Need Servo Advice    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Need Servo Advice
Page: [1]
Login
Need Servo Advice - 10/2/2012 2:46 AM
STKNRUD
Score: 110
Last Login: 5/24/2013
Status: offline
Got my KingCat out that I hadn't flown for a long time. Put it up on its back and attached wings to check gear and control servos. The flaps were 'frozen' and the 8611 servos could be heard trying to move them. I stared at it for a few seconds and tried the flap switch a couple times before I turned the Rx off. Rolled the planed over on the stand and there was the tape on the top of the wing and flap starring at me...called it a brain fart or age impairment. In any event, the servos work fine (with tape removed)...no slippage with resistance or hesitation. BUT can I trust that I haven't damaged them? Please save me the lecture, I feel bad enough!
George
_____________________________
I didn''''t say it was the plane''''s fault. I said I was blaming the plane.
Hide Signatures
       Post #: 1
RE: Need Servo Advice - 10/2/2012 4:28 AM
InboundLZ
Score: 140
Last Login: 5/23/2013
Status: offline
I highly doubt you damaged them. I assume they still move smoothly and work correctly? I would do a couple of cycles and if they work properly I would be on my way....
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
(in reply to STKNRUD)
       Post #: 2
RE: Need Servo Advice - 10/2/2012 4:29 AM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
pop wing cover and turn it on and load it with your hand for a bit to about 1-2 amps.. (use a watt meter on your main batt input) to simulate air load.. check temp of servo as well.. thats a pretty tough servo. I have one that was bound longer than that on a rudder and it was ok.. More important is checking your batts or replacing after extended sit time
Goose
Wren Turbines USA, Fromeco
Hide Signatures
       Post #: 3
RE: Need Servo Advice - 10/5/2012 2:43 PM
rctech2k7
Score: 115
Last Login: 4/16/2013
Status: offline
You got answer from this query already and to give you my point, you didn't damage them, test your servo no load current, with rated terminal voltage must be almost zero. At same voltage full load current it must deliver rated torque.
More than just sports, hobby and recreation, it’s technology…
Hide Signatures
       Post #: 4
RE: Need Servo Advice - 10/5/2012 5:29 PM
GSR
Score: 110
Status: offline
Dont worry as much about the servos as you should the mounts, horns and linkages- Give them a really good inspection. Scotty
"If you ain''t crashed-You ain''t flown"
Hide Signatures
(in reply to rctech2k7)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
