RE: Making an Ultra Flash into an F-20UF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Turbine Epic Victory Jet - Kit
Seller:  cat-boi
Details:   $3,600.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Making an Ultra Flash into an F-20UF
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9   next >   >>
Login
RE: Making an Ultra Flash into an F-20UF - 10/10/2012 4:46 PM
Pinnacle Aviation
Score: 100
Last Login: 5/25/2013
Status: offline
Hi Greg,
I always put the oil paint straight onto the paint without any clear coat, I put the clear on after the weathering and decals have been applied. The paint I use is either cellelous or acrylic basecoat.
The panel lines are made from vinyl sheet which is cut into 0.8mm wide strips, this is applied onto the model the a coat of primer applied, the primer is then rubbed back until the vinyl appears and then they vinyl is removed to give you a simulated panel line.
_____________________________
Phil Noel
Pinnacle Aviation (Professional model builder and painter)
Hide Signatures
(in reply to Maestri-M)
       Post #: 51
RE: Making an Ultra Flash into an F-20UF - 10/10/2012 5:46 PM
Scott Geller
Score: 100
Last Login: 5/22/2013
Status: offline
Very cool! Nice job.
Scott
Hide Signatures
(in reply to Pinnacle Aviation)
       Post #: 52
RE: Making an Ultra Flash into an F-20UF - 10/10/2012 6:06 PM
RCISFUN
Score: 105
Status: offline
1/32" (.8 mm) Wide tape
http://www.amazon.com/Vinyl-Black-Glossy-32-603/dp/B000CCUFWE
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to Scott Geller)
       Post #: 53
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 6:35 PM
Pinnacle Aviation
Score: 100
Status: offline
Putting some decals on to finish it off before I grease her up and clear cot her.
Photobucket Pictures, Images and Photos
Phil Noel
Hide Signatures
(in reply to RCISFUN)
       Post #: 54
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 6:59 PM
Pinnacle Aviation
Score: 100
Status: offline
Some more shots
Phil Noel
Hide Signatures
       Post #: 55
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 8:08 PM
Pinnacle Aviation
Score: 100
Status: offline
A shot of some grease and dirt on the underside
Phil Noel
Hide Signatures
       Post #: 56
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 9:29 PM
RCISFUN
Score: 105
Status: offline
quote:
ORIGINAL: Pinnacle Aviation
That is some serious nice work there!
Aw heck, my Flash looks like that and I didn't even have to work at it... LOL
Oh yea... I even added some deep scratches (read: nose wheel failure to extend) for more of an extra used effect
Rich
Hide Signatures
       Post #: 57
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:07 PM
vease
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: vease
One question. Do you apply the oils directly over the paint or have you put a seal on first?
Thanks for the reply Phil but I lied.....2 more questions.
Do you put the oils on neat or mixed with something?
and what liquid do you use to wipe off the unwanted?
I used oils on my P47 that you may have seen this year, but not sure I used it correctly?
Maybe see you Sunday at Baldock?
Gregg
UK Meister field rep - TJD Display team - BickleyMFC.co.uk
Hide Signatures
(in reply to vease)
       Post #: 58
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:17 PM
Pinnacle Aviation
Score: 100
Status: offline
Hi Gregg,
Cheeky another two questions, ok, I put the oil paints on straight out of the tube when the temperature is below 21 degrees, over that I add a very small amount white spirit.
I wipe it off dry, nothing on the cloth, if I select an area that I don't want much weathering then I put a drop of white spirit on the cloth and remove the oil paint, you have to be careful if you put to much white spirit on the cloth it will remove all of the weathering, if that happens you will need to leave it at least 4 hours so the white spirit totally evaporates otherwise it will affect the oils paints and not give you the weathering results you will need.
I hope this is helpful, if its not raining to much on Sunday I will pop up in the afternoon and see you there Gregg.
BTW, love the T'bolt, looks really good mate.
Phil Noel
Hide Signatures
(in reply to vease)
       Post #: 59
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:22 PM
vease
Score: 100
Status: offline
Thanks once again for the reply and explanation. The P47 turned out OK but was not easy and I new I was not doing it right. You have just confirmed that!
I have a very yellow Bearcat nearing completion which needs details showing up so want to do it right this time.
Thank you!!
Hide Signatures
       Post #: 60
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:31 PM
Pinnacle Aviation
Score: 100
Status: offline
Have you seen Ali's bearcat I did for him, here's a photo
Phil Noel
Hide Signatures
(in reply to vease)
       Post #: 61
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:34 PM
vease
Score: 100
Status: offline
Yes I had seen that... hope he didn't want it kept a secret!
