Eagle temp problem !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> Jet Central Turbines - Artes Jet >> Eagle temp problem !
Page: [1]
Login
Eagle temp problem ! - 9/29/2012 11:53 PM
Ian Prentice
Score: 100
Last Login: 5/3/2013
Status: offline
Hi I have a problem with an eagle ! The temp when I switch on is saying approx 135 rather than the 9 that it is ! I have just put a new thermocouple on and it says exactly the same so I am guessing it has to be an ecu issue ! Obviously it says cooling and wont allow a start !Anyone had this happen or any advice ! Thanks
Hide Signatures
       Post #: 1
RE: Eagle temp problem ! - 9/30/2012 5:50 AM
RONW
Score: 100
Last Login: 5/8/2013
Status: offline
Hope someone with more knowledge of the ecu, whatever version you have, replies to you. I have a feeling it could be to do with the calibration of the probe but not sure where that parameter is situated in your ecu menu or even if it is accessible without an unlock code.
Hide Signatures
(in reply to Ian Prentice)
       Post #: 2
RE: Eagle temp problem ! - 9/30/2012 9:01 AM
Ian Prentice
Score: 100
Status: offline
Thanks ! It's a little odd in that when you remove the thermocouple from the port it drops to the preset 8 deg ! The temp probe does work when heat is applied all be it 120 over what it should be !
Hide Signatures
(in reply to RONW)
       Post #: 3
RE: Eagle temp problem ! - 9/30/2012 1:19 PM
Dr Honda
Score: 100
Last Login: 5/20/2013
Status: offline
If it's one of Gasper's ECU's (xicoy)... it should go to 0 degrees if the temp probe is unplugged.
But, I'm sure Eric will chime in soon.
_____________________________
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.141RCU1
