HOBBYKING L59 for JETCAT P20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> HOBBYKING L59 for JETCAT P20
Page: [1] 2 3   next >   >>
Login
HOBBYKING L59 for JETCAT P20 - 9/21/2012 7:08 AM
POWER JET
Score: 100
Last Login: 6/18/2013
Status: offline
 Here's my little L59 with a Jetcat P20 installed. This was bought from Hobbyking  for $230 shipped.The air frame isn't too bad.
I will edit this tomorrow with a ready to fly weight, but I'm estimating it at about 3.300gr empty.
More photos coming soon....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
No excuses...!
Hide Signatures
       Post #: 1
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 7:32 AM
DominicM
Score: 101
Last Login: 6/20/2013
Status: online
I've read good things about the airframe as well. Seems HK's main problem is getting it shipped without incurring damage because of the poor packaging. Have they come to their senses and sent it double boxed?
Hide Signatures
(in reply to POWER JET)
       Post #: 2
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 8:38 AM
Henke Torphammar
Score: 100
Status: offline
Empty weight of the kit?
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to DominicM)
       Post #: 3
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 4:07 PM
POWER JET
Score: 100
Status: offline
The model is about 1.100 kgr when it comes out of the box.
No,it is'n double box.My plane has only a little crack on the nose but i will hysol it.Not a big deal!
Here is some photos..it's almost ready for take off..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
No excuses...!
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 4
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 4:51 PM
drdoom
Score: 130
Last Login: 6/17/2013
Status: offline
I may copy some of your install. Is that pipe a Single wall pipe?
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
       Post #: 5
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 6:20 PM
TimWatson
Score: 105
Last Login: 10/1/2012
Status: offline
Hey thats not fair. I am at about the same point with mine also a P20. In my view this is the best P20 model yet
< Message edited by TimWatson -- 9/22/2012 7:50 AM >
And so it is agreed. Whoever wins takes the horse 29716122118219
Hide Signatures
(in reply to drdoom)
       Post #: 6
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 9:47 PM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: drdoom
Yes it's a single wall pipe.
No excuses...!
Hide Signatures
       Post #: 7
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 9:53 PM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: TimWatson
Hey thants not fair. I am at about the same point with mine also a P20. In my view this is the best P20 model yet
It's the most scale plane that you can install the P20.It's large enough,you can see it easily from a big distance.Instead of the Habu that you can lose it from your sight in no time!
And it's very beautiful.
No excuses...!
Hide Signatures
(in reply to TimWatson)
       Post #: 8
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 9:54 PM
POWER JET
Score: 100
Status: offline
The weight is 3,260 gr empty.I believe is a good weight for the size of the plane and for the P20
No excuses...!
Hide Signatures
       Post #: 9
RE: HOBBYKING L59 for JETCAT P20 - 9/21/2012 11:22 PM
Vettster
Score: 105
Last Login: 6/19/2013
Status: offline
Hanz..Your weight is Very good! Mine is an EDF for the time being..but it weighs 7.6lbs without retracts, and flys amazingly well.
My only recommendation to you guys building this plane, is to glass the wings where they join top and bottom. You dont really want to trust some kids glue job or even the glue they used do you? There have been reports of the CMP Hawk wing separating at the wing joint. It comes pre-glued like the L-59
The flight envelope of the plane is simply amazing! Will do next to nothing in a 10khm wind or can be blisteringly fast on the downwind(edf) for a top speed of 165mph for my plane.
Check out this video of how slow she can fly.
http://www.youtube.com/watch?v=w_I13okGH4c
Trevor
Club NO MAX! No boarder..No Limits..No POLITICS! NO "MAX"
Hide Signatures
       Post #: 10
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 7:54 AM
TimWatson
Score: 105
Status: offline
The only bit I am ascratching my head about at the moment is the Canopy and how to attach it so that it will be secure but also quick and easy to remove at the field
Hide Signatures
(in reply to Vettster)
       Post #: 11
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 8:09 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: TimWatson
You don't have to!!I will use transparent duct tape!!
No excuses...!
Hide Signatures
       Post #: 12
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 8:17 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: Vettster
Trevor
Yes,i've notice that and i already did it!Thanks for the recomendation!
No excuses...!
Hide Signatures
       Post #: 13
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 11:25 AM
Henke Torphammar
Score: 100
Status: offline
Check this out http://www.rcuniverse.com/forum/m_11158642/anchors_11217220/mpage_1/key_/anchor/tm.htm
If your P20 does the stated 5.25lb of thrust you still need too optimize your setup to keep the thrust when installed. It's very easy to reduce thrust if you install the pipe wrong.
