Atlanta    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> Atlanta
Page: [1] 2 3 4   next >   >>
Login
Atlanta - 9/29/2012 11:45 PM
jetmech43
Score: 100
Last Login: 5/18/2013
Status: offline
Does the Atlanta use an offset header or what other pattern planes use the off set to go around the nose gear reason im asking I just came across I believe is an Atlanta but not sure and he has a Summit 1 too said he would take 100 bucks for both of them has YS that is seized and what looks like MK retracts
_____________________________
smooth pass
Hide Signatures
       Post #: 1
RE: Atlanta - 9/30/2012 1:08 AM
flywilly
Score: 102
Last Login: 5/21/2013
Status: offline
Yes, the Atlanta uses an offset header. I believe the Hatori Aurora or Cosmos header may be very close, the problem may be the amount of 'drop' as the Atlanta had a very tight fitting belly pan compared to the Aurora or Cosmos.
Hide Signatures
(in reply to jetmech43)
       Post #: 2
RE: Atlanta - 9/30/2012 2:04 AM
jetmech43
Score: 100
Status: offline
ok thanks though t it was an Atlanta, its in pretty good shape, does any one have parts for a YS I can clean the engine to get it unseized but not sure if the check valve will be serviceable
smooth pass
Hide Signatures
(in reply to flywilly)
       Post #: 3
RE: Atlanta - 9/30/2012 2:05 AM
jetmech43
Score: 100
Status: offline
when I get them I will post some pics would any body be interested in the Summit?
smooth pass
Hide Signatures
       Post #: 4
RE: Atlanta - 9/30/2012 6:41 PM
jetmech43
Score: 100
Status: offline
ok got the plane and the wing not to good shape going to try and repair it, does anybody have an Atlanta wing they dont need
smooth pass
Hide Signatures
       Post #: 5
RE: Atlanta - 9/30/2012 7:37 PM
PatternPilot
Score: 125
Last Login: 5/20/2013
Status: offline
sent you a pm
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
       Post #: 6
RE: Atlanta - 9/30/2012 7:46 PM
jetmech43
Score: 100
Status: offline
sent you one back
smooth pass
Hide Signatures
(in reply to PatternPilot)
       Post #: 7
RE: Atlanta - 9/30/2012 8:48 PM
rv7driver
Score: 105
Last Login: 5/16/2013
Status: offline
Heres a Pic of my Atlanta showing the Header with a YS 2 stroke. Pete
Click to see fullsize image.
Click for fullsize
the old saying in aviation is keep the dirty side down!; how Boring!
Hide Signatures
       Post #: 8
RE: Atlanta - 9/30/2012 9:18 PM
jetmech43
Score: 100
Status: offline
yeap just like the one I got
smooth pass
Hide Signatures
(in reply to rv7driver)
       Post #: 9
RE: Atlanta - 9/30/2012 10:17 PM
PatternPilot
Score: 125
Status: offline
jetmech43
sent you info you wanted....
scott
Hide Signatures
       Post #: 10
RE: Atlanta - 9/30/2012 10:46 PM
jetmech43
Score: 100
Status: offline
sent you the info you wanted
smooth pass
Hide Signatures
       Post #: 11
RE: Atlanta - 9/30/2012 10:48 PM
jetmech43
Score: 100
Status: offline
looks like your header bolts are backing out
smooth pass
Hide Signatures
       Post #: 12
RE: Atlanta - 9/30/2012 10:49 PM
dhal22
Score: 138
Status: offline
Of course Don can mail you a wing core set in the morning. Mine set was very well cut. No need to wait months and months from other providers.
David
Hide Signatures
       Post #: 13
RE: Atlanta - 9/30/2012 10:51 PM
jetmech43
Score: 100
Status: offline
repairing wing on it now not as bad as I thought, got the engine apart now piston looks good dont know about the bearing yet im sure it will need new ones its a YS 60 FR as it says on the case
smooth pass
Hide Signatures
       Post #: 14
RE: Atlanta - 9/30/2012 11:42 PM
stuntflyr
Score: 137
Status: offline
quote:
ORIGINAL: dhal22
Original templates?
