only way to get the dead cylinder to relight is to chop the throttle a bit and the McDaniel glow plug controller fires up the glow plugs.
Hide Signatures
(in reply to Old Fart)
       Post #: 12
RE: Check my fuel math? - 9/23/2012 6:08 PM
Kmot
Score: 168
Status: offline
quote:
ORIGINAL: Old Fart
Cheers,peter
Will do. I intend to post a full build-up and test report.
~Tom~
Hide Signatures
       Post #: 13
RE: Check my fuel math? - 10/11/2012 6:49 AM
Kmot
Score: 168
Status: offline
Peter,
I ran the engine today on the blended 7% oil fuel and the custom intake manifold. The engine runs just fine on this fuel. No smoke in the back yard either!
Report and video coming soon.
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 14
RE: Check my fuel math? - 11/2/2012 9:14 AM
Donairplane
Score: 100
Status: offline
Try this site when mixing fuel.  http://www.nitrorc.com/fuelws/allmix.asp
Hide Signatures
(in reply to Kmot)
       Post #: 15
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> Check my fuel math?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
