Something strange happened at the field today    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Something strange happened at the field today
Page: [1] 2 3   next >   >>
Login
Something strange happened at the field today - 9/23/2012 1:49 AM
karolh
Last Login: 5/18/2013
Status: offline
My friend was maidening his 50cc Goldwing Extra 330/ DA50 model today when shortly after takeoff on it's first flight the engine stopped. Luckily he was able to land the model safely enough, though breaking one leg of the CF l/ gear at the axle connection.
An inspection of the engine revealed that the 4 aluminium cylinder mounting bolts had all shared and only the spark plug being attached to the HT lead had kept the cylinder from coming completely loose. The cylinder and the rest of the engine is servicable but it will require a new piston and ring.
This makes me wonder what is the purpose of using aluminium bolts instead of steel bolts as most other engine manufacturers do, as if weight saving is the reason then the advantage of doing so at best must be miniscule.
Karol
_____________________________
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 1
RE: Something strange happened at the field today - 9/23/2012 2:46 AM
captinjohn
Status: offline
I have a Desert Aircraft 50cc engine....but the cyl base bolts do not seem like aluminum????
I never met a engine I did not like !
Hide Signatures
(in reply to karolh)
       Post #: 2
RE: Something strange happened at the field today - 9/23/2012 8:06 AM
TimBle
Status: offline
Aluminium ? No Way, Can't be!
The torque required to hold the bolt in reduces the tensile load the blt can carry. They WILL snap.
Must be a mistake. Engine should be sent back to the manufacturer unless the bolts were the idea of and fitted by the owner.
Hide Signatures
(in reply to captinjohn)
       Post #: 3
RE: Something strange happened at the field today - 9/23/2012 8:09 AM
Ernie Misner
Last Login: 5/17/2013
Status: offline
Let us know if they were indeed aluminum!
Hide Signatures
(in reply to TimBle)
       Post #: 4
RE: Something strange happened at the field today - 9/23/2012 9:10 AM
Mr67Stang
Last Login: 12/14/2012
Status: offline
I for one would like to see this. Pictures?
He who dies with the most toys wins!
Hide Signatures
(in reply to Ernie Misner)
       Post #: 5
RE: Something strange happened at the field today - 9/23/2012 10:12 AM
MetallicaJunkie
Status: offline
theres no way they DA would use aluminm bolts.... they may have been "silver" in color, but wdre actually stainless....not quite as soft as aluminum and not quite as hard as black carbon steel
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to Mr67Stang)
       Post #: 6
RE: Something strange happened at the field today - 9/23/2012 10:33 AM  1 votes
Cyberwolf
Status: offline
Karolh you are indeed correct in thinking the bolts are made from Alum. and anodized red. The back case bolts are made from Alum also. Only the prop hub bolts are steel in any DA 50-100 engine I have ever seen or worked on. Why there sheared off i'm sure was the fact they worked loose over time and the pressure from the piston and ring going up and down popped the heads off. Many don't know that pound for pound Alum is stronger than steel. The cylinder bolts doesn't require a great deal of torque on the bolts ,but they do need to be kept tight. Anyone that has the stock bolts (RED) in there DA engine, use a magnet on them and see for yourself.
http://www.desertaircraft.com/images/engines/50-small.jpg
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 7
RE: Something strange happened at the field today - 9/23/2012 1:21 PM
Rocketman_
Status: offline
It is not all that strange to hear of the highly touted DA engine popping those pretty red aluminum bolts. I am acquainted with an expert flier who will use nothing other than DA engines and sends his engines to DA for annual check ups but, in spite of that, he had a cylinder pop off. He told me about his experience after I told him that I had read about DA's blowing their heads off.
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
(in reply to Cyberwolf)
       Post #: 8
RE: Something strange happened at the field today - 9/23/2012 3:07 PM
karolh
Status: offline
quote:
ORIGINAL: Cyberwolf
Phew, I was beginning to think that I had forgotten what a red anodized aluminium bolt looks like.
Karol
Hide Signatures
       Post #: 9
RE: Something strange happened at the field today - 9/23/2012 4:00 PM
K-Bob
Status: offline
quote:
ORIGINAL: Rocketman_
In fact, that is very strange to hear. More than likely some one had the head off and overtorqued the bolts when re-installing. DA suggests replacing them if you ever remove them.
K-Bob. The K is silent. "The only time you can have too much fuel is if you are on fire"
Hide Signatures
(in reply to Rocketman_)
       Post #: 10
RE: Something strange happened at the field today - 9/23/2012 4:37 PM
TimBle
Status: offline
Indeed.
Overtorqueinng an aluminium bolt is murder. The twist in the material increases the static tension in the bolt. When the engine fires the pressure rises and the tensile stress in those bolts can easily be exceeded. Correct torque is an absolute necessity.
Replacment of those bolts if they are ever removed, is an absolute necessity - aluminium work hardens and thus will get brittle with repeated engine cycles.
If this is true for DA engine then it's very wise to adhere to the recommended service interval for those bolts.
Hide Signatures
(in reply to K-Bob)
       Post #: 11
RE: Something strange happened at the field today - 9/23/2012 4:41 PM
flycatch
Status: offline
I find it refreshing that there are those in this hobby who know what they are talking about.
