Making an Ultra Flash into an F-20UF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Making an Ultra Flash into an F-20UF
Page: [1] 2 3 4 5 6 7 8 9   next >   >>
Login
Making an Ultra Flash into an F-20UF - 10/1/2012 10:05 PM
Pinnacle Aviation
Score: 100
Last Login: 5/20/2013
Status: offline
This will be the second conversion from sports jet into pseudo scale jet. As the Ultra Flash looks a little like an F-20 I thought of a refreshing change from the standard Comp-AFT standard schemes and the over used Formula 1 team schemes. I am also going to utilise the current aggressor schemes used by the US Air Force, US Navy and US Marines.
I will leave the unavailing of the scheme just prior to painting her.
After installing all the equipment into the airframe I subsequently removed it all to make the painting easier. The first job I did was to sand down the airframe with scotchbrite to give it a surface finish for the primer to adhere too. After that process was complete to save weight I started the panel lines using some self manufactured panel tape. This tape is just normal vinyl cut into 0.8mm wide strips. As you can see I used similar panel lines of an F-5E to give me a rough design as we used the BAe Hawk panel lines for the Ali's Futura.
Tonight I have finished the wings and Horizontal stabiliser (tailplane here in the UK). People may ask why the panel lines, well if you have seen my previous paint projects you would have noticed that I love weathering so in this thread you will also see me weathering the model.
Enjoy the following photos.
< Message edited by Pinnacle Aviation -- 10/2/2012 11:54 AM >
_____________________________
Phil Noel
Pinnacle Aviation (Professional model builder and painter)
Hide Signatures
       Post #: 1
RE: Making an Ultra Flash into an F-20UF - 10/1/2012 10:23 PM
Pinnacle Aviation
Score: 100
Status: offline
Photobucket Pictures, Images and Photos
Phil Noel
Hide Signatures
(in reply to Pinnacle Aviation)
       Post #: 2
RE: Making an Ultra Flash into an F-20UF - 10/2/2012 4:14 AM
PaulD
Score: 105
Last Login: 5/21/2013
Status: offline
Seems to me the classic flash wing/profile would have suited the application better but very interesting project regardless.
Looking forward to seeing the results.
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
       Post #: 3
RE: Making an Ultra Flash into an F-20UF - 10/2/2012 9:36 PM
Pinnacle Aviation
Score: 100
Status: offline
This evening I finished all the panel lines on the Ultra Flash. Tomorrow morning I will give the model a coat of 2k primer over the whole model. I was hoping to have a little more time on the model but two models arrived today, Ali's FEJ F16 for installation of a new large undercarriage and lights, also the Tomahawk Large Futura for build and paint for Aerotrim wing bags. I will be adding a build and paint thread to RCU for the Aerotrim Futura.
Phil Noel
Hide Signatures
(in reply to PaulD)
       Post #: 4
RE: Making an Ultra Flash into an F-20UF - 10/2/2012 9:47 PM
Eddie P
Score: 120
Status: offline
Looking great so far! I like the new wing planform on the Flash and I think it will look great as a Sport F-5.
Hide Signatures
       Post #: 5
RE: Making an Ultra Flash into an F-20UF - 10/2/2012 10:17 PM
smchale
Score: 115
Status: offline
Subscribed. I thought this would be nice in one of the rcaf cf-5 schemes. In the end I went with a Futura, but watching your progress with interest. Also looking fwd to your Futura effort.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to Eddie P)
       Post #: 6
RE: Making an Ultra Flash into an F-20UF - 10/3/2012 2:32 PM
FMRR
Score: 100
Last Login: 5/19/2013
Status: offline
What a great idea, I'm a big fan of the F5 & F20
Hide Signatures
       Post #: 7
RE: Making an Ultra Flash into an F-20UF - 10/3/2012 4:17 PM
Pinnacle Aviation
Score: 100
Status: offline
I got up early this morning to put a coat of grey primer over the ultra flash before I started work in the workshop. At lunchtime I gave the inside a coat of stone effect paint. The heaters are on to cook all the paint on prior to the sanding down.
Phil Noel
Hide Signatures
(in reply to FMRR)
       Post #: 8
RE: Making an Ultra Flash into an F-20UF - 10/3/2012 8:04 PM
Jame
Score: 100
Last Login: 4/19/2013
Status: offline
Making a very hard job look very easy again Phil can't wait to see the end result, another masterpiece I'm guessing, I would've loved to be in this situation when I was speckling the inside of my Flash, took a muppet like me what seemed like hours to mask everything really finishes off the inside though.
