Triangle Stock?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Triangle Stock?
Page: [1]
Login
Triangle Stock? - 9/30/2012 10:56 PM
JH313
Score: 115
Last Login: 5/20/2013
Status: offline
I am rebuilding a plane and wondering, is there a difference between triangle stock and a regular "rectangle" piece of wood of the same size and material?
Thanks.
_____________________________
The Cub Brotherhood Member #20
Ultra Sport Brotherhood #134
Hide Signatures
       Post #: 1
RE: Triangle Stock? - 9/30/2012 11:02 PM
RCPAUL
Score: 122
Last Login: 5/21/2013
Status: offline
Triangle stock will have half the weight!
Gosh, model airplanes are not a matter of life and death - they''''''''re more important than that!
Hide Signatures
(in reply to JH313)
       Post #: 2
RE: Triangle Stock? - 10/1/2012 12:09 AM
tailskid
Score: 199
Status: offline
That's about it!
+1
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to RCPAUL)
       Post #: 3
RE: Triangle Stock? - 10/1/2012 1:01 AM
da Rock
Score: 265
Status: offline
There is more difference than weight.
The way I look at the square stick I'm going to use for triangular bracing is that the stick will provide TWO triangular strips.
Good flying wit ya today
Hide Signatures
(in reply to tailskid)
       Post #: 4
RE: Triangle Stock? - 10/1/2012 9:11 AM  1 votes
sebo
Score: 111
Status: offline
A SQUARE STICK WILL PROVIDE MORE STRENGTH BECAUSE THERE IS MORE WOOD GRAIN INVOLVED....THE NARROW END OF A TRIANGULAR STICK HAS VERY LITTLE STRENGTH WHEREAS A SQUARE STICK WILL PROVIDE MORE STRENGTH BECAUSE OF THE AMOUNT OF EXTRA WOOD AND GRAIN SUPPORTING THE AREA THAT WOULD BE SKINNY ON THE TRIANGULAR PIECE.
TRY BREAKING A TRIANGULAR STICK AND THEN A SQUARE STICK. SQUARE WINS......YOU DON'T USE MUCH TRIANGULAR STOCK IN AN AIRCRAFT ANYHOW.  NOT MUCH WEIGHT INVOLVED THERE.  IF YOU ARE ADDING STOCK JUST TO GIVE YOURSELF SOME SURFACE AREA TO ADHERE COVERING TO, USE TRIANGULAR; STRENGTH ISN'T AN ISSUE....JUST MY OPINION..
Hide Signatures
(in reply to JH313)
       Post #: 5
RE: Triangle Stock? - 10/1/2012 9:28 AM
beepee
Score: 109
Status: offline
sebo,
What you say is true, but you are ignoring the stress riser at the edge of the rectangular stock. This will contribute to fatigue in the base material at the edge. Triangle stock having a bit of flexibility at that edge will not cause such a concentration of stresses.
In the end we are not talking about much weight, or failure potential. I doubt anyone has recorded a failure caused by either installation.
Do what you like either way.
Bedford
Hide Signatures
(in reply to sebo)
       Post #: 6
RE: Triangle Stock? - 10/1/2012 10:26 AM
sebo
Score: 111
Status: offline
Understood...I do agree with you....never thought of it that way...I learn something every day.....Thanks.
Hide Signatures
(in reply to beepee)
       Post #: 7
RE: Triangle Stock? - 10/1/2012 1:53 PM
KW_Counter
Score: 141
Last Login: 5/19/2013
Status: offline
Beepee,
Could you please explain this further?
KW_Counter
Hide Signatures
       Post #: 8
RE: Triangle Stock? - 10/1/2012 4:17 PM
jaka
Score: 158
Status: offline
Hi!
Triangle balsa is used in some places and square balsa is used in some places...what is it you want to know?
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to JH313)
       Post #: 9
RE: Triangle Stock? - 10/1/2012 10:00 PM
da Rock
Score: 265
Status: offline
In most uses, triangular stock is there to reinforce a joint. It's real value is in the area that borders the seam between the two plates.
Ever see anyone use triagular spruce? or any other hardwood? No? I don't think I ever did. And a lot of times, the stock used was medium balsa. No attempt at all to put real strong wood in because it really wasn't being put in to provide much other than joint seam reinforcement.
Hide Signatures
(in reply to jaka)
       Post #: 10
RE: Triangle Stock? - 10/1/2012 10:39 PM
carrellh
Score: 179
Status: offline
If you slightly round the corners, will it relieve the stress riser?
- Carrell
Hide Signatures
       Post #: 11
RE: Triangle Stock? - 10/2/2012 11:07 PM
rlipsett
Score: 100
Status: offline
triangle stock is good for having a prebeveled surface for control surfaces
Hide Signatures
(in reply to carrellh)
       Post #: 12
RE: Triangle Stock? - 10/5/2012 8:51 AM
beepee
Score: 109
Status: offline
KW Counter,
I will try to explain ...
Fatigue failure appears at areas of concentrated stresses. At the outer edge of the rectangular stock, stress in the base material is concentrated more so than the tapered edge of triangle stock(mostly from vibration effects).
This is more important for the anally retentive such as myself than for real model builders. All of my birds have died from catastrophic failure before fatigue has set in.
Bedford
Hide Signatures
(in reply to rlipsett)
       Post #: 13
RE: Triangle Stock? - 10/5/2012 8:53 AM
beepee
Score: 109
Status: offline
KW Counter,
Bedford
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
