RE: Something strange happened at the field today    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Something strange happened at the field today
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Something strange happened at the field today - 9/24/2012 11:26 AM
DaleD
Score: 105
Last Login: 5/22/2013
Status: offline
This is a VERY interesting thread.  Thanks to the OP for posting as I have learnt quite a bit just from reading.  Definitely a wealth of knowledge out there, all one needs to do is post the correct scenario.
Thank for your replies all
DaleD
Hide Signatures
(in reply to Truckracer)
       Post #: 26
RE: Something strange happened at the field today - 9/24/2012 3:36 PM
warbird_1
Score: 159
Status: offline
the answer you seek is simple ... Chinese
_____________________________
Scratch Builders make their own destiny
Hide Signatures
(in reply to karolh)
       Post #: 27
RE: Something strange happened at the field today - 9/24/2012 3:50 PM
Capt Cash
Score: 100
Last Login: 5/20/2013
Status: offline
I have a new DLE111 that had all four left side cylinder bolts loose from the factory. Luckily I think i've hopefully caught it in time.  The very first engine run on the plane was for 5 min, then I let cool and did another easy 5 min run. After this I noticed the leak on the left cylinder gasket. Thinking the obvious I soon discovered each cylinder bolt need a half turn or more.  They probably were not much over finger tight.  Not having a torque wrench I tightened them best I could with a long Allen key wrench.  The engine was still hot too so I think I probably got them good enough.
Anyway, lesson learned. Check your new engines.  The engine now has 5 gal through it and is going strong.  I'm wondering though if I should get new bolts and torque them correctly now?
If you cannot afford to do something right, then be darn sure you can afford to do it wrong. —
Hide Signatures
(in reply to DaleD)
       Post #: 28
RE: Something strange happened at the field today - 9/24/2012 4:59 PM
MTK
Score: 203
Status: offline
I put a DLE55 on a diet a couple years ago. Shaved a little more than 10% of the engine's weight. The diet included titanium bolts for the jug and crankcase. These were around 3 bucks a bolt as I recall. The long carb bolts were more like 10$ a bolt. Yes a bit pricy but worth the weight savings to me. The 55 has 6 gallons of gas through it, and NP and don't expect any.
You guys might consider using Ti bolts next time you want to change the DA stock bolts. BTW- if the bolts are aircraft grade there is plenty of strength in the aluminum. Threads are typically rolled, not cut.
Ti bolts are also anodizable, just like Aluminum...same colors as ally
Regards,
MattK
Hide Signatures
(in reply to Capt Cash)
       Post #: 29
RE: Something strange happened at the field today - 9/24/2012 7:19 PM
Ernie Misner
Score: 130
Status: offline
Just curious, are the titanium bolts actually lighter an aluminum?
Ernie
Hide Signatures
(in reply to MTK)
       Post #: 30
RE: Something strange happened at the field today - 9/24/2012 7:20 PM
DaleD
Score: 105
Status: offline
quote:
ORIGINAL: MTK
Would you be kind and post a link to the suppplier of them coloured Ti bolts?
DaleD
Hide Signatures
(in reply to MTK)
       Post #: 31
RE: Something strange happened at the field today - 9/24/2012 7:22 PM
TimBle
Score: 162
Status: offline
I'm not sure which "Aircraft grade"aluminium is being refered to?
2024
6061
7075?
All are high strength alloys but none are as strong as steel.
All are available in ALclad for corrosion resistance but this surface treatment typically reduces the effective tensile area of the component.
Ti bolts are tougher so they can be loaded and reloaded through more repeat cycles.
Neither has the UTS or  fatigue life of steel.
SInc eour two stroke are not hgh compression I'm sure the manufacturer can get away with AL bolts but at a reduced factor of safety.
I could understand the desire to use these on a 20cc to 30cc engine but on a >100cc i'd really like to understand why.
Hide Signatures
(in reply to MTK)
       Post #: 32
RE: Something strange happened at the field today - 9/24/2012 7:54 PM
karolh
Score: 310
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Truckracer
quote:
ORIGINAL: dirtyoldman00
Ive got five DA engines 50's and they all have aluminum bolts and when I orderd spares they sent new aluminum bolts You mess with the bolts youll blow your warranty
My DA engines are so far out of warranty that it doesn't matter any more what kind of bolts I use!
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 33
RE: Something strange happened at the field today - 9/24/2012 7:58 PM
MTK
Score: 203
Status: offline
7075-T6 low gall aluminum alloy. Make sure the threads are rolled and not cut
Try Mettec or Pro Bolt for Ti bolts. Prices are higher than a couple years ago, about 4$ a bolt.
Aluminum is slightly lighter than Titanium; either metal is less than half the weight of steel. But even the best aluminum A/C grade has a UTS of around 70 ksi. Titanium starts at around 120 ksi....fairly close to steel strength, but costs about 6X as much as SS.
Like I said, cost is not a terrible concern for my application so I buy Ti bolts where applicable
Regards,
MattK
Hide Signatures
(in reply to TimBle)
       Post #: 34
RE: Something strange happened at the field today - 9/24/2012 8:05 PM
matt43
Score: 100
Last Login: 4/29/2013
Status: offline
You do know that with da, the warty is almost really lifetime... Send in your motor they tear it down tell you what you need and you ONLY pay parts... NO labor!! So you only pay parts an labor... You would be an idiot to not send an engine back to DA... Just sent out a 150 and it cost $10 to ship USPS from Maryland to Arizona....