Hide Signatures
       Post #: 9
RE: Making an Ultra Flash into an F-20UF - 10/3/2012 8:06 PM
CJ2002
Score: 100
Status: online
Phil,
It would look horny as hell in a well weathered pseudo 527th Aggressor scheme (Alconbury 70s-80s)...
Cheers,
Dick
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Making an Ultra Flash into an F-20UF - 10/3/2012 8:16 PM
Pinnacle Aviation
Score: 100
Status: offline
Hi guys,
Thanks for your nice comments, dick I did look at the old Alconbury scheme but the one I really like is the following brown scheme.
Phil Noel
Hide Signatures
(in reply to CJ2002)
       Post #: 11
RE: Making an Ultra Flash into an F-20UF - 10/5/2012 2:52 AM
Wayne22
Score: 105
Status: offline
can't believe how much definition the panel lines give to the shape of the flash...It should look fabulous when it is finished!!
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
       Post #: 12
RE: Making an Ultra Flash into an F-20UF - 10/5/2012 5:04 AM
Eddie P
Score: 120
Status: offline
Those are all fantastic options!!
Hide Signatures
(in reply to Wayne22)
       Post #: 13
RE: Making an Ultra Flash into an F-20UF - 10/5/2012 1:45 PM
ppljr
Score: 100
Status: offline
Here are some good pics...
http://www.rcuniverse.com/forum/m_11085686/anchors_11085706/mpage_1/key_/anchor/tm.htm#11085706
Hide Signatures
       Post #: 14
RE: Making an Ultra Flash into an F-20UF - 10/5/2012 11:09 PM
Boomerang1
Score: 120
Status: offline
Does the chart tape:
Come off before the colour leaving lines in the primer?
Come off after the colour leaving white lines in the colour?
Not come off at all leaving raised lines in the final finish?
John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to ppljr)
       Post #: 15
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 3:28 AM
Craig B.
Score: 100
Status: offline
Hi John,
It usually comes off after primer so colour fills in the depressions which also capture the weathering paint/ chalk when applied.
Looks great Phil...will be watching this one with interest.
Craig.
Hide Signatures
(in reply to Boomerang1)
       Post #: 16
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 8:53 AM
Pinnacle Aviation
Score: 100
Status: offline
Hi John/Craig,
Your right Craig, I have now removed the tape only after the whole model had been rubbed down with 1000 wet'n'dry. This has now given me a nice line definition for the weathering. The next job will be adding some rivets, I will only be adding about 10k on this model not to many, I added 25k on Ali's Futura and 35k on my hunter so not to many this time. These will be burnt into the paint using a soldering iron and a small piece of copper tube compressed onto the end.
I will add some pictures later of the model before, during and after the riveting.
Phil Noel
Hide Signatures
(in reply to Craig B.)
       Post #: 17
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 8:46 PM
Pinnacle Aviation
Score: 100
Status: offline
The first set of photos show the tape removed, the second set shows the riveting and the tool I used.
Phil Noel
Hide Signatures
       Post #: 18
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 8:51 PM
Pinnacle Aviation
Score: 100
Status: offline
And now the riveting
Phil Noel
Hide Signatures
       Post #: 19
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 9:22 PM
InboundLZ
Score: 140
Last Login: 5/12/2013
Status: offline
No button head rivets?
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
       Post #: 20
RE: Making an Ultra Flash into an F-20UF - 10/6/2012 9:25 PM
Pinnacle Aviation
Score: 100
Status: offline
Hi Dave,
No, there are no button head rivets on the F-20UF
Phil Noel
Hide Signatures
(in reply to InboundLZ)
       Post #: 21
RE: Making an Ultra Flash into an F-20UF - 10/7/2012 3:37 PM
Pinnacle Aviation
Score: 100
Status: offline
First colour on, this is sand which is the underside colour and the lightest colour on the top
Phil Noel
Hide Signatures
       Post #: 22
RE: Making an Ultra Flash into an F-20UF - 10/7/2012 3:53 PM
Pinnacle Aviation
Score: 100
Status: offline
A couple of photos of her all together outside in the afternoon sun while the Marchetti is being painted
Phil Noel
Hide Signatures
       Post #: 23
RE: Making an Ultra Flash into an F-20UF - 10/8/2012 4:25 AM
Wayne22
Score: 105
Status: offline
hope your nose gear fits throught the stock opening after all that rivet work around the perimeter..... I've built 2 and had to reprofile the opening on both...
Hide Signatures
       Post #: 24
RE: Making an Ultra Flash into an F-20UF - 10/8/2012 9:37 AM
Boomerang1
Score: 120
Status: offline
Yep, got the rivet & panel line detail - nice.
Subtle, just enough to avoid the 'plastic aeroplane' look but not over the top. - John.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
