Getting started in electric F3A    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> Getting started in electric F3A
Page: [1]
Login
Getting started in electric F3A - 10/1/2012 7:39 PM
highfly3D
Score: 100
Last Login: 5/10/2013
Status: offline
Hi all,
After thinking a lot... i have finally decided to get started in electric F3A, the main reason behind this is synthetic fuel with 30% nitro. I think electric will be quite n clean. I need suggestions what Motor n ESC & batteries will be the cheapest to get started. I am flying masters sequence.
Regards,
Harry
_____________________________
I will say it only once Yak 54 the best aerobatic plane ever made.
Hide Signatures
       Post #: 1
RE: Getting started in electric F3A - 10/1/2012 8:35 PM
jetmech43
Score: 100
Last Login: 5/18/2013
Status: offline
possiabilities are endless ,go to F3A unlimited and start looking from there will be a good start for you
smooth pass
Hide Signatures
(in reply to highfly3D)
       Post #: 2
RE: Getting started in electric F3A - 10/1/2012 8:36 PM
jetmech43
Score: 100
Status: offline
of course there alot of opinions im sure people will chime in
smooth pass
Hide Signatures
(in reply to jetmech43)
       Post #: 3
RE: Getting started in electric F3A - 10/2/2012 2:10 PM
bem
Score: 115
Last Login: 5/20/2013
Status: offline
Hi,
Are You converting an existing glow powered F3A machine to electric? If Yes - what model?
Or is it a new full 2 x 2M F3A electric powered machine You want?
Or could a plane like Sebart MythoS 125E work also?
http://www.rcgroups.com/forums/showthread.php?t=1719280
http://www.sebart.it/F3A.html
There is also a full 2 x 2M MythosS Pro avaliable here in Europe now but I do not know when it will arrive in US.
For example from this company http://www.f3alorenz.de/index-home-f3a.htm
ExtremeFlight 2M Vanquish is a rather popular F3A machine that is not so expensive.
http://www.extremeflightrc.com/html/2MVanquish.html
Just check threads on above planes to see what motors, ESC and suitable LiPo is used.
/Bo
< Message edited by bem -- 10/2/2012 2:37 PM >
Hide Signatures
       Post #: 4
RE: Getting started in electric F3A - 10/2/2012 2:38 PM
nonstoprc
Score: 110
Last Login: 5/21/2013
Status: offline
I have one Neu f3a motor ($275) and one Jeti Advance Pro 90 ESC ($120) for sale on RCU. Both are very low usage and known competitive for all pattern classes.
sorry for the shameless advertisement.
< Message edited by nonstoprc -- 10/3/2012 12:33 AM >
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to bem)
       Post #: 5
RE: Getting started in electric F3A - 10/2/2012 3:03 PM
Zeeb
Score: 111
Status: offline
Electric F3A and cheapest????? lol.... sorry but that's a contradiction in terms.
I've recently decided to give it a try as well and do not have any F3A experience or equipment and virtually none of my IMAC GS gasser stuff is of any use. Of course you can start smaller than 2M and with less expensive equipment but one thing you need to consider is how you're going to charge batteries at the field? There's a reason you see a lot of Honda generators when that electric powered F3A crowd shows up at the field.
Long story short; I've dropped over $5,000.00 in the last couple of weeks and don't have all the model stuff yet, but I am reasonably close with some pretty nice equipment.
So if you'd care to share your idea of what you'd like to spend, it would be easier for these guys to offer suggestions?
Zeeb
Hide Signatures
(in reply to nonstoprc)
       Post #: 6
RE: Getting started in electric F3A - 10/2/2012 6:38 PM
serious power
Score: 100
Status: offline
Hi,
No need to spend anything like $5,000 to get started or even be competitive.
You can spend $10,000 also.
But there are good/very good models,motors,esc's, chargers, power supplies and batteries out thereat a very reasonable price.
Batteries ; http://www.hobbyking.com/hobbyking/store/__21377__ZIPPY_Compact_5000mAh_10S_25C_Lipo_Pack.html
Chargers ; www.revolectrix.com
Power supplies ; http://www.feathermerchantrc.com/
You can charge at home then from your car to get up and going - the no,, of batteries you get matters.
An Axi motor or Hacker outrunner and Castle Esc are great value and very competitive ; www.f3aunlimited.com
Model ; http://www.f3aunlimited.com/webstore/index.php?main_page=product_info&cPath=8_70&products_id=475
Total ; inc 4 packs less than $2,000 for a good set up.
Brian
< Message edited by serious power -- 10/2/2012 11:28 PM >
Hide Signatures
(in reply to Zeeb)
       Post #: 7
RE: Getting started in electric F3A - 10/3/2012 10:20 AM
highfly3D
Score: 100
Status: offline
Many thanks to all for the details given on electric F3A plane, will post more details for which setup i will go for. I am in the process of building this plane, but earlier i had planned for glow power, but now since i am going electric i have to build the plane as light weight as possible
Hide Signatures
(in reply to serious power)
       Post #: 8
RE: Getting started in electric F3A - 10/3/2012 6:12 PM
NeilRivera
Score: 100
Status: offline
You can spend less than $5000 to try it out, look at the Sebart Wind S 50. Uses one 6 cell lipo, I have this as my practice plane. It is small enough to fit in most vehicles and won't cost an arm an a leg and it flies really well. If you are starting in Sportsman or Intermediate it is a perfect candidate. Use the recommended Hacker setup. As for a charger, well there are many options to choose from. And you might want to consider Vquick's charge box, it is custom made and has built in power supplies. I don't fly glow F3A anymore and really enjoy the electric scene....
