Scratched piston/sleeve reapir    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Scratched piston/sleeve reapir
Page: [1]
Login
Scratched piston/sleeve reapir - 9/21/2012 9:19 PM
supertib
Score: 302
Last Login: 5/25/2013
Status: offline
there has been talk about doing piston/sleeve repairs.... I just so happen to repair a fair amount of engines, i basically just stick to working on CRE engines, But I figured I would show how I do some of the repairs....I am not much for describing things, so I will post the pictures and if anyone has any questions feel free to ask.....The engine pictured is a C6 USA...it lost the circlip on the exhaust side and took out the piston and put a healthy scratch on the sleeve... The piston unfortunately is too far gone for repair...But I think the sleeve can be saved.... I will find a used piston in the shop from a Nova/RB of that series and match it to the sleeve, or match the sleeve to the piston..... I can lap the piston smaller, or I can pinc the sleeve smaller..I own the RayA Racing tooling set ........I mainly use a flexi hone in my lathe for cleaning up the sleeve, It does a fantastic job .....
< Message edited by supertib -- 9/21/2012 9:53 PM >
_____________________________
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 1
RE: Scratched piston/sleeve reapir - 9/21/2012 9:21 PM
supertib
Score: 302
Status: offline
and here is what I use in my lathe to do it
I also own the Raya Racing pinching tools and my own custom piston lapping die set...
Hide Signatures
(in reply to supertib)
       Post #: 2
RE: Scratched piston/sleeve reapir - 9/21/2012 10:00 PM
llkoolskillet
Score: 100
Status: offline
Are you boreing the sleeve larger and then finding a piston to fit?
ERCM Picco/ Endbleed power should be the only combo allowed in a Savage.
Hide Signatures
       Post #: 3
RE: Scratched piston/sleeve reapir - 9/21/2012 10:13 PM
supertib
Score: 302
Status: offline
And here is a few more pics of that sleeve after honing.... this time I tried to get better depth in the photo...the results are quite nice
Hide Signatures
(in reply to llkoolskillet)
       Post #: 4
RE: Scratched piston/sleeve reapir - 9/21/2012 10:16 PM
supertib
Score: 302
Status: offline
When I have to repair a piston, or resize a piston I use these here custom made lapping die's ...I have a die for every bore of engine I work with....I use 1200 grit clover lapping paste
Hide Signatures
       Post #: 5
RE: Scratched piston/sleeve reapir - 9/21/2012 10:31 PM
supertib
Score: 302
Status: offline
I decided to pass the piston thru the lapping die for a few minutes....just to show how it works with the 1200 grit.... if i wanted I could use much more aggressive abrasive and take it down substantially more..and yes that is a modified piston and rod....rod is lightened and so is the piston.... the circlip was still in the piston, but the dog leg snapped off
Hide Signatures
       Post #: 6
RE: Scratched piston/sleeve reapir - 9/21/2012 10:47 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: llkoolskillet
more or less....except i am only honing the sleeve.... and I will find a piston of that style and I can either take the piston down to fit the sleeve, or take the sleeve down to fit the piston... I will likely use a piston from a P5 XLT...tho i will check my engine box and see if there is anything else suitable....
Hide Signatures
       Post #: 7
RE: Scratched piston/sleeve reapir - 9/21/2012 11:44 PM
purenitro33
Score: 115
Last Login: 3/30/2013
Status: offline
That's pretty slick!
Hide Signatures
       Post #: 8
RE: Scratched piston/sleeve reapir - 9/22/2012 8:02 PM
Anthoop
Score: 121
Status: offline
Thanks for sharing.
The lapping tools are made out of garolite?
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to purenitro33)
       Post #: 9
RE: Scratched piston/sleeve reapir - 9/22/2012 8:29 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: Anthoop
Thanks for sharing.
good eye !!!!!
Hide Signatures
(in reply to Anthoop)
       Post #: 10
RE: Scratched piston/sleeve reapir - 9/24/2012 9:34 AM
controlliner
Score: 100
Last Login: 5/24/2013
Status: offline
This process is totally do able but by the time you put in all your man hours in , won't it far exceed the cost of a new piston and liner set? I could see this done on an obsolete engine where no parts are available.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
       Post #: 11
RE: Scratched piston/sleeve reapir - 9/24/2012 1:59 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: controlliner
not really.....what you see here took me all of 5 minutes to do...the piston/sleeve is worth about $200.00 with the mods.... so the 5 minutes is definitely worth saving a $200.00 piston/sleeve set..............
Hide Signatures
(in reply to controlliner)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
