how to convert motor to engine size?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> how to convert motor to engine size?
Page: [1]
Login
how to convert motor to engine size? - 9/28/2012 8:51 PM
flybyjohn
Last Login: 5/17/2013
Status: offline
Ok, here it goes. I was looking to build a plane from electric plans for glow power. I read some plans that called for a e480 outrunner engine that is a 1020kv. It said that it would run best with a 3 cell lithium battery and a 11x6 apc propeller. Now I kind of know how this works, 1020 kv means the rpm should be 1020 rpm per volt which means that with the 11.1v 3 cell bat. it should rev to 11,322 rpm. This is a 31 oz 39" wingspan plane and I would normally put a 10 to 15 glow on this size plane, but holy cow, my 46 thunder tiger can only swing a 11x6 at slightly over 12,000 rpm and it pulls around 5-6 lb airplanes. The watt rating on this motor is 250w so that equates to about 1/3 hp. So how does 1/3 hp turn an 11x6 at 11,000 rpm? Can anyone tell me what I am missing here?
Hide Signatures
       Post #: 1
RE: how to convert motor to engine size? - 9/29/2012 1:06 AM
ckreef
Status: offline
I can't answer your question technically but here is what I got that works for me.
My MiniStik currently has a WS of  36" and an AUW of 37oz.(just put it on the scale) I fly it with a OS .25LA.  It's a fast plane for it's size and good performance.
I would think a OS .25AX would work fine delivering about 3/4 hp and keep your weight down to a reasonable amount.  Just remember after converting your AUW  will be a bit over what was spec'ed for electric. Use whatever prop is recommended for your motor. Also use metal gear servos as I have already had to replace my nylon gear servos.
I would have loved to put a .25AX on the MiniStik but I used what I had. A .25AX would have made it a rocket ship - the LA motors are just low end motors.
Hide Signatures
(in reply to flybyjohn)
       Post #: 2
RE: how to convert motor to engine size? - 10/8/2012 1:06 PM
optech
Status: offline
Flybyjohn,
Your calculations are assuming a 100% efficient system. Doesn't work that way in reality. Most outrunners like the one you described are actually not that efficient. In general, about 75% efficieny is about right for outrunner type motors. Gear driven inrunners are better at about 87% efficiency. There are always exceptions to the rules of course but the above figures should get you in the ball park.
This means your 11,300 rpm figure at 75% would be around 8400 which seems about right for that outrunner, prop, and battery you describe.
Mike
Hide Signatures
(in reply to ckreef)
       Post #: 3
RE: how to convert motor to engine size? - 10/10/2012 10:03 PM
opjose
Status: offline
I prefer to utilize constant wattage maximums for a motor, then equate that to horsepower.
Doing that you can go back and forth easily, but you do need adjust for inefficiencies and advertizing hype.
e.g. 1 HP = 745.7 watts.
A powerful .32 glow engine puts out 1 - 1.2 hp, while a weaker LA type engine may only put out about .7-.8 HP.
It is a loose equivalence but it works pretty well for me.
_____________________________
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to optech)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