Hide Signatures
       Post #: 9
RE: Getting started in electric F3A - 10/3/2012 6:17 PM
NeilRivera
Score: 100
Status: offline
I failed to mention that the Wind S 50 can do the Advanced and Masters routine quite well, I am currently practicing Advanced with it. A fellow flier at our field is flying the masters and does really well ...
Hide Signatures
(in reply to NeilRivera)
       Post #: 10
RE: Getting started in electric F3A - 10/4/2012 5:03 PM
Zeeb
Score: 111
Status: offline
like I said above; it would help if the OP would indicate how much money he'd like to consider spending.
And we don't buy this stuff because we need it, we buy it because we WANT IT. Everything else is just rationalizing....
Zeeb
Hide Signatures
       Post #: 11
RE: Getting started in electric F3A - 10/5/2012 7:02 AM
highfly3D
Score: 100
Status: offline
A million thanks for all for giving me the inputs for electric F3A airplane
I have seen many chargers to charge lipo batteries... but i am confused which one to go for.... there are really so many out there i want a charger with which i can charge 3s to 10s pack with a reasonable price
Regards,
Harry
Hide Signatures
(in reply to Zeeb)
       Post #: 12
RE: Getting started in electric F3A - 10/5/2012 7:52 AM
bem
Score: 115
Status: offline
Hi,
I do not know if you have thought about it but for 10 cell LiPo driven 2M F3A plane You usually have two 5 cell pack in series to get one 10 cell pack, so a charger capabale of charging 5 cell or more on two ports will work.
But You can go with two chargers also. Or one dual port charger to achive this.
If You have 110/240 volt at the flying field it may be enough with one single port charger if you get LiPo packs that can handle fast charging like 5C (current of 5 times capacity of the LiPo pack) and that way can charge rather quick each pack.
If You are going to charge from a 12 volt source like Pb (lead) supply battery (designed to handle deep discharges, not a car start battery) You perhaps would like a single charger with dual ports like ThunderPower TP820CD or Hyperion EOS 0720i Super DUO3. You need a Powersupply at home when charging at home since most chargers do not have that built in in them.
I use Hyperion EOS 0720i Super DUO3 myself and charge mostly 6 cell LiPo packs (two packs at the same time, one on each of the two charge outputs) and it works great at the field on a 80 Ah Pb marine dual purpuse (supply) 12 volt battery. I usually charge at 2C at the field. I actually bring two Pb batteries with me usually to the field if I'm going to fly all day. That is the downside when charging at the field on 12 volt source that You have to bring that with You, or have enough LiPo packs so You can fly as much You prefer and that can be expensive with 10 cell packs, I doubt that many have more then 2-3 maybe 4 such packs, the top flyers maybe have more since they probably are spnsored and can use the batteries for free. A third alternative is there also and that is to get a gas driven generator with you like the small portable one from Honda, Kipor, Yamaha.
So You have different options and many nice chargers out there for You, cheaper or more expensive that can suit different budgets.
As for 5 cell LiPo packs You have ThunderPower as one of the most expensive and HobbyKing various named LiPo on the other end of the price range.
There is 10 cell ready made packs out there also if you prefer that
Maybe You can squeeze out up to about 200 cycles out of a mid quality LiPo pack, maybe some more on higher quality, maybe less on cheaper packs.
I managed to get about 200 cycles out of my 6 cell DesirePower V8 35C 5200 mAh packs (I have 3) before they had not good enough performance for F3A flying (with my Sebart Wind S 50E plane).
Much depend of LiPo care also (like never drain it below 20% of capacity, storage charge them when not in use for example, balance charge etc).
When You tell what plane You are going to use You will get more help what motor, ESC etc that may be a good choice. If You have luck maybe someone else has converted a plane like Yours to electric and can give good advice.
/Bo
< Message edited by bem -- 10/5/2012 1:54 PM >
Hide Signatures
       Post #: 13
RE: Getting started in electric F3A - 10/5/2012 2:23 PM
Zeeb
Score: 111
Status: offline
quote:
ORIGINAL: highfly3D
Regards,
Harry
Bem gave you some good advice and options but if you want to charge either a 10 cell pack or two 5 cell packs wired in series which is probably the most common configuration for a 2 meter size, then there's only one charger that'll do 10S as far as I know and that's the CellPro 10S or newer 10XP. Hobbly King or one of those places puts out the same charger with different labeled cases for a bit less money and it's done under license from FMA.
This is where it gets trickier or should I say spendier????? Is that a word???? lol
The 10XP is a 600 watt charger IF you can feed it with 32 volts which most people cannot, however it's pretty happy with 24 volts and that voltage is becoming much more common with various power supply manufacturers. I elected to go with a system from Progressive RC which uses two CellPro 10XP chargers fed by a 24 volt Meanwell Power supply and that's fed by a Honda generator.
So as I've said, what you might do is really affected by how much you can spend and how big a priority certain options might be for you but recharging the batteries these 2 meter size models use is no small consideration.
Here are a few pics of what I set up with the components from Progress RC which is where the case came from as well. You can see the power supply in the bottom of the case and there is room there to store several different boards and you can see the power cord for the station which is setup on the outside like a computer so the cord can be removed.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Zeeb
Hide Signatures
       Post #: 14
RE: Getting started in electric F3A - 10/6/2012 1:16 PM
jetmech43
Score: 100
Status: offline
Ive got a 10s charger the I can make a deal on if some one wants it
smooth pass
Hide Signatures
(in reply to Zeeb)
       Post #: 15
RE: Getting started in electric F3A - 10/6/2012 3:23 PM
nonstoprc
Score: 110
Status: offline
The other strategy is to buy 5-7 packs and bring the charged packs to field. No generator is needed.
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
