BVM MAVERICK FLAP'S    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> BVM MAVERICK FLAP'S
Page: [1]
Login
BVM MAVERICK FLAP'S - 10/1/2012 10:25 PM
agent adds
Score: 100
Last Login: 5/22/2013
Status: offline
FROM THE ORIGINAL INSTRUCTION BOOKLET-HOW DOES BVM RECOMMEND TO HINGE THE FLAPS WITH-PLEASE
Hide Signatures
       Post #: 1
RE: BVM MAVERICK FLAP'S - 10/2/2012 7:12 AM
agent adds
Score: 100
Status: offline
whilst i was sleeping i thought i would wake up to a reply
Hide Signatures
(in reply to agent adds)
       Post #: 2
RE: BVM MAVERICK FLAP'S - 10/2/2012 2:03 PM
FalconWings
Score: 121
Status: offline
No one cares, its all about Large Hawks and $14,000 A4's that dont work.
I had a Mav and as much as I can remember it used nylon flat type hinges, bonded against the split flap top skin and the inner skin of the balsa sheeting of the wing. Really nothing to it, if memory serves me well.
A friend of mine did a mod to replace the split flap with a normal full bodied one. Just cut the flap off of the wing and sheet every surface that has an exposed section of foam core, then hinge at the very bottom.
Good luck,
David
_____________________________
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 3
RE: BVM MAVERICK FLAP'S - 10/2/2012 2:10 PM
lov2flyrc
Score: 109
Last Login: 5/21/2013
Status: offline
Just use a normal flat hinge from the bottom. Nothing special about the Maverick flaps!?
Todd Witkoff
Dreamworks Model Products LLC
www.dreamworksrc.com
Your Source For RC Jet Accessories!
Hide Signatures
(in reply to FalconWings)
       Post #: 4
RE: BVM MAVERICK FLAP'S - 10/2/2012 3:17 PM
gunradd
Score: 120
Status: offline
The normal mavs used a split flap. The mavpro used a normal flap.
Loving my Kingtech Turbine!
Hide Signatures
(in reply to lov2flyrc)
       Post #: 5
RE: BVM MAVERICK FLAP'S - 10/2/2012 6:00 PM
PHIL NUZA
Score: 100
Status: offline
Something like this.....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Phil Nuza
BVM Rep
Hide Signatures
(in reply to gunradd)
       Post #: 6
RE: BVM MAVERICK FLAP'S - 10/2/2012 8:19 PM
ron Sweeney
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Adam, all the above posts are correct. I have just done mine, (full depth with standard bottom hinging) Why do you ask? yours is complete, Ron.
Hide Signatures
       Post #: 7
RE: BVM MAVERICK FLAP'S - 10/2/2012 9:48 PM
agent adds
Score: 100
Status: offline
renewed!
Hide Signatures
(in reply to ron Sweeney)
       Post #: 8
RE: BVM MAVERICK FLAP'S - 12/20/2012 8:02 PM
dwatherton
Score: 100
Status: offline
If you still need it I have a standard Maverick, stopped mid-stream in the building phase years ago. Still have all the documentation, so I can send you the exact info from the manual and picture pages. Would be able to send them right after Christmas. Just let me know.
Hide Signatures
       Post #: 9
RE: BVM MAVERICK FLAP'S - 12/20/2012 8:31 PM
cmjets
Score: 105
Status: offline
Hi Adam:
You can make the hinges like composite wing, you must retire half balsa cover and put into the nylon hinge, them cover again with balsa and them apply fiber glass. Is like built the wing in foam with the nylon hinge but with a wood and ribs wing.
I show you a photo of my foam wing with nylon hinge.
BR form Spain.
Carlos Márquez
http://cmjets.blogspot.com.es/
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dwatherton)
       Post #: 10
RE: BVM MAVERICK FLAP'S - 12/20/2012 8:38 PM
cmjets
Score: 105
Status: offline
I used the same method in the vertical fins of Roo´s and Hotspot.
Regards.
Click for fullsize
Hide Signatures
(in reply to cmjets)
       Post #: 11
RE: BVM MAVERICK FLAP'S - 12/20/2012 8:58 PM
dbsonic
Score: 100
Status: offline
Carlos, very nice. The hinge material is a nylon strip of some sort? Any idea where to get it and thickness?
Hide Signatures
       Post #: 12
RE: BVM MAVERICK FLAP'S - 12/20/2012 9:01 PM
eazyp
Score: 100
Status: online
cmjets or anyone else, where can I find this type of hinge material,I would love to try this out. thanks Paul
Hide Signatures
       Post #: 13
RE: BVM MAVERICK FLAP'S - 12/20/2012 9:38 PM
cmjets
Score: 105
Status: offline
Hello friends:
I buy this nylon hinge here:
http://www.maquelar.com/
you click in "tienda online" them in "varios" and you find:
Cinta para bisagras 20mm ancho
Cinta de nylon especial para bisagras full-span tanto para alas forradas en madera como en fibra de vidrio. Tejido suave y resistente al uso. Paquete de 5m.
Grupo: 20 Ref: PPL-20 Precio: 4,40.- €
I don´t know if sell out Spain, but if not you send me a PM and I can send you, no problem.
Carlos Márquez
__________________________________
Click for fullsize
Hide Signatures
(in reply to eazyp)
       Post #: 14
RE: BVM MAVERICK FLAP'S - 12/20/2012 10:21 PM
joeflyer
Score: 105
Status: offline
The Maverick came with Hayes Poly hinges.  I have used them on the flaps and other control surfaces on my Maverick and on a number of other planes.  They hold up very well.  I've had no issues with them and 250 flights on one jet.  Your local hobby shop may have them.  If not they're available from Tower.  http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK840&P=7
Joe
Hide Signatures
       Post #: 15
RE: BVM MAVERICK FLAP'S - 12/22/2012 10:02 PM
Wclays
Score: 105
Status: offline
http://www.hobbyking.com/hobbyking/store/__8400__Heavy_Duty_Arms_L43_22_H1_H2_5pc.html
http://www.hobbyking.com/hobbyking/store/__9214__Heavy_Duty_Arms_10pcs_bag_.html
These look like a possible substitute for the nylon hinge.
Hide Signatures
(in reply to joeflyer)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
