RE: Making an Ultra Flash into an F-20UF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Making an Ultra Flash into an F-20UF
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Making an Ultra Flash into an F-20UF - 1/15/2013 6:15 AM
izzy
Score: 100
Last Login: 5/18/2013
Status: offline
Phil. This is great stuff
What add the panel lines made from?
Can u give us a rough estimate on cost to paint s model
Lets say if it was white.
Izzy
Hide Signatures
(in reply to Pinnacle Aviation)
       Post #: 101
RE: Making an Ultra Flash into an F-20UF - 1/15/2013 10:02 AM
Alex48
Score: 100
Status: offline
I like the 45...
As always, great stuff Phil. Have you got time to do a clear coat in the next 7 days?
Cheers, Alex
_____________________________
The Little Jet Company
www.facebook.com/TheLittleJetCompany
Hide Signatures
(in reply to izzy)
       Post #: 102
RE: Making an Ultra Flash into an F-20UF - 1/15/2013 8:44 PM
Pinnacle Aviation
Score: 100
Last Login: 5/17/2013
Status: offline
The final panel lines fitted and she is complete, I have just given her a heavy coat of primer.
Photobucket Pictures, Images and Photos
Phil Noel
Pinnacle Aviation (Professional model builder and painter)
Hide Signatures
(in reply to Alex48)
       Post #: 103
RE: Making an Ultra Flash into an F-20UF - 1/18/2013 6:26 PM
Pinnacle Aviation
Score: 100
Status: offline
So the story so far, the model has been given a second coat of primer over the lining tape, this way subsiquently rubbed down with 400 wet n dry paper wet. The rivets were then burn into the paint using special tips that I turned up on my lathe. Approximately 5000 rivets were added. The model was then rubbed down with 400 wet again, this is to remove the paint around the rivets that blisters up. I then removed the lining tape.
The model is now in the paint shop and has had it's first coat of the base colour (pale yellow). After its had its second coats then I will mask up the underside and the pale yellow areas of the camo ready for the second colour medium grey, then the final colour olive drab.
Phil Noel
Hide Signatures
       Post #: 104
RE: Making an Ultra Flash into an F-20UF - 1/19/2013 12:52 PM
Pinnacle Aviation
Score: 100
Status: offline
A lot of people have asked me what is the scheme going to be well its something like this magister but I have charged the brown to slate grey
Click to see fullsize image.
Click for fullsize
Phil Noel
Hide Signatures
       Post #: 105
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 11:29 AM
Pinnacle Aviation
Score: 100
Status: offline
Ok this has been a bit of a wind up for Steve who is the owner of this flash. I hope you like it mate. This what was are basing the scheme on, it's going to be an aggressor US Marines VMET-101 (03) s/n 776081 futuristic scheme, not scale, I have change the original scheme from the L39 (pictured) as I wanted the lines on the fuse to be more slanted due to model being a fast looking model.
Phil Noel
Hide Signatures
       Post #: 106
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 11:34 AM
Pinnacle Aviation
Score: 100
Status: offline
Base blue applied over the whole model it's now the very long task of masking.
Phil Noel
Hide Signatures
       Post #: 107
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 11:39 AM
Pinnacle Aviation
Score: 100
Status: offline
The grey now painted is now time for more masking also a little accent from the l39 that I liked, the base of the tiger strips on the top of the fin.
Phil Noel
Hide Signatures
       Post #: 108
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 11:42 AM
Pinnacle Aviation
Score: 100
Status: offline
Now the blue is applied.
Phil Noel
Hide Signatures
       Post #: 109
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 2:25 PM
Pinnacle Aviation
Score: 100
Status: offline
Some photos of the de masking and getting ready for the next batch of masking
With any paint job there is always a little bit of touching up that needs to be done
Phil Noel
Hide Signatures
       Post #: 110
RE: Making an Ultra Flash into an F-20UF - 1/22/2013 5:52 PM
InboundLZ
Score: 140
Last Login: 5/12/2013
Status: offline
Out-flipping-standing! The work involved in just taping that off is just crazy in itself....
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
       Post #: 111
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 11:17 AM
Pinnacle Aviation
Score: 100
Status: offline
Now to the final stage of masking and painting, then on to weathering and clear coat, I think flat clear coat will suit this colour scheme
Phil Noel
Hide Signatures
(in reply to InboundLZ)
       Post #: 112
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 11:38 AM
Andrew Bird
Score: 110
Status: offline
It looks fantastic! Not wanting to be negative but a real shame about that rudder arm cut out in the fin, though.
Hide Signatures
       Post #: 113
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 12:53 PM
Pinnacle Aviation
Score: 100
Status: offline
Hi Andrew, yes it does look crap but we have a plan, there is a cover which will be fitted after the linkage has been fitted. Thanks for asking.
Phil Noel
Hide Signatures
(in reply to Andrew Bird)
       Post #: 114
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 1:00 PM
Andrew Bird
Score: 110
Status: offline
Excellent! That will clean things up nicely - the scheme looks so good it would have been a shame not to do something with the cut out. Really looking forward to seeing pics of it all together, the scheme really suits the plane.
Hide Signatures
       Post #: 115
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 1:01 PM
marc s
Score: 110
Status: offline
Phew! Awesome AGAIN
marcs
Hide Signatures
       Post #: 116
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 1:46 PM
Aerotrimwingbagz
Score: 100
Last Login: 5/10/2013
Status: offline
Phil you are a sod !!! I wanted the camaroon scheme !!! Lol!!
The pain i have been through with phil and ali winding me up !!
Well done mate !! Its amazing  !! you are the meastro of the building world and have made me some special toys indeed and cant wait to get it eating the sky with the 180  !!!
Hide Signatures
(in reply to marc s)
       Post #: 117
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 2:25 PM
Pinnacle Aviation
Score: 100
Status: offline
Thanks guys for your nice comments.
Here are a couple of shots of the wings due the second phase of masking
Phil Noel
Hide Signatures
(in reply to izzy)
       Post #: 118
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 2:46 PM
Pinnacle Aviation
Score: 100
Status: offline
A pre figment of the wings and fuse to get the fuse profile for the 'No Step' zone
Phil Noel
Hide Signatures
       Post #: 119
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 2:56 PM
Pinnacle Aviation
Score: 100
Status: offline
Having a visit from the quality manager, overseeing what I am doing and making sure I am doing it correct LOL
Phil Noel
Hide Signatures
       Post #: 120
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 4:10 PM
Pinnacle Aviation
Score: 100
Status: offline
Blimey this project has created a lot of attention, just had a visit from the general manger to see how this model is coming along LOL
Phil Noel
Hide Signatures
       Post #: 121
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 4:13 PM
Pinnacle Aviation
Score: 100
Status: offline
Ok seriously back to the model, the no step zones are now masked off. I little time consuming but worth it in the end.
Phil Noel
Hide Signatures
       Post #: 122
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 4:38 PM
Pinnacle Aviation
Score: 100
Status: offline
At last the final bit of painting before the weathering. It's always a good idea to make a chart to explain which colour goes on what colour
Phil Noel
Hide Signatures
       Post #: 123
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 5:34 PM
3dean
Score: 101
Status: offline
too good
Hide Signatures
       Post #: 124
RE: Making an Ultra Flash into an F-20UF - 1/23/2013 5:41 PM
Jamie C
Score: 115
Last Login: 5/19/2013
Status: offline
Nice . . . . very nice!
Hide Signatures
(in reply to 3dean)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