Looks great and a very different scheme. He must lose the spinner though!!
Hopefully I can learn from you when doing mine which will be in this scheme:
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 62
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:36 PM
vease
Score: 100
Status: offline
Sorry, I seem to have highjacked the thread with warbird talk!!
Back to the superb F20 UF
Hide Signatures
(in reply to vease)
       Post #: 63
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:40 PM
Pinnacle Aviation
Score: 100
Status: offline
That's a cool scheme Gregg, if ever you need a hand feel free to pop up with a wing or fuse and I could show you first hand.
Nah, it's not a secret
Phil Noel
Hide Signatures
(in reply to vease)
       Post #: 64
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 10:50 PM
vease
Score: 100
Status: offline
Now that is an offer that the guys across the pond must be very jealous of.
Much appreciated Phil, hope to see you Sunday at your field.
Hide Signatures
       Post #: 65
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 11:00 PM
vease
Score: 100
Status: offline
quote:
ORIGINAL: vease
Now that is an offer that many people must be very jealous of.
Hide Signatures
(in reply to vease)
       Post #: 66
RE: Making an Ultra Flash into an F-20UF - 10/11/2012 11:12 PM
yeahbaby
Score: 135
Status: online
great job amigo!!! the desert aggressor paint scheme fits the ultraFlash nicely.
"Audentes fortuna iuvat"
Hide Signatures
       Post #: 67
RE: Making an Ultra Flash into an F-20UF - 10/12/2012 2:45 PM
Pinnacle Aviation
Score: 100
Status: offline
It looks so much better with a couple of coats of flat clear applied.
Phil Noel
Hide Signatures
(in reply to yeahbaby)
       Post #: 68
RE: Making an Ultra Flash into an F-20UF - 10/12/2012 4:44 PM
Neil Collins
Score: 105
Last Login: 5/23/2013
Status: offline
Hi Phil
Thanks for all your threads and posts, I really learn a lot reading them. This is something I would like to try.
I just have one question.
Once you have done the weathering and decals what do you do as far as prep work before you shoot the clear.
ie. sanding, cleaning, etc
Regards
Neil
Hide Signatures
       Post #: 69
RE: Making an Ultra Flash into an F-20UF - 10/12/2012 6:34 PM
Pinnacle Aviation
Score: 100
Status: offline
Hi Neil,
During the process of painting, weathering and applying the decals I am very careful handling the model, once the decals are applied I give the model a blast with an airline to remove any dust, then a wipe with an anti static cloth, no liquids.
Once that is completed then the clear is applied.
I hope this is helpful.
Phil Noel
Hide Signatures
(in reply to Neil Collins)
       Post #: 70
RE: Making an Ultra Flash into an F-20UF - 10/12/2012 7:34 PM
furloughed ual
Score: 100
Status: offline
Does anyone know if the artists oil paints would be compatible under an epoxy based cleaer? I use Klass Kote epoxy paints exclusively but would like to try this weathering method.
[i] "somewhere between the port of indecision and southeast of disorder" [/i]
Hide Signatures
       Post #: 71
RE: Making an Ultra Flash into an F-20UF - 10/12/2012 10:30 PM
Pinnacle Aviation
Score: 100
Status: offline
As long as you leave the oil paint to harden for between 2 to 3 days you should be fine, but I would always do a test sample.
Whenever I am trying something new I always do a test sample to ensure that it has no reaction between the different paints.
One type of paint you have to be careful of is Humbrol emamals, the only way to get over a reaction with this type of paint is to give it a very light dust coat before a heavy coat is applied.
Phil Noel
Hide Signatures
(in reply to furloughed ual)
       Post #: 72
RE: Making an Ultra Flash into an F-20UF - 10/15/2012 5:38 PM
Pinnacle Aviation
Score: 100
Status: offline
I got round to taking some photos today of her put together before I start the final install of the radio, engine and landing gear which I hope arrives tomorrow.
Phil Noel
Hide Signatures
       Post #: 73
RE: Making an Ultra Flash into an F-20UF - 10/15/2012 10:15 PM
Pinnacle Aviation
Score: 100
Status: offline
Canopy glass fitted
Phil Noel
Hide Signatures
       Post #: 74
RE: Making an Ultra Flash into an F-20UF - 10/16/2012 1:06 AM
smchale
Score: 115
Status: offline
Looks great Phil, it's really coming together well. Refreshing look to the popular Flash.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.125RCU1
