Water cooling setup?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Water cooling setup?
Page: [1]
Login
Water cooling setup? - 9/29/2012 8:01 PM
palmen
Score: 100
Last Login: 3/26/2013
Status: offline
hi, can someone help me with the cooling setup, its my first build.
I have 2 waterpickups, 2 nipples on piston coup, 2 nipples on mainfould and 2 on the pipe. how do i draw the waterlines?
thanx!
_____________________________
2 Fast 4 U
Hide Signatures
       Post #: 1
RE: Water cooling setup? - 9/29/2012 8:23 PM
mistycreekboats
Score: 105
Last Login: 5/25/2013
Status: offline
post a picture of inside ur boat
Randy Danchuk
Misty Creek Boats Canada
Hide Signatures
(in reply to palmen)
       Post #: 2
RE: Water cooling setup? - 9/29/2012 8:30 PM
palmen
Score: 100
Status: offline
here is a pic!!!
Click to see fullsize image.
Click for fullsize
2 Fast 4 U
Hide Signatures
(in reply to mistycreekboats)
       Post #: 3
RE: Water cooling setup? - 9/29/2012 8:57 PM
goodson
Score: 100
Status: offline
One line to the manifold, out and to the lower nipple on the cylinder head, then out of the hull. Second line to the pipe and then out of the hull.
Hide Signatures
       Post #: 4
RE: Water cooling setup? - 9/29/2012 9:05 PM
w3bby
Score: 120
Last Login: 5/23/2013
Status: offline
I'd go with one to the waterjacket, in low, out high and overboard and the other to manifold then pipe and out.
You are going to be cutting that exhaust header down a lot before you find a tuned length so don't plan your exhaust mounting hardware at that length. You will be looking for 320 - 370mm from exhaust flange to widest part of pipe measuring down the centre of the pipework.
Are you a member of Stockholm Model Boat Club, lots of good help and a friendly crowd.
Ian
Hide Signatures
       Post #: 5
RE: Water cooling setup? - 9/29/2012 9:45 PM
palmen
Score: 100
Status: offline
hi thx for fast replay.
the lenght from the mainfold to widest on the pipe is now 37cm,
is that right?
2 Fast 4 U
Hide Signatures
(in reply to w3bby)
       Post #: 6
RE: Water cooling setup? - 9/29/2012 9:51 PM
palmen
Score: 100
Status: offline
Here is some pics on the Makara 57 build with A Zen7 motor
Click for fullsize
Click for fullsize
2 Fast 4 U
Hide Signatures
       Post #: 7
RE: Water cooling setup? - 9/30/2012 1:20 AM
w3bby
Score: 120
Status: offline
You are still going to come in some from that, Prestwich instructions. Once you start getting to the sweet spot you will cut the exhaust so you have about 1 cm past the o-rings in the pipe.
Ian
Hide Signatures
       Post #: 8
RE: Water cooling setup? - 9/30/2012 1:57 PM
palmen
Score: 100
Status: offline
Is this looking ok?
Click for fullsize
2 Fast 4 U
Hide Signatures
(in reply to w3bby)
       Post #: 9
RE: Water cooling setup? - 9/30/2012 2:14 PM
lipdaddy
Score: 100
Last Login: 5/22/2013
Status: offline
Looks good. You will probably need to bring that pipe in some.
Ryan
http://lipgensfabrication.com
Hide Signatures
       Post #: 10
RE: Water cooling setup? - 9/30/2012 3:00 PM
palmen
Score: 100
Status: offline
Ok thanks
2 Fast 4 U
Hide Signatures
(in reply to lipdaddy)
       Post #: 11
RE: Water cooling setup? - 9/30/2012 5:09 PM
Jackal1983
Score: 105
Last Login: 5/24/2013
Status: offline
Hi Palmen,
Looking like a nice build...
I alway run my water lines as follows.
Pickup 1 > Manifold in> Manifold out to Lower Head Nipple> Higher Nipple out of Hull.
Pickup 2 > To exhaust orings then out the side of hull.
The reason you run waterlines like this is to stop cold seizures... So you warm the water up before it goes into the head.
When you strip you engine and you get marks down the cylinder this is caused by cold water cooling the head to much and it nipping the piston.
As for the exhaust measure ... get a long bit of string..
from the joining split in your manifold. measure around the bend and to the widest point of the pipe. this measurement should be 13.5 inch to start with....
dont let the header pipe go to far in the pipe because this will make it so the pipe will not work correctly.
Looking good tho!!!
Jack
MillPond Models
Hide Signatures
       Post #: 12
RE: Water cooling setup? - 9/30/2012 6:20 PM
palmen
Score: 100
Status: offline
Another question, can i put my tank or iv bag ( not decide yet)to the right side of the hull to weight up for the pipe?
2 Fast 4 U
Hide Signatures
(in reply to Jackal1983)
       Post #: 13
RE: Water cooling setup? - 9/30/2012 8:32 PM
qdemon
Score: 100
Status: offline
quote:
ORIGINAL: palmen
Is this looking ok?
That is the perfect route for your water lines you will not have any problems with that.
Bob.
Hide Signatures
       Post #: 14
RE: Water cooling setup? - 10/1/2012 12:44 AM
w3bby
Score: 120
Status: offline
quote:
ORIGINAL: palmen
I prefer the centre of the hull between radiobox and motor.
Pipe wise you want to measure as shown on the picture, you will probably end up around 340mm.
Click for fullsize
Ian
Hide Signatures
       Post #: 15
RE: Water cooling setup? - 10/1/2012 8:39 PM
glennb2006
Score: 105
Last Login: 10/31/2012
Status: offline
One thing I find makes a big performance difference on the Makara is a forward bulkhead, it takes out all the tendancy of the hull to twist and turn at high speeds. I have two like this, and ran them both "before" and "after". It is worth doing. They can also handle a lot of motor, big bores and twins go very well in them.
Great hulls though, my one boat I will not part with.
Have fun.
Glenn
Hide Signatures
(in reply to w3bby)
       Post #: 16
RE: Water cooling setup? - 10/3/2012 10:37 AM
MrMikeG
Score: 115
Status: offline
You shouldn't use that yellow Tygon for water, it expands when it gets hot and will blow right off the nipples, use silicone for water, tygon for fuel.
Hide Signatures
(in reply to glennb2006)
       Post #: 17
RE: Water cooling setup? - 10/4/2012 3:48 PM
palmen
Score: 100
Status: offline
 Yee more silicon is on the way, did the setup just for show my set, thanks anyway.
2 Fast 4 U
Hide Signatures
(in reply to MrMikeG)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
