Ziroli Stearman Idea    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
PT-17 Stearman - 87"
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> Ziroli Stearman Idea
    Page: [1]
    Login
    Ziroli Stearman Idea - 10/2/2012 2:02 AM
    Fear2722
    Score: 100
    Last Login: 5/23/2013
    Status: offline
    What's going on everyone? I'm finishing up the frame-up of my 87" Ziroli Stearman. I can't help but think how cool it would be to have the wing center section be the fuel cell just like the real bird. As of now, unless I inherit some unforseen windfall of money, I will be powering the beauty with a G-62. My plan is to make a second center section as a mold/plug, and lay one up with fiberglass, and having wood roots, leading and trailing edge. I haven't calculated the amount of fuel it will hold when done, but I think it will be an awesome addition.
    Question is, how well does fiberglass and resin hold up to gasoline? Do I need to go about this a different way to bring the dream to life? Never have taken on a glass project like this, so all your advice will be appreciated.
    Hide Signatures
           Post #: 1
    RE: Ziroli Stearman Idea - 10/2/2012 2:46 AM
    abufletcher
    Score: 1576
    Last Login: 5/24/2013
    Status: offline
    You might also consider making your own custom brass fuel take. It's not all that difficult with some thin brass sheet and basic soldering skills. One worry I would have with the fiberglass (apart from whether it is truly fuel proof) is that I'd want the INSIDE of the tank to be completely free of loose fibers. There's also the question of whether a gravity feed tank works with our RC models. I'm no expert, just throwing out some thoughts.
    Hide Signatures
    (in reply to Fear2722)
           Post #: 2
    RE: Ziroli Stearman Idea - 10/2/2012 2:47 AM
    denoferth
    Score: 105
    Last Login: 5/20/2013
    Status: offline
    Sounds like a plan but I’d put a shut-off cock in the line and there is another issue. I've been following the Tailwind and Dyke Delta homebuilt sites and people there have reported many problems with alcohol in auto fuel. Some even reported leak problems with rubber bladders in metal tanks when they started using auto gas with only 10% alcohol. I see Sears and a few other stores are now selling cans of alcohol-free gasoline. Maybe in our application, where the fuel tank only holds fuel when we are flying and not for longer periods parked in the hanger, it would work. I’d still make up a test panel with the epoxy I would be using and submerge it in a jar of gas for a few months to see if it showed any deterioration.
    _____________________________
    I have seen things you people wouldn’t believe.
    Hide Signatures
           Post #: 3
    RE: Ziroli Stearman Idea - 10/2/2012 3:45 AM
    TFF
    Score: 148
    Status: offline
    You will need to research the right epoxy; hobby epoxy will not be good enough. You might need s backup plan in case the tank has problems a couple of years from now.
    Hide Signatures
    (in reply to denoferth)
           Post #: 4
    RE: Ziroli Stearman Idea - 10/2/2012 4:04 AM
    Fear2722
    Score: 100
    Status: offline
    I was thinking more along the lines of structural adhesive used in full scale composite and fiberglass applications. The brass idea doesn't sound too bad either. If this comes to life, my fix for the fuel delivery issue (should the G62 require it) is just to throw a pump in the fore end of the fuselage. The bad thing about good ideas is the amount of work it takes to make them fruitful sometimes! Thanks all
    Hide Signatures
    (in reply to TFF)
           Post #: 5
    RE: Ziroli Stearman Idea - 10/2/2012 1:56 PM
    Idigbo
    Score: 100
    Status: offline
    A G62 will pump fuel from a tank in the tailplane if it has to!! I've had a couple of De Havilland models where the tank is in or on the top wing. The first prime of the day takes a few seconds, but once there you'll have no issues. Since the carb is a sealed, pumped unit, you'll have no issues with syphoning either. I have a 1/2 scale Flying Flea on the go at the moment (its actually been on the go a few years) and that has a geared Zenoah 22 and the tank will be in the wing. I'll make it from tinplate, soldered up with normal soft solder. You can obtain a screw top filler by using the top of a tinplate can, simply cut the fitting off an old can, leaving enough spare for a good soldering surface and solder away. Be sure to do a thread when you start, it'd be interesting for sure!!!
    Heres a couple of pics of my models that had tinplate tanks on the wing. A DH Tiger Moth and an Airco DH2, both 1/3 scale and powered by a Z62
    Ian.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 6
    RE: Ziroli Stearman Idea - 10/2/2012 9:39 PM
    Fear2722
    Score: 100
    Status: offline
    Where do you get the tinplate at? I've never taken on a project that would require it! Do you need to pressure test them at all?
    Hide Signatures
    (in reply to Idigbo)
           Post #: 7
    RE: Ziroli Stearman Idea - 10/2/2012 11:20 PM
    Idigbo
    Score: 100
    Status: offline
    I use old oil cans, dismantle with tin snips and clean thoroughly. I don't pressure test at all, but do test them with a full tank of petrol. Best thing is to make sure the parts fit well with a good soldering flange. Tin the parts well and then solder away. Its very rewarding to make a scale tank that works. You'll need a clunk filter, this can be either permanently fitted to the tank structure, but I fit the fittings into a removable screw cap for serviceability.
    Ian.
    Hide Signatures
           Post #: 8
    RE: Ziroli Stearman Idea - 10/7/2012 4:13 AM
    eagle1945
    Score: 100
    Last Login: 5/21/2013
    Status: offline
    any tank you deside on, should be coated with gas tank liner. its cheap and light waight. i'm using 2 olive oil cans as tanks for my PBY, both are cut open and baffeled put back together and soldered and then coated to make them completely sealed.
    Hide Signatures
           Post #: 9
    Page:   [1]
    Page: [1]
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.797RCU1