/Henke
Hide Signatures
       Post #: 14
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 8:39 PM
POWER JET
Score: 100
Status: offline
The distance from the exhaust of turbine to the tail of the plane is almost 15 cm.The distance is very little so i install the exhaust just to protect the plane from the big heat and to align the exhaust gas.
If it was up to me, not to install the pipe,i will not be install her just for weight matter!
No excuses...!
Hide Signatures
       Post #: 15
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 9:02 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: POWER JET
you say it your self in "no excuses" :-) it's very easy to make 1lb of thrust vanish(!)
/Henke
Hide Signatures
       Post #: 16
RE: HOBBYKING L59 for JETCAT P20 - 9/22/2012 10:22 PM
Vettster
Score: 105
Status: offline
quote:
ORIGINAL: TimWatson
Tim.. I thru away that cheep cockpit area. It has no structural strength at all. I replaced it with a light ply sheet and bulkhead that a latch could hold on to. I put a dowel up front.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: HOBBYKING L59 for JETCAT P20 - 9/23/2012 4:58 AM
POWER JET
Score: 100
Status: offline
[/quote]
Yes of course,i know that's is very easy  to make 1lb of thrust vanish ,but I did not excuses my self.
The exhaust is 12cm long and the turbine gases are free flowing!
I believe i have all of the 5.25lbs of thrust of my P20!
No excuses...!
Hide Signatures
       Post #: 18
RE: HOBBYKING L59 for JETCAT P20 - 9/23/2012 6:25 PM
POWER JET
Score: 100
Status: offline
I did the maiden today.Success!!!
The plane was very  fast for the size of it! I'm very impressed!! Very stable in flight but very steep!
The control surface movements are too much in all surfaces.The manufacturer gives 15-20 mm on AIL and ELEV,me i have them on 15 mm but it was too much!Needs lower movements!
I think the best scale plane for the P20!!
No excuses...!
Hide Signatures
       Post #: 19
RE: HOBBYKING L59 for JETCAT P20 - 9/23/2012 8:36 PM
TimWatson
Score: 105
Status: offline
Glad you had a successful maiden.
What do you mean. 'Very Steep'
Hide Signatures
       Post #: 20
RE: HOBBYKING L59 for JETCAT P20 - 9/23/2012 11:07 PM
Vettster
Score: 105
Status: offline
quote:
ORIGINAL: POWER JET
GOOD STUFF!
Ohhh I think we're going to need to see some video
Any chance you can GPS that puppy? Wonder how fast she's moving out.
When people ask how it flys..I always tell them that its just a Super Fast Cessna
Hide Signatures
       Post #: 21
RE: HOBBYKING L59 for JETCAT P20 - 9/24/2012 6:41 AM
POWER JET
Score: 100
Status: offline
[/quote]
GOOD STUFF!
[/quote]
Video very soon!! I will try to have also an on board camera.
All you unbelievers ,you will be suprised as i did!!
Be patient!!...
No excuses...!
Hide Signatures
       Post #: 22
RE: HOBBYKING L59 for JETCAT P20 - 9/24/2012 6:55 AM
POWER JET
Score: 100
Status: offline
quote:
ORIGINAL: TimWatson
How can i say that...bluntness,brusqueness!
Thats,because of the big surface movements that the manufacturer gives.If i decreased them i believe that it will be fine!
I didn't have the luck to do a second flight because the nose gear has broken.
Very little glue on the nose gear reception.!
Mavbe the chinese boy who build my plane had to go for break and drink sake!
No excuses...!
Hide Signatures
       Post #: 23
RE: HOBBYKING L59 for JETCAT P20 - 9/25/2012 10:55 AM
CrocEnd
Score: 100
Last Login: 5/5/2013
Status: offline
Henke Hi
So what pipe distance was the end result for the P-20
CrocEnd
Hide Signatures
       Post #: 24
RE: HOBBYKING L59 for JETCAT P20 - 9/25/2012 12:42 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: CrocEnd
Henke Hi
CrocEnd
Hi,
We found it differs depending on which setup you run. Diameter and length of the pipe, bellmouth shape etc. If you want to optimize the setup the only way is to test it your self. As the test bench only costs €99 includeing all you need it's not much to argue about. Neither Grumanias, jetcats or Lamberts recomendations were the best in our testing. I have not tested a P20 yet but are soon to do so. Test were done with a Kolibri turbine. You can also use the test bench for making a linear thrust to stick throtthe curve.
This was not right in our test.
/Henke
Hide Signatures
(in reply to CrocEnd)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.782RCU1