Hide Signatures
       Post #: 12
RE: Something strange happened at the field today - 9/23/2012 4:58 PM
lopflyers
Status: offline
quote:
ORIGINAL: flycatch
Me too, unfortunately most dont, and is difficult to tell the difference
Keep your wings level
Club Saito Member #693
Hide Signatures
(in reply to flycatch)
       Post #: 13
RE: Something strange happened at the field today - 9/23/2012 5:30 PM
Rocketman_
Status: offline
quote:
ORIGINAL: K-Bob
It is more likely that DA didn't replace the bolts because as I said in my previous post, the owner sends his engines back to DA for annual checkups and service because he does not work on his own engines. Perhaps it is difficult for some to believe that a product from a well known manufacturer can fail without the user causing the failure.
< Message edited by Rocketman_ -- 9/23/2012 11:32 PM >
Hide Signatures
(in reply to K-Bob)
       Post #: 14
RE: Something strange happened at the field today - 9/23/2012 5:37 PM
tony0707
Last Login: 5/14/2013
Status: offline
Da engines have been around a long time
Surprised this has not been posted here before
Cylinder heads coming off and damaging an expensive piston and liner is never acceptable in my opinion for any reason
This truly is ODD
" The power and performance glo fuel , 15 % Morgan Omega "
Hide Signatures
(in reply to lopflyers)
       Post #: 15
RE: Something strange happened at the field today - 9/23/2012 6:01 PM
Truckracer
Status: offline
Strange this thread should appear just on the same day I'm replacing those pretty red bolts with steel ones on my older DA100. For those who have never examined a DA jug closely, the top surface of the cylinder retaining flange is angled quite a bit from what would be parallel to the mating surface. Those aluminum bolts have to conform quite a bit (that means bend) as the head contacts the surface and is further torqued to specs. If you ever remove one of these bolts the bend in the bolt just below the head is quite easy to see and is present on every cylinder retaining bolt. This is not uncommon for many of our cylinders regardless of brand but the steel bolts seem to conform to the task better than aluminum.
By the way, my guess is that the aluminum bolts are a carry over from the early 3W days when they used quite a few aluminum fasteners. 15 or so years ago, the aluminum bolts retaining my 3W 60 carb broke in flight with less than pleasant results so I have never cared for aluminum bolts ever since.
Do a few searches and you'll find the DA aluminum bolt failing problem is not uncommon.
Hide Signatures
       Post #: 16
RE: Something strange happened at the field today - 9/23/2012 6:25 PM
TimBle
Status: offline
I'm just surprised that DA would still be using aluminium retaining bolts on the cylinder head. Sure it saves weight but it invites more problems than necessary.
Although aluminium may be stronger than steel per lb we still need UTS and toughness and unfortunately aluminium simply fails to deliver in these areas.
Hide Signatures
(in reply to Truckracer)
       Post #: 17
RE: Something strange happened at the field today - 9/23/2012 8:29 PM
koastrc
Status: offline
This one of those things I enjoy about the business of model aircraft. Why use aluminium? Only thing that comes to mind is galvanic corrosion. Perhaps as the thread goes on we shall find out. Thanks for the comments about a very good and interesting subject. Even us know it alls may learn something.
Hide Signatures
       Post #: 18
RE: Something strange happened at the field today - 9/23/2012 11:02 PM
TimBle
Status: offline
Aluminium to aluminium won't really create galvanic corrosion concerns. More concerning is galling between the two parts as they vibrate at slightly different frequencies.
What can create galvanic corrosion is the steel spring washer usually used underneath the hex / socket head of the bolt. But I can't see DA making an amateurish mistake in this area.
Hide Signatures
(in reply to koastrc)
       Post #: 19
RE: Something strange happened at the field today - 9/24/2012 12:45 AM
captinjohn
Status: offline
I will replace my DA 50 cyl bolts with steel ones...coated with a touch of anti-seeze.  I do not like any bolt made out of aluminum.   Capt.n.
Hide Signatures
       Post #: 20
RE: Something strange happened at the field today - 9/24/2012 1:09 AM
karolh
Status: offline
Good idea Capt,n if only for the peace of mind it will give.
Karol
Hide Signatures
       Post #: 21
RE: Something strange happened at the field today - 9/24/2012 2:02 AM
dirtyoldman00
Last Login: 5/15/2013
Status: offline
Ive got five DA engines 50's and they all have aluminum bolts and when I orderd spares they sent new aluminum bolts You mess with the bolts youll blow your warranty
< Message edited by dirtyoldman00 -- 9/24/2012 2:38 AM >
Hide Signatures
       Post #: 22
RE: Something strange happened at the field today - 9/24/2012 2:17 AM
captinjohn
Status: offline
quote:
ORIGINAL: dirtyoldman00
Ive got five DA engines 50's and 85's they all have aluminum bolts and when I orderd spares they sent new aluminum bolts You mess with the bolts youll blow your warranty
How much do they charge for the spares?   Also it sounds like if you mess with anything....you blow the warranty.   Their easy out of it all.
Hide Signatures
(in reply to dirtyoldman00)
       Post #: 23
RE: Something strange happened at the field today - 9/24/2012 2:37 AM
dirtyoldman00
Status: offline
spare bolts were cheap like a 50 cents apiece but they were a bear to torque you need a long 5mm allen wrench Ive read in many old threads this happens alot I would say probally from fuel or mixture or ignition timing off it would have to back fire to blow the head off you definatally cant re use them
Hide Signatures
       Post #: 24
RE: Something strange happened at the field today - 9/24/2012 3:01 AM
Truckracer
Status: offline
My DA engines are so far out of warranty that it doesn't matter any more what kind of bolts I use!
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Something strange happened at the field today
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
