Flyzone Nieuport Prop removal    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Flyzone Nieuport Prop removal
Page: [1]
Login
Flyzone Nieuport Prop removal - 10/1/2012 11:12 PM
bgordon
Score: 100
Last Login: 4/16/2013
Status: offline
I am trying to remove a broken prop. Tried needle nose on the drive shaft and pulling on the prop. I think its glued on so i tried spak the front with nail polish remover ,....nothing..any help out there?
Hide Signatures
       Post #: 1
RE: Flyzone Nieuport Prop removal - 10/3/2012 10:17 PM
Dr Kiwi
Score: 120
Last Login: 5/24/2013
Status: offline
They probably used CA to glue the prop to the shaft, and it would be hard to get CA remover into the back of the hub........you may have to carve off the prop hub with a knife or, carefully, with a cutting wheel in a Dremel.
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to bgordon)
       Post #: 2
RE: Flyzone Nieuport Prop removal - 10/5/2012 6:21 PM
Glacier Girl
Score: 122
Status: offline
Or before you go hacking at it, some of the micros have the prop actually screw onto the prop shaft. Just like spinning a nut onto a bolt.
Try holding the prop shaft, and spinning the prop counter clockwise, viewed from the front.
Missing Man Formation, Looking heavenward you can''t help but shed a tear,mournful, lonesome, a hole that screams out at you
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
