RE: HOBBYKING L59 for JETCAT P20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: HOBBYKING L59 for JETCAT P20
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: HOBBYKING L59 for JETCAT P20 - 9/25/2012 1:37 PM
CrocEnd
Score: 100
Last Login: 5/5/2013
Status: offline
Actually
I have seen that before Magic
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 26
RE: HOBBYKING L59 for JETCAT P20 - 9/25/2012 1:40 PM
CrocEnd
Score: 100
Status: offline
AR another one
What about a Wren Gold 44 Pipe size
Croc
Hide Signatures
(in reply to CrocEnd)
       Post #: 27
RE: HOBBYKING L59 for JETCAT P20 - 9/26/2012 9:33 AM
CrocEnd
Score: 100
Status: offline
Henke
Tell me more Re: test bench
Thanx Croc
Hide Signatures
       Post #: 28
RE: HOBBYKING L59 for JETCAT P20 - 9/26/2012 10:20 AM
Henke Torphammar
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: CrocEnd
Henke
Thanx Croc
You can modify the test bench for MW44 too, the scale handles up to 5kg of thrust. works with up to 90mm EDF too. Email hab@hab.se for more info.
_____________________________
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 29
RE: HOBBYKING L59 for JETCAT P20 - 9/29/2012 4:52 AM
CrocEnd
Score: 100
Status: offline
What I need is the diametter of a pipe for a Wren 44 or and Wren 54
Hide Signatures
       Post #: 30
RE: HOBBYKING L59 for JETCAT P20 - 9/30/2012 11:50 AM
TimWatson
Score: 105
Last Login: 10/1/2012
Status: offline
Had to put 5 oz  (125 g) of lead in the very nose of mine to get it to balance. I had also put the P20 quite a way forward. The problem is the tail on this plane is quite heavy. I will weigh the all up dry weight in a moment
Just put her on her wheels and it is obvious that the CG in the manual looks wrong as it is very bouncy on the nose. I just read the trread on this plane on RC Groups and it says the cg should be 60 mm back at 240 mm and not as the manual which says 80 mm back at 240 mm. I thorefore opened up the nose from the bottom at the very front and put in another 110g of lead and that has done the trick. All I need now is some good weather
Just weighed it and the all up dry weight with the header empty and no fuel but everything else included is 3.2 kg which is 7 Lbs. I am quite pleased at this weight the EDF Boys seem to be comming in over 8lbs.
I recon with the amount of wing area that the L59 has she should fly well with a P20 (5.2 lbs of thrust)
< Message edited by TimWatson -- 9/30/2012 2:30 PM >
And so it is agreed. Whoever wins takes the horse 29716122118219
Hide Signatures
       Post #: 31
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 6:31 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: TimWatson
So you have a total of 235g in the nose.I have 180g in the nose,i left the cg on 80mm and the plane is perfectly balanced.
The plane has a  weight of 3370g which i believe is very good.
No excuses...!
Hide Signatures
(in reply to TimWatson)
       Post #: 32
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 11:37 AM
BaldEagel
Score: 118
Status: offline
That EDF weight of 8Lb is probably with batteries as you have said your 7Lb weight is with no fuel on board, so possibly you are coming out at the same weight near enough.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to POWER JET)
       Post #: 33
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 6:42 PM
TimWatson
Score: 105
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
Very true but I can land at 7 lb I dont think the edf boys can chuck out spent batteries
Hide Signatures
(in reply to BaldEagel)
       Post #: 34
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 6:44 PM
BaldEagel
Score: 118
Status: offline
I don't know though I have certainly lost a battery in flight from my EDF Habu, so it was lighter when it arrived. LOL
Mike
Hide Signatures
       Post #: 35
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 7:08 PM
DelGatoGrande
Score: 105
Status: offline
POWER JET here is the video of your flight i took last week with my mobile...flare didnt go as planed
< Message edited by DelGatoGrande -- 10/2/2012 8:53 AM >
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
       Post #: 36
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 7:37 PM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: DelGatoGrande
http://www.youtube.com/watch?v=0GQKMUHRn14
So,you did all this!!!!!  It was your trembling hands that shaked and crash my plane!!! It's perfectly sycronized!!!!
