RE: building board what do you use ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: building board what do you use ?
Page: <<   < prev  1 [2]
Login
RE: building board what do you use ? - 9/29/2012 10:32 PM
Boomerang1
Score: 120
Last Login: 6/19/2013
Status: offline
1/2 inch ply on a 1'' steel angle frame. I use dressmakers pins & hammer them in with a pin hammer.
One or two light taps gets them in. Twist & pull with pliers to remove them. Quick, easy & secure. - John.
_____________________________
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to grh_70)
       Post #: 26
RE: building board what do you use ? - 9/29/2012 10:50 PM
Speedy-Gonzales
Score: 141
Last Login: 6/16/2013
Status: offline
Yeh.... if you can't twist and pull or you have driven the pins through into the underlying hardwood board just bend the pin over at a 90 degree and then twist and pull them out that way. Oh yes...throw bent pin in trash can! :>)
I have never used a JIG but I do build "above the board" which means my structures are alway elevated and I rely on a good straight edge and measurements off the flat surface below. This works well for me. Especially when building wings with progressive washout or a wing with only washout on the outer panels and a flat center section.
Round fuselages for me are also built in this manner.
About the only structures I build flat on the board are flat structures like tail feathers and some sub-assemblies.
Hide Signatures
(in reply to Boomerang1)
       Post #: 27
RE: building board what do you use ? - 9/29/2012 11:29 PM
Chad Veich
Score: 275
Status: offline
I have a couple of different building tables but the largest of them is of welded steel construction with a 3/4" MDF top. On top of that is tempered glass and I build directly on the glass itself. Works great because I can simply tack glue directly to the glass and then clean up the glue with a single edge razor blade when I'm done. In those instances where I need to build directly over the plan I simply tape it to the glass and then cut out small sections of the plan where I need to tack glue to the glass. I also utilize 1-2-3 blocks for holding things down, holding them vertical and/or at 90 degrees to some other surface. I've reached the point where I'm not sure I could build without the aid of the blocks any more! They really are very handy. However, great care must be taken when combining glass and heavy steel objects with pointy edges!
Hide Signatures
(in reply to Speedy-Gonzales)
       Post #: 28
RE: building board what do you use ? - 9/30/2012 1:09 AM
jjonnette@aol.com
Score: 100
Last Login: 9/30/2012
Status: offline
I am new to this RC Universe and it is great. I have been an RCer since 1960,  however do to some health problems I have had to lay off for about 6 years. Anyway Johnny is back. I have been enjoying reading many comments by our RC brothers. For those much younger then me I started with an old Ground Base Bramco, 110 inch whip Attenna and push button on the  of telephone wire. Single channel 27 mghurtz, one punch was right rudder, two puches was left rudder quick blip was kick up elevtor or a sequence throttle. The escapement was rubber wound rubber band that moved surfaces. I moved quickly to a Bramco hand held single Channel and on to reeds  and analog propro and then Digital now I guess I will move into 2Mghrtz stuff. I hope no one will laugh if I ask stupid questions from time to time. RC'ers are the greatest bunch of guys. While I was in the USAF I moved around the states a lot and met great guys. I am moving into electrics so I have lots of questions in my head.
Hide Signatures
       Post #: 29
RE: building board what do you use ? - 9/30/2012 7:55 AM
Rotten40851
Score: 110
Status: offline
Here is what I use, Its all Magnetic and it workd great
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Futaba 18 MZ... Nothing even comes Close!!!
Hide Signatures
(in reply to jjonnette@aol.com)
       Post #: 30
RE: building board what do you use ? - 9/30/2012 2:39 PM
bikerbc
Score: 121
Status: online
Welcome back Jhonny
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to Rotten40851)
       Post #: 31
RE: building board what do you use ? - 9/30/2012 3:12 PM
KaP2011
Score: 115
Status: offline
Glad to have you back Johnny.
I use a hollow core door supported by a 2X4 frame with a piece of fibre insulation like you use when building a house. It has worked pretty good for several years now but will soon need replacing. Hollow core doors aren't what they used to be, I've actualy put my elbo thru once when I was leaning on it without the fibre insulation on top on it. I'm thinking of going with a steel top and magnets. I think I'm going to order the jig setup from  http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/tools/magnetic_building_board/order_magnetic_fixtures.htm , It's a really nice looking setup.
KaP2011
AMA #408493
Hide Signatures
(in reply to bikerbc)
       Post #: 32
RE: building board what do you use ? - 9/30/2012 8:54 PM
dadragon
Score: 112
Last Login: 6/8/2013
Status: offline
I do like chad, a 32x85 mica counter top bolted to a 1x2 rectangular tube frame to glue and weight down.I use a lot of 10lb sand bags and sts bar stock.
Hide Signatures
(in reply to KaP2011)
       Post #: 33
RE: building board what do you use ? - 9/30/2012 10:06 PM
Johnny_Zero
Score: 105
Last Login: 6/18/2013
Status: offline
1/4 tempered plate glass. Spray the glass with 3m 77, let is tack off, lay plans down on this. Spray the plans with 3m 77 and lay wax paper on this. Spray the wax paper with 3m 77. Lay out your spars and ribs, they stick and start gluing. This works great for perfect wings. For fuselage depending on how it is built this can work for the first stages of construction.
Carl Goldberg Ultimate Brotherhood # 60.
Hide Signatures
(in reply to dadragon)
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