LOL.
Chris...
Hide Signatures
(in reply to dhal22)
       Post #: 15
RE: Atlanta - 9/30/2012 11:58 PM
jetmech43
Score: 100
Status: offline
quote:
ORIGINAL: dhal22
who be Don
smooth pass
Hide Signatures
       Post #: 16
RE: Atlanta - 10/1/2012 1:54 AM
hrrcflyer
Score: 121
Status: offline
Hey Jetmech43,
Don goes by Frequent Flyer, here on RCU. He is making quite a few classic pattern planes available for us, including the Atlanta. His craftsmanship is outstanding.
Good luck with your Atlanta.
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
       Post #: 17
RE: Atlanta - 10/1/2012 4:05 AM
Atlanta 60
Score: 100
Status: offline
Pictures Please!!!
You should be able to get a YS check valve from YS Parts and Service (pn: YS0405)
http://www.ysengines.net/support/parts/
Since you have it apart I would (personally) put a set of bearings in it...
A little problem with the YS60 is that the gasket sets are not available any more so you will more than likely have to make your own, unless you can find someone has a set laying around...Not that big of a deal though...Good thing is the diaphragm, spring, plunger, needle valve/seat and carb o-rings are still available...I'd personally order a set of those and replace everything while I had it tore down...
I attached a copy of the manual in case you need it...
Good Luck with your Atlanta!!!
Click to see the file in new window.Attachment.pdf
The less I fly....The less I crash...
Hide Signatures
(in reply to hrrcflyer)
       Post #: 18
RE: Atlanta - 10/1/2012 4:30 AM
rv7driver
Score: 105
Status: offline
Chuck, thanks for the info will order parts for a couple that need TLC. phone # is 775-267-9252 for YS parts and service. Pete
Hide Signatures
(in reply to Atlanta 60)
       Post #: 19
RE: Atlanta - 10/1/2012 10:11 AM
jetmech43
Score: 100
Status: offline
ok thanks
smooth pass
Hide Signatures
       Post #: 20
RE: Atlanta - 10/1/2012 11:55 AM
dhal22
Score: 138
Status: offline
quote:
ORIGINAL: stuntflyr
Original templates?
LOL.
Chris...
Exactly..............................
David
Hide Signatures
(in reply to stuntflyr)
       Post #: 21
RE: Atlanta - 10/1/2012 11:57 AM
dhal22
Score: 138
Status: offline
Chuck, great to see you back on the forum. It figures an Atlanta would be the thread.
David
Hide Signatures
       Post #: 22
RE: Atlanta - 10/1/2012 4:09 PM
hrrcflyer
Score: 121
Status: offline
quote:
ORIGINAL: dhal22
Dhall22,
I had to laugh out loud when I read your comment. I was thinking the exact same thing as I read Chuck's post. I guess great minds think alike..............
Hey Chuck, it is great to see you back in the Classic Pattern Forum, Buddy.
Jetmech43,
By all means, please post some pictures. An Atlanta in almost any condition is a thing of beauty.
David
Hide Signatures
       Post #: 23
RE: Atlanta - 10/1/2012 4:29 PM
80sPattern
Score: 100
Last Login: 5/3/2013
Status: offline
quote:
ORIGINAL: hrrcflyer
David
Jet,
Here is a little motivation for you.
Doug
Click for fullsize
Hide Signatures
       Post #: 24
RE: Atlanta - 10/1/2012 4:39 PM
KaP2011
Score: 115
Last Login: 5/19/2013
Status: offline
Wow! That is a beautiful plane.
KaP2011
AMA #408493
Hide Signatures
(in reply to 80sPattern)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.157RCU1