No excuses...!
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 37
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 7:50 PM
DelGatoGrande
Score: 105
Status: offline
lol .. im sure its ready for this weekend
Hide Signatures
       Post #: 38
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 7:59 PM
terryjet
Score: 100
Last Login: 5/11/2013
Status: offline
very nice and stable flight power jet but must be very windy at the airport!!this video is HD or not?the ideal plane for this turbine!!
Hide Signatures
       Post #: 39
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 8:08 PM
POWER JET
Score: 100
Status: offline
I don't think so...the wing has serious damageσ so if i try to fix i will add weight and i don't want to.
So the solution is easy....i ordered two new kits from Hobbyking!
No excuses...!
Hide Signatures
       Post #: 40
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 8:10 PM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: terryjet
Thank you very much Terry...yes i believe it's the best plane for the P20!! Scale fast and very stable in flight!!!
No excuses...!
Hide Signatures
(in reply to terryjet)
       Post #: 41
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 8:20 PM
terryjet
Score: 100
Status: offline
ti vra to sabbato?
Hide Signatures
       Post #: 42
RE: HOBBYKING L59 for JETCAT P20 - 10/1/2012 8:28 PM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: terryjet
ti vra to sabbato?
Hahaha!!!! Apo to proi mexri to bradi!!!
Sorry about that my friends...it's greek humor!!
We're  just arrange what time we're gonna meet at our flight academy club field on weekend!!
No excuses...!
Hide Signatures
       Post #: 43
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 8:57 PM
Chris Pyrah
Score: 100
Status: online
Hi Guys Anyone any feedback/ install pics on the P20 instal,l I have just ordered one from hobbyking uk and ordered the retracts from the Germany hobbyking so should have them in the next few days
Hide Signatures
       Post #: 44
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 9:03 PM
DominicM
Score: 101
Status: offline
If it helps my 8S5000 powered EDF version is 3.2kg AUW. Not flown yet. Waiting for a fan. Just in case you haven't read the RCG thread most important mod is the reinforce the area around the mounts for the mains LG with carbon cloth. Several have landed and the retract punch straight through the wing.
Hide Signatures
(in reply to Chris Pyrah)
       Post #: 45
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 9:41 PM
Chris Pyrah
Score: 100
Status: online
any chance of a link to that thread sounds interesting thanks for the warning about the retract mounts
Hide Signatures
(in reply to DominicM)
       Post #: 46
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 9:42 PM
DominicM
Score: 101
Status: offline
http://www.rcgroups.com/forums/showthread.php?t=1661261
Hide Signatures
       Post #: 47
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 10:21 PM
BaldEagel
Score: 118
Status: offline
You may wish to look at this thread as well: http://www.youtube.com/watch_popup?v=jEjUAnPc2VA#t=20
Mike
Hide Signatures
       Post #: 48
RE: HOBBYKING L59 for JETCAT P20 - 2/26/2013 10:58 PM
Chris Pyrah
Score: 100
Status: online
brilliant but its a pigeon not an albatross lol
Hide Signatures
       Post #: 49
RE: HOBBYKING L59 for JETCAT P20 - 3/1/2013 12:40 AM
Chris Pyrah
Score: 100
Status: online
Got the kit today, I have had a look at the wing retract mounts they seem quite well braced there is a ply mount with a quadrant brace under the ply, has this been added since earlier models ? ,Not too sure about a lot of the formers in the fuz they look like they need Hysol reinforcement. Overall though. it looks like it will make a very nice model with a bit of tlc.need to get a thrust pipe sorted next,I think the P20 will sit quite a way forward to get the c of g, looks like the tank will sit nicely on the c of g, plenty of room for that
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
