Axi 4120/18    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Axi 4120/18
Page: [1]
Login
Axi 4120/18 - 9/23/2012 2:07 AM
squeaky penguin
Score: 105
Last Login: 6/19/2013
Status: offline
Hi all,
I got an Axi 4120/18 in a trade that is mounted on a .46 size Cap 232 that is suppose to weigh 5.5-6lbs. First off will this motor be a good fit for the plane? It appears to be a .60 size replacement, but I do live at 7,000'asl and wouldn't mind the extra power.
That in mind what battery ESC combo should I go with. I was thinking about a 5s would give me the right power, or do I need 6s? I guess that would then equate to a 4000-5000mah battery and about an 80amp ESC?
I've done a lot with electrics, but never anything this big. I just don't know where to start,
Brett
Hide Signatures
       Post #: 1
RE: Axi 4120/18 - 9/23/2012 3:35 PM
Dr Kiwi
Score: 120
Last Login: 6/1/2013
Status: offline
http://www.modelmotors.cz/index.php?page=61&product=4120&serie=18&line=GOLD
It seems to be rated very sensibly for around 3W/g = 960W max.. which gives you about 150W/lb....so on 6s that's about 40A....5s will let you use a slightly larger prop which might be advantageous given your altitude.... the Axi site indicates around 12x8 on 6s... 13" on 5s.
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to squeaky penguin)
       Post #: 2
RE: Axi 4120/18 - 9/25/2012 1:38 AM
squeaky penguin
Score: 105
Status: offline
So the idea behind that is on 5s, you would have less rpm, allowing you to use a larger prop? Giving you similar current draw? I went ahead and orderd an Ice 75. So I'm good there, just trying to figure out the battery. Is 5000mah overkill for a 46 size electric? Looks like it will physically fit, of course a small battery will be less weight and could provide better performace.
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 3
RE: Axi 4120/18 - 9/25/2012 3:54 AM
Dr Kiwi
Score: 120
Status: offline
Assuming equal C-rating, a larger mAh battery will cope with current draw better (less voltage drop under load)... and will give you better motor performance and longer flight time... conversely a lighter battery may give you better flight performance!
Hide Signatures
       Post #: 4
RE: Axi 4120/18 - 10/4/2012 2:55 AM
ray foley
Score: 100
Last Login: 12/21/2012
Status: offline
hi there from Toledo
With my axi 412018 I typically use 4000 mah lipos, a 2s and a 3s connected in series and prop for about 750 watts. I works great. At 7000 asl i can't recommend a prop or pitch but a watt meter will help you get it right.
ciao -rjf
volare est vivere
Hide Signatures
       Post #: 5
RE: Axi 4120/18 - 10/4/2012 4:25 PM
squeaky penguin
Score: 105
Status: offline
Already picked up some 5000mah 5s 20c batteries. I don't have the patience for charging two batteries for one flight. I've got a bunch of props to try and will run it though the watt meter before I madien it.
Hide Signatures
(in reply to ray foley)
       Post #: 6
RE: Axi 4120/18 - 10/9/2012 1:00 AM
squeaky penguin
Score: 105
Status: offline
Had it out at the field yesterday, and ran it though the wattmeter. The biggest prop I had out there was a 15x6, and it only pulled 32 amps for about 600 watts. 30 amps with a 14x7. On the postive note it flew well even with that setup. Hovering at 3/4 throttle.
So, time to order some more props. I might be able to fit a 16" with some bigger wheels. So maybe a 15x12, or 16x10, or 16x8. I think 40-45 amps would be best.
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.204RCU1