Hide Signatures
       Post #: 35
RE: Something strange happened at the field today - 9/24/2012 8:36 PM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: matt43
Yes, I know they take care of things but I'll still stay with my steel bolts. And I have sent engines back with the steel bolts in place .... they came back with the pretty red aluminum replacements! Frankly I haven't needed much service lately so its all pretty much a non issue to me. I still prefer to take care of minor issues at home.
Hide Signatures
(in reply to matt43)
       Post #: 36
RE: Something strange happened at the field today - 9/24/2012 10:34 PM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: MTK
Interesting thanks. I do use Pro Bolt ti bolts and some aluminium bolts on my Mtb and Road bicycles in non critical areas (like chain ring bolts)
If 7075 to T6 hardness is employed then that would offer some comfort. Howver , those bolts are fit once and toss when removed in high stress areas.
The Ti are a better option I agree.
Hide Signatures
(in reply to MTK)
       Post #: 37
RE: Something strange happened at the field today - 9/25/2012 12:19 AM
Ernie Misner
Score: 130
Status: offline
I make it a point never to stand in line with the prop arc, now best move back behind the jug as well! Can't you just see a jug go blasting off while you're flying and suddenly you would be in a dead stick situation with a drastically tail heavy craft..... For safety a tiny parachute could be attatched to each jug.
Hide Signatures
       Post #: 38
RE: Something strange happened at the field today - 9/25/2012 1:42 AM
retransit
Score: 125
Status: offline
Here's some pics of a DA blowing a jug with aluminum bolts. DA made it all better. The kid was flying. I got to repair the airframe damage.
This aircraft did a deadstick and couldn't make it over a perimeter fence.
Bob
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
       Post #: 39
RE: Something strange happened at the field today - 9/25/2012 2:39 AM
ARUP
Score: 134
Status: offline
Anodizing metal weakens it! Could be a factor.
Hide Signatures
       Post #: 40
RE: Something strange happened at the field today - 9/25/2012 2:41 AM
gsmarino2000
Score: 100
Status: offline
The angle on the back of the cylinder mounting flange is draft for the casting process. The proper way to make a bolted joint would be to spotface the back side of the flange so that the bolt head seats against a flat surface.
One advantage that I have noticed with the aluminum bolts. I have seen a DA 100 take a pretty hard crash that broke the aluminum bolts on both sides, and it was repairable. With steel bolts you typically break the cylinder or crankcase mounting flanges in that type of crash and throw the engine away.
Hide Signatures
(in reply to retransit)
       Post #: 41
RE: Something strange happened at the field today - 9/25/2012 3:14 AM
Truckracer
Score: 304
Status: offline
quote:
ORIGINAL: Ernie Misner
Jugs removing themselves from the engine happen from time to time in Fuel (Nitro) Harley drag racing. Not a pretty sight and there have been injuries from this.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 42
RE: Something strange happened at the field today - 9/25/2012 3:26 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: gsmarino2000
So why is the spot-facing NOT done?  Then shot blasted to prevent cracks.
I never met a engine I did not like !
Hide Signatures
(in reply to gsmarino2000)
       Post #: 43
RE: Something strange happened at the field today - 9/25/2012 3:42 AM
Champ-RCU
Score: 100
Status: offline
Forget the bolts, replaceable toy airplanes, GET THAT KID AWAY FROM THAT PROP AND ALL PROPS!
MTY
Hide Signatures
(in reply to captinjohn)
       Post #: 44
RE: Something strange happened at the field today - 9/25/2012 4:08 AM
captinjohn
Score: 247
Status: offline
Don,t  get too excited....the KID is just trying to imitate his  Da Da.  HMmm...click the switch and turn prop...just like DAD!!!!!!!!!!!
Hide Signatures
(in reply to Champ-RCU)
       Post #: 45
RE: Something strange happened at the field today - 9/25/2012 4:56 AM
Truckracer
Score: 304
Status: offline
I sense that KID is the pilot of the plane and not your average garden variety kid. Probably knows more about planes than many adults.
Hide Signatures
       Post #: 46
RE: Something strange happened at the field today - 9/25/2012 5:29 AM
retransit
Score: 125
Status: offline
It's funny how a picture gets people excited. And yes, Truckracer, you are correct in your assumption. He's a teenager and has been flying for a number of years. Dad can't fly as good as him. Good kid too. Has has feet on the ground. His first love is fishing, though.
Bob
Club Saito #800
Hide Signatures
       Post #: 47
RE: Something strange happened at the field today - 9/25/2012 5:35 AM
brockettman
Score: 105
Status: offline
That's the pit crew... Doesn't look like he's trying to start the beast, just checking the prop bolt torque... Gotta learn somehow!
Club SAITO Member #565
Hide Signatures
       Post #: 48
RE: Something strange happened at the field today - 9/25/2012 1:14 PM
a65l
Score: 105
Last Login: 5/7/2013
Status: offline
One little thing about Titanium, probablly not so much of a factor with R/C engines, it's fairly far up on the cathodic side of the galvanic series of metals, and in direct contact with Alumimimum will cause corrosion. Used to have to take special precautions on the "old F-14 where the rest of the airplane attached to the Ti wing center beam structure, which was all Titanium.
In God I trust.
All others pay cash.
Hide Signatures
(in reply to brockettman)
       Post #: 49
RE: Something strange happened at the field today - 9/25/2012 3:39 PM
hobby_man
Score: 105
Last Login: 3/23/2013
Status: offline
http://afsindustrial.com/huck360/performance-engineered
http://afsindustrial.com/huck360/?utm_source=MDcustom_enews&utm_medium=custom_enews&utm_content=Huck360_WatchVideo&utm_campaign=Huck%2B360
Hide Signatures
(in reply to a65l)
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Something strange happened at the field today
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
