BVM Nose Gear    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> BVM Nose Gear
Page: [1]
Login
BVM Nose Gear - 10/2/2012 12:06 AM
YellowAircraft
Score: 181
Last Login: 5/23/2013
Status: offline
Hi,
Has anyone used the old plastic BVM nose unit (like from the 60" Sabre) with a separate air cylinder instead of the retract servo they were designed for? I have the plastic set and I'm trying to use them for this Sabre build.
Thanks in advance for any help.
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
       Post #: 1
RE: BVM Nose Gear - 10/2/2012 12:23 AM
NickC5FE
Score: 150
Status: offline
Yeah i have and they work fine. I would just make sure the trunnion in the gear unit is aluminum. BV updated them years back because that was a high failure point. The plastic housing with separate air ram is ok though..
I Fly FREDex
The C-5M Super Galaxy project
Hide Signatures
(in reply to YellowAircraft)
       Post #: 2
RE: BVM Nose Gear - 10/2/2012 12:33 AM
DAN AVILLA
Score: 100
Last Login: 5/24/2013
Status: offline
I had a 60" saber many years ago and I converted it to all air. Not a problem. The only thing is the plastic retract frame doesnot hold up well when it is turbine powered. The weight gets to it. If you can find the metal frames or use the new gear it would be better. Dan Avilla
Hide Signatures
(in reply to NickC5FE)
       Post #: 3
RE: BVM Nose Gear - 10/2/2012 2:28 PM
YellowAircraft
Score: 181
Status: offline
Hi,
Thanks, guys. I guess what I should have asked was how you installed the air cylinder. The nose cone/inlet lip appears to be in the way. Thanks.
Hide Signatures
(in reply to DAN AVILLA)
       Post #: 4
RE: BVM Nose Gear - 10/2/2012 4:08 PM
Per Strommen
Score: 100
Last Login: 5/21/2013
Status: offline
I put the air cylinder behind the wheel opening with a brass tube "pushrod" on my ducted fan Sabre
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: BVM Nose Gear - 10/2/2012 8:26 PM
ron Sweeney
Score: 100
Last Login: 5/18/2013
Status: offline
Trim aircraft in Australia make the metal rotating nose retract and the extended air cylinder. I use this on my bvm Sabre. works a treat on grass, Ron.
Hide Signatures
       Post #: 6
RE: BVM Nose Gear - 10/2/2012 8:46 PM
YellowAircraft
Score: 181
Status: offline
Ron,
Do you have any pics of your install? That'd be very helpful!
Hide Signatures
(in reply to ron Sweeney)
       Post #: 7
RE: BVM Nose Gear - 10/3/2012 3:55 AM
Chris True
Score: 100
Last Login: 5/6/2013
Status: offline
The trick is the bend in the brass tube
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
